harvey00
Everything posted by harvey00
  1. so without a PLM that support 220v/50hz i'm not going to be able to link insteon units to isy? and there is no other way to get it to work..
  2. I have another question from some research i can see that the following http://www.insteon.com/2242-222-insteon-hub.html insteon hub, works for 220v and 50hz, and from the way i can see it plugs into the hub, and power, thus no PLM. My question now, if i were to add a insteon Hub to the setup to communicate to the insteon devices, would i be able to see them in the ISY without the PLM, or is there another way for the Insteon hub and ISY to communicate? my end result is to be able to setup programs etc using the isy, if i need to go through the Insteon hub, so be it. I understand that the current insteon keypad and on/off unit works on 220v and 50hz, thus in theory i could let them communicate, but not being able to see them in ISY just makes it an expensive switch..
  3. thanks;(
  4. here is the extremely strange thing, cause im running at 220v/50hz, i used a transformer to reduce the 220v to 120v. but with the transformer on the line x10 does not work.. when i remove the transformer (in theory the Insteon link should burn out- right), x10 works perfectly, through the Insteon link. would it be possible to bypass the over powerline coms completely and only use RF? and how would i link that to the ISY994i?
  5. 220v, 50hz The strange thing is that it works perfectly with my x10 setup.
  6. Events viewer: Thu 07/04/2013 20:51:30 : [1F FE AC ] Added to list of devices to link to ISY Thu 07/04/2013 20:51:30 : [iNST-TX-I1 ] 02 62 1F FE AC 0F 0D 00 Thu 07/04/2013 20:51:30 : [iNST-ACK ] 02 62 1F.FE.AC 0F 0D 00 06 (00) Thu 07/04/2013 20:51:39 : [iNST-TX-I1 ] 02 62 1F FE AC 0F 0D 00 Thu 07/04/2013 20:51:48 : [iNST-TX-I1 ] 02 62 1F FE AC 0F 0D 00 Thu 07/04/2013 20:51:48 : [iNST-ACK ] 02 62 1F.FE.AC 0F 0D 00 06 (00) Thu 07/04/2013 20:51:50 : [iNST-SRX ] 02 50 1F.FE.AC 22.7F.7A A3 0D FF (FF) Thu 07/04/2013 20:51:50 : [std-Direct Nack] 1F.FE.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Thu 07/04/2013 20:51:50 : [iNST-TX-I2CS] 02 62 1F FE AC 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 Thu 07/04/2013 20:51:59 : [iNST-TX-I2CS] 02 62 1F FE AC 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 Thu 07/04/2013 20:51:59 : [iNST-ACK ] 02 62 1F.1F.01 00 00 00 00 (00) Thu 07/04/2013 20:52:08 : [iNST-TX-I2CS] 02 62 1F FE AC 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 Thu 07/04/2013 20:52:08 : [iNST-ACK ] 02 62 1F.FE.AC 1F 09 00 00 00 00 00 00 00 00 00 00 F6 F6 00 00 00 06 LNK-ON (00) Thu 07/04/2013 20:52:09 : [iNST-SRX ] 02 50 1F.FE.AC 22.7F.7A A3 09 FD LNK-ON (FD) Thu 07/04/2013 20:52:09 : [std-Direct Nack] 1F.FE.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Thu 07/04/2013 20:52:09 : [iNST-DUP ] Previous message ignored. Thu 07/04/2013 20:52:13 : [1F FE AC 0 ] Failed to add device, reason 3 Thu 07/04/2013 20:52:13 : [All ] Writing 0 bytes to devices
  7. Thanks, i'm on a 220V and the 2443-222 micro module on/off device can support that. I had a look under PLM info status, and it is connected. my other X10 devices work fine with the system, so it seems to be working, by the new insteon devices does not want to.. any ideas?
  8. Hi, i'm trying to add a insteon 2443-222 micro module on/off device. the first error i got was: "cant determine Insteon Engine" then went to the Event viewer: Thu 07/04/2013 19:18:39 : [1F F9 B1 ] Added to list of devices to link to ISY Thu 07/04/2013 19:19:00 : [1F F9 B1 0 ] Failed to add device, reason 3 Thu 07/04/2013 19:19:00 : [All ] Writing 0 bytes to devices Please assist, dont know what i'm doing wrong..
