seattlestexan
Everything posted by seattlestexan
  1. Well, that doesn't help when I can't make v5 UI work. As I said in the post before yours, I've been on two computers today trying to get one of them or the other to run v5, with no luck. But since this sounds like a "call tech support or get lost"... Have a nice evening.
  2. Okay, so I've been screwing around with trying to make the v5 UI work, to no avail. I've done the Java thing, IcedTea, two different computers, one of which is less than a year old. v5 will not load past the ISY finder screen on either computer. I also decided to try adding a couple of new GE smart plugs. Whether I try and add them as secure or not, they get found, show up in console, with an error that says "Not Implemented". I was also able to get the Inovelli switch to include, and it showed the dimmer, 3 buttons, and the power usage. The only thing that worked was the power usage, the buttons and dimmer gave me the "Not Implemented". I'm beginning to suspect it may be an issue with my ISY at this point. I have a bunch of Insteon devices that work just fine, it's just trying to add anything ZWave or use UI v5 that I can't do. Have there been any bugs with the ISY hardware or the included firmware?
  3. Apparently I have to be some corporate user to DL an older Java. RPMs or Tarballs, clicking download sends me to an Oracle login or create account screen, which then wants as much info as they can get.
  4. Wow... I just remembered I've not hear the name RedHat in years. lol I've spent entirely too much time in front of a bright square thing. Is there a safe place to download 1.8 that doesn't require me to set up an account I'm never going to use again?
  5. -xmx512m or something like that. I read that earlier. Could there be something like that for IcedTea that I missed?
  6. I think it's all Ubuntu at this point. ?
  7. It says I need the v5 UI, which puts me back to the UI fails to load after I select Admin Console. I feel like I'm chasing my tail on this whole UI/FW issue. Give me a minute to put my head through a wall.?
  8. Normally mine gives something to automatically do the upgrade under the help menu in the AC, but I don't have that currently. Only option I have is manually upgrade. Is 5.3.0 stable for the i/zw+/irpro?
  9. When did that change? I've always gotten a little "upgrade available" on the top of my admin console home screen.
  10. Ahhhhhh okay, that makes more sense. Is 5.0.16 the latest stable, or has there been an update for the 994i ZW+ IR/Pro that I've not gotten the pop up about?
  11. Which ISY do you have? I've not been notified about 5.3.0 on my ISY994i ZW+ IR/Pro. Are you managing in Linux under a VM or in browser? Also, is your 5.3.0 beta or final?
  12. I'm waiting for another FW/UI update from UD before I try updating the ISY's Admin Console UI again, due to having a butt load of issues last time. I also wasn't sure if Inovelli had a firmware update for the switch, if that's a thing. The date code sticker on my switch is 0720. It's a Red series with the RGB indicator and no neutral required. (I really like the options with this, if I could just get the silly thing working.)
  13. 1: I got that part, was just hoping someone had made some progress or something had been figured out for further troubleshooting. 2: I'll get the ZWave stick and get the software, assuming it can run on Win7. 3: I've never been able to make the official JRE work in Linux Mint (ubuntu), and IcedTea has always been great at letting me access the Admin Console UI from Linux. The last time I tried to run Oracle's JRE, I was blocked with a security warning, but I don't remember what it said, as that was several months ago when I was trying to fix the UI issue. A1: This is how it seems to want to be added. I can at least get it to recognize the switch when I try and securely include, but if I turn off secure ZWave in the admin console and try to add the switch, Console throws a fit. I: Can you clarify the support statement? ISY doesn't support v 5.0.16? That's what my ISY shipped with. The only secure zwave I can disable is ZWave>ZWSecureDevices>Don't allow secure devices. I've tried that, and was hit with another error about "not securely added" the Inovelli goes red indicating inclusion failed, and it never shows up in the devices on admin console.
  14. I'd love to, but I've never gotten v5 to work. V4 works just fine, and lets me do everything I need to do. I've already spent too much time on the UI thing, now I just want to get the Inovelli switch to work, as that's the only issue I have with my ISY right now.
  15. It's a ZWave/Inovelli to ISY issue, not an Admin Console issue. I've never been able to get V5 UI to work. I spent a couple hours a day for a couple months trying to TS UI v5, then said screw it, resumed working with v4, and it's been great, until I got this Inovelli, and have been futzing with it for a few months.
  16. @lilyoyo1 @dbuss Do you have a solution that doesn't involve my version difference? I've already tried the troubleshooting listed here, plus other tips I've found, to no avail. Until there is a firmware and UI update, I'm not dealing with the UI issue further. Everything in the v.4 admin console works perfectly fine, and the only issue I'm having currently is the one that started this forum thread - my Inovelli switch fails to securely include to my ISY's ZWave network.
  17. Hello, Has there been any progress made on this issue? I was given an Inovelli Red switch as a gift, and my ISY994i ZW+ IR PRO first had issues even seeing the switch, but once I discovered the range was the issue, now I get a persistent failure to securely add the device when I attempt to include it. Oddly, it has no issues excluding the switch after I've received the error. Moving the switch to a closer and neutral friendly box has not helped the issue. Is this something that can be corrected in software/firmware? Is this something that a Polisy Pro could work around? Not sure if this makes a difference, but under Linux (using IcedTEA) and Windows 7, I've been unable to get the latest admin console to work on 3 different computers, plus one borrowed Windows 10 laptop, so I've been using the previous version. The finder box loads, I can select Admin Console, there's a pause, but the console never loads. Firmware- Insteon_UD994_OADR v.5.0.16 (2020-01-25-12:36:41) UI- Insteon_UD994 v.4.6.2 (2017-06-21-13:52:47) Product- ISY994i/IR-PRO (1110) - OpenADR (21010) - Z-Wave (21100)
