croven
  • Posts
    8
Everything posted by croven
  1. Thanks, that's what I need to know
  2. I use sighthound to record video events on my security cameras. I would like to be able to have sighthound send commands to my isy when it sees people in its video feeds. I could use the program below to turn on lights and such but I wanted to keep track of the events to some degree. although sighthound does a better job than any other cctv software I seen on detecting people, it sill has false positives. most of my cameras have over lapping fields of view. I would like the isy to act only when both cameras indicate that they see a person. this should reduce the false positives to almost zero. I believe I will need to use rules to get this to work correctly. any suggestions? http://forum.universal-devices.com/topic/6828-command-line-interface-to-99i-with-source/
  3. There was one accidentally put on "My Programs Folder". There was one there and I removed it. it seems to have help. thanks both of you for the help. I knew you could add one to folders but didn't think that one could be on the main folder.
  4. firmware is 4.0.5 I rebooted the device twice today
  5. 14.99.8E is the motion sensor 1D.C0.9D should be the light Wed 7/3/2013 10:30:26 PM : [std-Cleanu p ] 14.52.B1-->ISY/PLM Group=1, Max Hops =1, Hops Left=0 Wed 7/3/2013 10:30:26 PM : [iNST-DUP ] Previous message ignored. Wed 7/3/2013 10:31:04 PM : CLI-WBug: Connecting to datafeed.weatherbug.com Wed 7/3/2013 10:31:04 PM : CLI-WBug: Successfully Processed WBug Response Wed 7/3/2013 10:31:04 PM : [MOD 2 2 1 5] -26000.000000 Weather - Temperat ure Rate = -2.6 ï½°F/h Wed 7/3/2013 10:31:04 PM : [MOD 2 2 1 7] 40000.000000 Weather - Humidity Rate = 4 %/h Wed 7/3/2013 10:31:04 PM : [MOD 2 2 1 11] 0.000000 Weather - Wind Speed = 0 mph Wed 7/3/2013 10:31:12 PM : [iNST-SRX ] 02 50 14.99.8E 00.00.01 CB 11 01 LTONRR (01) Wed 7/3/2013 10:31:12 PM : [std-Group ] 14.99.8E-->Group=1, Max Hops=3, Hops Left=2 Wed 7/3/2013 10:31:12 PM : [ 14 99 8E 1] DON 1 Wed 7/3/2013 10:31:12 PM : [ 14 99 8E 1] ST 255 Wed 7/3/2013 10:31:12 PM : [iNST-SRX ] 02 50 14.99.8E 00.00.01 CB 11 01 LTONRR (01) Wed 7/3/2013 10:31:12 PM : [std-Group ] 14.99.8E-->Group=1, Max Hops=3, Hops Left=2 Wed 7/3/2013 10:31:12 PM : [iNST-DUP ] Previous message ignored. Wed 7/3/2013 10:31:12 PM : [iNST-SRX ] 02 50 14.99.8E 1F.23.CC 41 11 01 LTONRR (01) Wed 7/3/2013 10:31:12 PM : [std-Cleanu p ] 14.99.8E-->ISY/PLM Group=1, Max Hops =1, Hops Left=0 Wed 7/3/2013 10:31:12 PM : [iNST-DUP ] Previous message ignored. I also have programs that kick off on the Elk arming that have stopped running recently.
  6. a) yes saved no activity to turn on light c) yes the light comes on d) program is enabled e) seems to be fine. the status is false but I thought that changed when the program ran. its the program highlighted in red called "new program" in the attached jpeg. I had other programs working before and then a few days ago everything stopped. I created the last program to test with. Any way a houselinc or smartlinc would interfere?
  7. I am trying to get the very simple program to work but no success. IF Control 'backdoor-sensor' is switched On Then Set 'Kitchen Door Light' On I can see the motion sensor on commands come through on the events viewer but the light never turns on. Any ideas on what i am doing wrong?
  • Create New...
