Elburn
  1. Elburn replied to Elburn's topic in ISY994
    Sorry to be so confused. I buy another isy 99ipro with the PLM I plug it in the building and network switch that I am having probs with. I Remove all my devices from the ISY that are sort of working with the ISY in the main house and register them to the new ISY in the guest house. I looked over the white papers on REST programming and it is way over my head. Is the next step to configure the 2 ISYs to talk to each other fairly simply. Thanks for your help
  2. Elburn replied to Elburn's topic in ISY994
    Can not do wire as we have fiber optic building to building due to lightning. Main house has the router. Then we convert to fiber then go to the other houses another fiber to network converter, then a cisco switch. Would this work
  3. Elburn replied to Elburn's topic in ISY994
    Sorry a lot over my head Buy a 2nd ISY 99pro with PLM Plug it into the house wifi and wireing I am having problems in. Where do i configur the 2 isys looking at each other.
  4. Elburn replied to Elburn's topic in ISY994
    Thanks How would I go about that. Everyting is on the same wifi network Thanks for your help'
  5. Elburn posted a topic in ISY994
    We have an very large property that spans 3 building on 2 transformers and generator. Things work great for the main house and 2nd house but not for the 3rd house, it is not stable since it is on a diffrent transformer. could I register a 5 button device to 2 different isy controllers. Would it even work. I have very close rf devices where it should make the hope between the 2 buildings but it does not always work.
  6. Elburn replied to Elburn's topic in ISY994
    I have a program/timer which turns on the 2 relays between sunset and 9 pm independent of any scene or device action. My concern is that if someone presses the A button in error durning Sunset to 9 pm lets say at 8:30 pm that it now overrides the stay on until 9pm part of the independent program and will only say on until 8:40
  7. Elburn replied to Elburn's topic in ISY994
    They are actual 2 diffrent programs.. the Driveway Timer is a sunset to set time program that controls the 2 relays not buttons or scenes involved.. The only reason I added that is not to override the timer off time. The Status "anybutton A" would be the name of each acutal button A so if I have 5 button A's in the scene then they would all be listed on the if part of the program with or between each?
  8. Elburn replied to Elburn's topic in ISY994
    I think I am starting to get it. Thanks The next thing I am doing is that all my A button should function as follows They should all light up when anyone are pressed and off when done. Turn the driveway lights relay (2450) and foyer lights relay (2450) on for 10 min then shut off. This allows someone to leave and then automactily turn off those lights. And allow if they pressed this button in error to press it again and cancel shut off the relays. Currently I am doing this with the following... Would this be correct and or any better way to do it. If Control '{HIDE ME} Foyer Switch - A' is switched On And Program 'MH Driveway Timer' is False Then Set '{HIDE ME} Foyer Switch' On Set 'Foyer Walk Lights' On Set 'Driveway Lights' On Wait 10 minutes Set 'Foyer Walk Lights' Off Set 'Driveway Lights' Off Set '{HIDE ME} Foyer Switch' Off Set Scene '{HIDE ME} Foyer' Off Else - No Actions - (To add one, press 'Action') Thanks again
  9. Elburn replied to Elburn's topic in ISY994
    Looks as the relays 2450 will only allow me to put them into the scene as responders not controlers. Would this still work?
  10. Elburn replied to Elburn's topic in ISY994
    I have 2 relays that are controling high amp loads so in my scene is all the devices are set as responders not controlers... and then the following program triggers it it is workng but my ? is would it be the right way? What I want to happen is when anyone pushes the B button that all the B status Lights go on on each of the devices and the 2 relays turn on ... or off... and it should work at any switch that is in the program If Control '{HIDE ME} Bedroom - B' is switched On Or Control '{HIDE ME} Study Entrance - B' is switched On Or Control '{HIDE ME} Foyer Switch - B' is switched On Or Control '{HIDE ME} Garage Entrance - B' is switched On Or Control '{HIDE ME} Garage House B' is switched On Or Control '{HIDE ME} Garage Hr Office -B' is switched On Or Control '{HIDE ME} His Office - B' is switched On Or Control '{HIDE ME} Pool Path Ent B' is switched On Or Control '{HIDE ME} Pool Equpt B' is switched On Or Control '{HIDE ME} Pool Side Ent - B' is switched On Then Set Scene '{HIDE ME} Security Lights Sce' On Set '{HIDE ME} Security Lights GEO' On Set '{HIDE ME} Security Lights Tas' On Else - No Actions - (To add one, press 'Action') I have another progarm with the above but with Off commands...
  11. Any way to remove a device that no longer respnondes to the ISY, broken...out of range what ever the case.... can this device be deleted or removed manually?
  12. Elburn posted a topic in ISY994
    Need help in setting up a 4way I have a garage with 3 2487s installed. The house door is the 2487s actually set up with the switch leg (red wire) wired in. the other 2 switchs are not using the red wire. I want all 3 to work the same when you press the on/off button at any location. Control the same load and turn on the on button when on and off button when off. I have created a scene but does not work. Do all 3 go in one scene as controlers?
  13. Understanding that I can not seperate the load from the on/off could disconnect the load from that switch and use a 2443-222 Micro on/off without a regular sw attached and just program it in a scene. It is not just one post light but 4 at opposit ends of the pool so it goes 50 to the right and 150 to the left. Also can I control CFL type load with the 2443-222 (non dimming) micro switch?
  14. I have a 2487s at a exit door location where we are using the Red/Load wire to control outdoor switch leg to pier lights about 50 ft from the door. As expected the on off of that switch contols that wired load (pier lights). What I would like to do is not control that load via the ON/OFF of that 2487s there but rather use the A or B or whatever else button we choose and would like the ON/OFF to act as a 3 way for the soffit lights as that makes more sence as being the local load (soffit lights are outside that door) . The soffit lights are controled via another 2487s at the location where the soffit light switch leg is. I know how to to a 3way and make the A and B work but what I do not know how to do is seperate the on/off from the wired load to act independant of the wired load. Thanks
  15. Can anyone point me in the right direction. In Mobilinc I am able to set custom status state names for on off. I would like to do that through the ISY if possible. As an example we have a sensor for low water and right now it says low water sensor "ON" I would rather have it say "ALL OK" Thanks
