usadventure
Everything posted by usadventure
  1. Thanks, the reset worked!
  2. Hello All, I am having a challenge with setting up a button on a KPL to control a single light. In my dining room, I simply want to press button A to turn on and off an upstairs light, called Loft. The below programming works, except when I press it the dinning room main light and the loft turns on and another press turns both of them off. How can I control the Loft without affecting the dinning room light? Below is how I programmed this: KPL with he following names setup in the ISY network: DiningRoomKeyboard DiningRoomKeyboard -A DiningRoomKeyboard -B DiningRoomKeyboard -C DiningRoomKeyboard -D All buttons are set to Toggle Created a scene called Loft KPL Button A The controller is DiningRoomKeyboard -A The responder is a switch called Loft, which controls a light in my loft area. Created a program called Dining KPL A: If Control 'DiningRoomKeyboard - A' is switched On Or Control 'DiningRoomKeyboard - A' is switched Fast On Then In Scene 'Loft KPL Button A' Set 'Loft' 80% (On Level) Else - No Actions - (To add one, press 'Action') Thank you for your help.
