ro345
  1. I am seeing time events very frequently in my event log. Any idea what these are? I found a post that says they should be very ten minutes, but these happen very often. Event log below:
  2. One more thing. When I performed the tests today, I was running over a VPN to my home, the latency was about 150-200ms roundtrip. However, my source IP address that would be presented to the ISY would be from the same subnet as the ISY is connected to. I've seen the problem occur both directly attached to my LAN with 1ms latency and coming in through my VPN.
  3. Michel, That seems to be it. On both Windows and Ubuntu, if I access the the ISY using http, I do not get Current State information or any Event Logs. If I access it using https, then I do get that information and the ISY Java Administrative Console seems to work just as it should. I tested this 3 times in each scenario (Ubunutu Firefox/http, Ubuntu Firefox/https, Win7 Chrome/http, Win7 Chrome/https). In all cases, http failed, but https was successful. That may be coincedence but I think you are on to something here. I would have never thought that the jar app changed its communication protocol depending upon the way the browser called it.
  4. I just started using the ISY and this happens very often for me. I use both Ubuntu Linux and Win 7 using the latest Oracle Java on both. I will lose the "current state" information for all devices. The "event log" will show no events occuring. I can still turn devices on and off, but the state is never updated. I can still edit programs and most everything else seems functional. It can happen on both wireless or wired. It seems to happen most frequently if the PC goes into suspend mode and then comes out of suspend mode. It seems like rebooting the PC helps sometimes. Rebooting the ISY doesnt seem to help. When it happens, I just switch to a different PC, until I find one that works. So far I can say that I'm very happy with the ISY except for this isssue.
