lpperras
  1. It looks like you were right, I just moved the ISY about 1 feet closer and now everything runs smooth. Thank you for the advice.
  2. Thank you for the reply, I will see if I can put it any closer and see if it makes a difference. What is weird is that querying it or making it lock or unlock is instantaneous and never failed (So far...). The ISY device is in my basement, but really about 8 feet in linear distance to the actual door (It's the room just below). I'll also take a look at a powered Z Wave device to see if that would make a difference.
  3. This is my only Z Wave device so far. I have about 20 Insteon devices but only this one Z Wave. Thanks for clarifying that it should update it back, I'll reset it again and see if it helps. I have the latest 4.x firmware, do you think 5.x would solve any of this? I was waiting for the go live. Thanks!
  4. I linked my Yale lock to my ISY and after about 4 unsuccessful attempts, I was able to link it. It works fine to send command to it, but the Yale lock doesn't send status back to the ISY. I can query it to know its current status but it won't update it automatically. Is it the normal behaviour or is something not right in the link that was made between it and the ISY? Thanks, Louis
