chazzie
  1. Yeah, I saw that example, but couldn't figure out how to adapt it to the multiple times in the IF statement. If I turn the 'Use Hot Tub - On' program at 9:15pm and it includes a "Run Program 'Hot Tub Maintenance - Off' (Else Path)" to set the 'Hot Tub Maintenance - Off' program to false, won't it just become true again when 9:40pm rolls around?
  2. So you're saying that: If X10 'C9/On (3)' is Received Then Stop program 'Use Hot Tub - Off' Send X10 'C8/On (3)' Wait 3 Seconds Send X10 'C8/On (3)' Wait 3 Seconds Send X10 'C8/On (3)' Wait 3 Seconds Else Set program 'Use Hot Tub - Off' = False ...will make the 'Hot Tub Maintenance Temp - Off' program be overridden correctly by this code?
  3. I recently began the upgrade from x10 to Insteon and purchased an ISY994i as my central controller. I have an older hot tub with mechanical controls, so it is on a heavy duty X10 switch and I use the automation to turn it on for 10 minutes every half hour and then back off for the remaining 20. I leave the mechanical switches set where I like them for actually using the hot tub and this cycle effectively gives me the "maintenance mode" of new digital hot tub controllers. To move this to the ISY994i, I have built two programs (one to turn the switch on every 30 minutes and another to turn it off 10 minutes later). These work well for the maintenance mode, but I don't want to have to log into the ISY994i every time I want to use the hot tub and I don't want it to turn the hot tub off while I'm in it. I have an older (X10 only) KPL next to the physical switch for the hot tub and would like to use a spare button on it to disable the "Off after 10 minutes" program with an x10 signal. I'm hoping this can be done and I just haven't figured out where in the isy994i to do it. Barring that, here is my code (the override program 'Use Hot Tub' doesn't seem to override this, but I left the condition in the code) and maybe someone can offer an alternative way to accomplish the goal of being able to override the "maintenance mode" when I get in the hot tub (without getting out the laptop)(Note the hot tub switch is X10 C8 and the KPL Button I want to use for override is set in toggle mode and sends X10 C9 On/Off): The "Off portion off the "Maintenance" code) If Program 'Use Hot Tub - On' is False And Time is 12:10:00AM Or Time is 12:40:00AM Or Time is 1:10:00AM Or Time is 1:40:00AM Or Time is 2:10:00AM ...well you get the idea. Then Send X10 'C8/Off (11)' Wait 3 Seconds Send X10 'C8/Off (11)' Wait 3 Seconds Send X10 'C8/Off (11)' Stop program 'Hot Tub Maintenance Temp - On' Not that you need it, but the "Use Hot Tub - On" Code: If X10 'C9/On (3)' is Received Then Stop program 'Use Hot Tub - Off' Send X10 'C8/On (3)' Wait 3 Seconds Send X10 'C8/On (3)' Wait 3 Seconds Send X10 'C8/On (3)' Wait 3 Seconds
