atomic182
Everything posted by atomic182
  1. Here are some screenshots of what I'm working with I'm going to change the values when I'm done but I'm in need of some guidance
  2. I checked the thread mentioned
  3. thanks on the link, i will go check it out right now see if it helps me out of the wilderness i am stuck in.
  4. pc but i have an apples well, i loaded up airport utility on windows to access my router. it port forwarding is much different than i am used to, i think i got the right port forwarded but not positive.
  5. i have elk m1 gold setup ademco wireless sensors for the security with elkm1xep and isy994i and dualband plm working insteon switchlinc and other device, i got all these hooked up working perfectly programmed without a problem but i have run into an immovable object in trying to access isy and elk remotely, in network everything is perfect but when i try and access out of network nothing. i have read all the links i could on port forward and setting up ekeypad to access but i think i reached the end of my ability's. i am using a apple time capsule does anyone have a proper walk through on what i need to do. thanks
