Red Baron
Everything posted by Red Baron
  1. Actually I think I'm just going to replace the whole mess with the Somfy MyLink controller. It looks like it will do nearly everything that can be done with the ISY and more. Anybody need an URTSI II?
  2. I've emailed him to see if he has come up with anything else. Have seen anything on the forum so I'm not hopeful. I'd like to see if the new bridge that Smarthome sells can be programmed to control the URTSI...
  3. You know it's funny... >>Smart home never sold the bridge<<, but it has Smarthome's name on it. Go figure!
  4. Yes, I know. That was all done previously and worked just fine for a couple of years. As you can tell from the OP, I had a power issue which I believe caused multiple problems in my system; not the least of which was the failure of my (coincidently I'm sure!) 2 year old PLM. Now that is restored, I'm not seeing the bridge unit that interfaces between the URTSI and the ISY. I have just noticed that there is no LED on with it either, so I'm thinking the issue is that it has failed too (as I think is the issue with my garage door relay interface too). So I think I'm down to hoping that paceyben is still around and can pass on the programming for a new interface bridge. I did see where Somfy has just come out with an interface unit that enables control via WiFi/ internet from a smart device like an iPhone. But I want the ISY control.
  5. Yes, it's an URSTI II. I am not using the dry contact interfaces. I purchased a bridge to interface the ISY with the URTSI that had been programmed by a guy on the Smarthome forum who went by paceyben. At this point, I'm thinking that old Smarthome bridge may have gone south too....
  6. After the "Replace Modem" I can see and control all my devices except the URTSI II. As an aside there is no LED light lit on the bridge modem. Maybe it's bad too?
  7. No. I flowed the Replace Modem instructions to the letter. "followed"
  8. The bridge is an older unit which I don't think Smarthome sells anymore...
  9. My bad... I should have said via a Somfy bridge unit from Smarthome!
  10. Here is the comm file + rewrite on PLM Thu 09/10/2015 15:53:09 : [ 3C 48 86 1] Restoring PLM Thu 09/10/2015 15:53:09 : [ 22 2C D4 1] Replacing PLM links (locally and in PLM) Thu 09/10/2015 15:53:09 : [ 22 2C D4 1] Replacing PLM links Successful Thu 09/10/2015 15:53:09 : [ 22 BA 5D 1] Replacing PLM links (locally and in PLM) Thu 09/10/2015 15:53:09 : [ 22 BA 5D 1] Replacing PLM links Successful Thu 09/10/2015 15:53:09 : [ 22 CA 66 1] Replacing PLM links (locally and in PLM) Thu 09/10/2015 15:53:09 : [ 22 CA 66 1] Replacing PLM links Successful Thu 09/10/2015 15:53:09 : [ 22 D4 D5 1] Replacing PLM links (locally and in PLM) Thu 09/10/2015 15:53:09 : [ 22 D4 D5 1] Replacing PLM links Successful Thu 09/10/2015 15:53:09 : [ 23 DA 58 1] Replacing PLM links (locally and in PLM) Thu 09/10/2015 15:53:09 : [ 23 DA 58 1] Replacing PLM links Successful Thu 09/10/2015 15:53:09 : [ 23 DB FC 1] Replacing PLM links (locally and in PLM) Thu 09/10/2015 15:53:09 : [ 23 DB FC 1] Replacing PLM links Successful Thu 09/10/2015 15:53:09 : [ 23 EA C5 1] Replacing PLM links (locally and in PLM) Thu 09/10/2015 15:53:09 : [ 23 EA C5 1] Replacing PLM links Successful Thu 09/10/2015 15:53:09 : [ 25 3 54 1] Replacing PLM links (locally and in PLM) Thu 09/10/2015 15:53:09 : [ 25 3 54 1] Replacing PLM links Successful Thu 09/10/2015 15:53:09 : [ 2B 7E 9C 1] Replacing PLM links (locally and in PLM) Thu 09/10/2015 15:53:09 : [ 2B 7E 9C 1] Replacing PLM links Successful Thu 09/10/2015 15:53:09 : [ D 4F D9 0] Replacing PLM links (locally and in PLM) Thu 09/10/2015 15:53:09 : [ D 4F D9 0] Replacing PLM links Successful Thu 09/10/2015 15:53:09 : Reset PLM Thu 09/10/2015 15:53:11 : [All ] Writing 102 bytes to devices Thu 09/10/2015 15:53:19 : [22 2C D4 1 ] Link 0 : 0FF8 [A200000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:53:19 : [22 2C D4 1 ] Link 1 : 0FF0 [E201000000FF0001] Writing [....000000......] Thu 09/10/2015 15:53:20 : [22 2C D4 1 ] Link 2 : 0FE8 [A213000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:53:30 : [22 BA 5D 1 ] Link 0 : 0FF8 [A200000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:53:31 : [22 BA 5D 1 ] Link 1 : 0FF0 [A213000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:53:36 : [22 CA 66 1 ] Link 1 : 0FF0 [A200000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:53:37 : [22 CA 66 1 ] Link 2 : 0FE8 [A213000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:53:45 : [22 D4 D5 1 ] Link 0 : 0FF8 [A200000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:53:46 : [22 D4 D5 1 ] Link 1 : 0FF0 [E201000000FF0001] Writing [....000000......] Thu 09/10/2015 15:53:47 : [22 D4 D5 1 ] Link 2 : 0FE8 [A212000000FF1F00] Writing [....000000......] Thu 09/10/2015 15:53:55 : [23 DA 58 1 ] Link 0 : 0FF8 [A200000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:53:56 : [23 DA 58 1 ] Link 1 : 0FF0 [E201000000FF0001] Writing [....000000......] Thu 09/10/2015 15:53:56 : [23 DA 58 1 ] Link 2 : 0FE8 [A211000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:54:04 : [23 DB FC 1 ] Link 0 : 0FF8 [A200000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:54:05 : [23 DB FC 1 ] Link 1 : 0FF0 [E201000000FF0001] Writing [....000000......] Thu 09/10/2015 15:54:06 : [23 DB FC 1 ] Link 2 : 0FE8 [A211000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:54:14 : [23 EA C5 1 ] Link 0 : 0FF8 [A200000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:54:14 : [23 EA C5 1 ] Link 1 : 0FF0 [E201000000FF0001] Writing [....000000......] Thu 09/10/2015 15:54:22 : [25 3 54 1 ] Link 0 : 0FF8 [A200000000FF1F01] Writing [....000000......] Thu 09/10/2015 15:54:23 : [25 3 54 1 ] Link 1 : 0FF0 [E201000000FF0001] Writing [....000000......] Thu 09/10/2015 15:54:24 : [25 3 54 1 ] Link 2 : 0FE8 [E202000000FF0002] Writing [....000000......] Thu 09/10/2015 15:54:25 : [25 3 54 1 ] Link 3 : 0FE0 [E203000000FF0003] Writing [....000000......] Thu 09/10/2015 15:54:26 : [25 3 54 1 ] Link 4 : 0FD8 [E204000000FF0004] Writing [....000000......] Thu 09/10/2015 15:54:26 : [25 3 54 1 ] Link 5 : 0FD0 [E205000000FF0005] Writing [....000000......] Thu 09/10/2015 15:54:27 : [25 3 54 1 ] Link 6 : 0FC8 [E206000000FF0006] Writing [....000000......] Thu 09/10/2015 15:54:28 : [25 3 54 1 ] Link 7 : 0FC0 [E207000000FF0007] Writing [....000000......] Thu 09/10/2015 15:54:29 : [25 3 54 1 ] Link 8 : 0FB8 [E208000000FF0008] Writing [....000000......] Thu 09/10/2015 15:54:29 : [25 3 54 1 ] Link 9 : 0FB0 [A214000000FF1F05] Writing [....000000......] Thu 09/10/2015 15:54:30 : [25 3 54 1 ] Link 10 : 0FA8 [A214000000FF1F03] Writing [....000000......] Thu 09/10/2015 15:54:31 : [25 3 54 1 ] Link 11 : 0FA0 [A214000000FF1F07] Writing [....000000......] Thu 09/10/2015 16:06:52 : [ 23 DA 58 1] ST 255 Thu 09/10/2015 16:07:02 : [ 23 DA 58 1] ST 0 The URTS II device is communication via powerline...
  11. I received my new PLM today. Things are (almost) back to normal. I have an URTII device which communicates with my Somfy window shades which has the "1011" code displayed. I tried ensuring the device was in the program mode, right clicked/ Write pending updates. It appears the device is being written to, but the ISY still can't communicate with it. Any ideas? Btw, it also appears I have a dead relay on my garage door as well... "!" is displayed next to that device. Am I correct?
  12. Bummer. Ok, thank you.
  13. PLM shows "not connected". Is that the same as safe mode?
  14. Even with a green LED on the PLM?
  15. I apparently had a power event during an absence and my 994 hasn't worked since. PLM seems ok, with a green LED, and ISY seems ok with power and Rx blue lights. Firmware is 4.2.30 (latest). The admin console shows my installed Insteon devices. I am unable to control or read the status of the devices. I cannot read status of PLM; get error message that says "cannot connect" in various forms. Tried to restore PLM; error message "failed reset PLM, -200000/-30" and "could not open config file, [/config/insteng.opt]". There is no programming showing in the admin console under "programs". I am unable to restore a backup of my programming either. I'm at a loss how to proceed from here. What's wrong? Any ideas?
