ebr162
  1. ebr162 replied to jday's topic in ISY994
    How do you deactivate a portal I loaded the isy portal in error and want to remove it. In the portals tab there is a red ! tab. What does that mean? Thanks Barry
  2. That did the trick Thanks Barry
  3. I have set button G to non toggle off to close my garage door. When I press it, the LED flashes 2 times but the program will not trigger. I have cleared the log pressed the G and looked at the log. When I open the log I get a window "Response Failed" and the the log comes up and has no items in it. Here is the program. As I am only in to this for a week I would appreciate any help If Status ‘Key_Pad_G’ is On Then $Tester_Vairable =1 Set ‘1F.C3.77-Relay_Garage_Door’ On Wait 2 seconds Set ‘1F.C3.77-Relay_Garage_Door’ Off Else - No Actions – (To add one, press ‘Action’) Thanks
