scimanic1
Everything posted by scimanic1
  1. Barry, Thanks for all your efforts in developing this solution. Unfortunately, probably due to my lack of understanding, I am unable to get your AWS_Config program to work. AWS_Config is detecting my ISY and two emulators running but errors with "Run-time error '13': Type mismatch" after 40 devices are listed in the "Start of ISY Device Setup" section of the AWS_Alexa file.
  2. Thanks for responding Lee. Been busy with my other projects and haven't had the time to follow up on this. What I am trying to do is trigger the then statement above to toggle the EZIO relay on, wait 1 sec, and then off. The relay toggles correctly when I run the then statement, but can't figure out how to use a secondary keypadlinc button in the if statement to trigger the then statement. Ultimately, I want to use a single secondary keypadlinc to trigger three different programs: The first program, will trigger relay #1 on/off using a Fast On command (turn lights on). The second program will trigger relay #2 on/off using a On command (change lights mode). The third program will trigger relay #1 on/off using a Fast Off command (turn lights off). I hope this is possible. TURN LIGHTS ON: If Control 'Secondary Keypadlinc button' is switched Fast On Then Set 'EZIO Relay#1' On Wait 1 second Set 'EZIO Relay#1' Off Set Scene 'Deck Rail Lights On' On Else - No Actions - (To add one, press 'Action') CHANGE LIGHTS MODE: If Control 'Secondary Keypadlinc button' is switched On Then Set 'EZIO Relay#2' On Wait 1 second Set 'EZIO Relay#2' Off Set Scene 'Deck Rail Lights On' On Else - No Actions - (To add one, press 'Action') TURN LIGHTS OFF: If Control 'Secondary Keypadlinc button' is switched Fast Off Then Set 'EZIO Relay#1' On Wait 1 second Set 'EZIO Relay#1' Off Set Scene 'Deck Rail Lights Off' On Else - No Actions - (To add one, press 'Action') BR, scimanic
  3. Was it something I said? Or didn't say? Can anyone help?
  4. I've searched the forums and internet, but cannot find the answer to my delima. I am trying to create a program that will allow me to use the on and fast on and commands to trigger a program that will toggle two different relays on the EZIO40. I have wired the EZIO to power and mode (dimming levels) control for led lighting and only have one keypadlinc button for both power and mode. The idea was to double-press the keypad button (fast on) to trigger a script (and scene that lights the button) to turn the power on (toggles relay#1). Subsequent presses of the same button (on) would change the mode (toggles relay#2) but leaves the keypadlinc led lit. When I double-press the keypad button again, the power is turned off (toggles relay #1) again. I tried the following script, but I can't get it to trigger properly and not sure how to light the Deck Rail LED. The Then statement works properly and toggles the relay. Any help is greatly appreciated! Program: If Control 'Rear Light-KL / Deck Rail' is switched Fast On Then Set 'Deck Step Lights Mode / Deck Rail Lights Power' On Wait 1 second Set 'Deck Step Lights Mode / Deck Rail Lights Power' Off Set Scene 'Deck Rail Lights On' On Else - No Actions - (To add one, press 'Action') Scene: Deck Rail Lights On Deck Rail (Keypadlinc button) On Level 100% -Scimanic
