rudedog830
  1. I have a keypadlinc button setup as a controller for a water valve controlled by an IOLinc. Currently, the LED lights up when the button is pressed and the water valve is turned to ON. What I want to have happen is that the button is lit only when the IOLinc, and therefore the water valve, is in the OFF state. How do I do this?
  2. I'm looking for an Insteon alternative to the wireless garage entry keypads. What I'd like to be able to do is to provide access via a passcode and then to notify me that someone has successfully raised the door. I already have the Insteon garage relay and sensor. Any thoughts on how this can be done?
  3. I'd like some help on how to program this type of situation: I'd like to be able to set an away condition from a KPL button. This will trigger a setback of temp in my thermostat. Then, I'd like to wait a set amount of time before the temps are set back to the original temps when I left. However, if I come back before the wait period expires and I press the same KPL button, I'd like the temps to change at that point rather than waiting for the time to expire. My main question is...what is the best way to program the "wait a certain period or until a button is pressed" before temperatures are reset?
