Sidetrack_CA
Everything posted by Sidetrack_CA
  1. Thanks Tuchman. Do you happen to know if anyone has found a place to get PLMs? Thanks, Rob
  2. Can I use this as a PLM replacement? If so, how would I connect it to an ISY 994i? Any help would be greatly appreciated? Thanks, Rob
  3. I am embarrassed that I figured this out quickly after I posted. I did not see the option when configuring the ISY to work with the Echo that there was a devices, scened, or Programs tab. If I would have seen the program tab i would have got it quickly. It woks fine now! Thanks for taking the time to read the post!
  4. ** SOLVED ** Hi All, I setup an Autelis controller for my Jandy Pool system and all is working fine after adding the commands to the network resources page. However I am struggling with how to use the network resources. Here is what I want to do. I want use the Amazon Echo to control my pool equipment (waterfall, spa jets, lights, etc..) I configured the network resources and tested each one and no issues. I have also set up a variables page with every piece of connected equipment that the Autelis can talk to. So this is where I am stuck. I know I can control a scene with the Echo. However the scene needs a device to be in the scene to control. I as hoping to setup a program that detected the variable change and would run the corresponding network resource. But I can't figure out how to set the variable without an actual device? Any help pointing me in the right direction would be much appreciated.. Thanks, Rob
