atomic182
  1. Here are some screenshots of what I'm working with I'm going to change the values when I'm done but I'm in need of some guidance
  2. I checked the thread mentioned
  3. thanks on the link, i will go check it out right now see if it helps me out of the wilderness i am stuck in.
  4. pc but i have an apples well, i loaded up airport utility on windows to access my router. it port forwarding is much different than i am used to, i think i got the right port forwarded but not positive.
  5. i have elk m1 gold setup ademco wireless sensors for the security with elkm1xep and isy994i and dualband plm working insteon switchlinc and other device, i got all these hooked up working perfectly programmed without a problem but i have run into an immovable object in trying to access isy and elk remotely, in network everything is perfect but when i try and access out of network nothing. i have read all the links i could on port forward and setting up ekeypad to access but i think i reached the end of my ability's. i am using a apple time capsule does anyone have a proper walk through on what i need to do. thanks
