Baja
  1. Thanks for your replies! It looks like I'll have to gather some additional information. The hard part is that it's for a house in Mexico where they don't always follow standard wiring conventions! I should have taken pictures of the wiring in both switch boxes, because now I can't remember exactly what the wiring in each box looked like.
  2. I want to use Insteon switches to replace a traditional 3-way switch configuration. The problem I have is that one switch has a neutral wire but the other one does not. Is it possible to use a traditional Insteon dimmer switch (with neutral wire) and a 2-wire Insteon dimmer switch to create an Insteon 3-way switch replacement?
  3. Baja replied to Baja's topic in ISY994
    Yes, I perform a "Restore Device", followed by "Write Updates to Device". I can't get rid of the green 0101 icons, and now the individual buttons don't work either.
  4. Baja replied to Baja's topic in ISY994
    I'm still having problems with my RemoteLinc devices. Right now, the only buttons that are working are the All ON and All OFF buttons. The other buttons no longer control the lights they were controlling before. Any ideas on what to try next?
  5. Baja replied to Baja's topic in ISY994
    I was able to restore the two RemoteLinc 2 devices but regardless of where I was in my house, I was not able to restore the two RemoteLinc devices successfully. They still have the green 0101 icon next to them. One thing I noticed that was odd was when I did a Restore Device to one of my RL devices, I saw on the admin console that it showed Writing to Device on the other RL device, and then later it showed Writing to Device for the RL device I had selected. I wouldn't have expected this behavior. Shouldn't it just write to the RL device I had selected? Do you have any other ideas?
  6. Baja replied to Baja's topic in ISY994
    I replaced the PLM following your instructions and everything worked well except for my RemoteLinc and RemoteLinc 2 devices. Even after performing Restore Device these devices still have the 0101 icon next to them. Would you recommend a factory reset on these devices or is there a unique procedure for RemoteLinc and RemoteLinc 2 devices?
  7. Baja replied to Baja's topic in ISY994
    Paul, Thanks for your quick response. After running the Replace Modem steps, would you recommend following the steps to Restore Devices? I have several devices that are problematic and I was wondering if this step might clear up those issues. Thanks.
  8. Baja posted a topic in ISY994
    I have an ISY994i/IR Pro that I've been using for several years, but my PLM just died and I'm very confused about the exact procedure to replace it. Do I need to perform the "Delete Modem (PLM)" steps before I perform the "Restore Modem (PLM)" steps? Is there a place I can find all of the steps I need to perform listed in the exact order I need to perform them? This whole procedure is very confusing and I would appreciate any help you can offer me. Thanks.
  9. I am using MobiLinc HD and the ISY Portal to communicate with my ISY. After updating my ISY to v4.5.1, I was having trouble syncing so I deleted my MobiLinc HD app and re-installed it. The problem I'm having now is configuring the account and password information. It says to use the password I used when registering the ISY Portal. Is this different than the actual ISY Portal Login? How can I find which password I used when registering the ISY Portal or how do I go about resetting it? Thanks!
  10. Thanks, you've been very helpful!
  11. No. Do I just run this one time after all stations have completed?
  12. I'm trying to program my EZFlora to only water when needed. I have both the climate and irrigation modules. I'm currently using the value "Irrigation Reqt". However, I notice that this value slowly increases every day without ever decreasing. Is there a better value to key off?
  13. Thanks for the ideas. I'll be testing them out this weekend.
  14. No, that was not my intent. I'm happy to get advice or ideas from anyone with information to share regarding this topic.
  15. Xathros, I set up my garage door controller following your excellent instructions and everything is working correctly for me. Now I would like to take it one step further. Is it possible using the ISY994i controller to write a program that would perform the following? Between midnight and sunrise, if my garage door has been open for 5 minutes, run the Garage-Open-Close program to automatically close the garage door. This may not be the right forum, but I would appreciate any help or suggestions you could offer me. I'm new to this and I'm trying to get up to speed as quickly as possible. Thanks!
