baabm
  1. I restarted my modem and my router, then I rebooted my EISY and am still getting the same issue with synchronization. It gets a little past "programs", then bombs out with a message that disappears so quickly, I cannot read it. Then I noticed that my caseta devices weren't working using UDM, so I opened the PG3 server and Admin Console on my mac. I got at least one instance of the socket error on AC while trying to figure out what was happening. I then reloaded the caseta plugin and it started working. I retried the sync and it still didn't work. Any ideas?
  2. - Fixed warning for upgrade to 14.x <br/> ************ IoX ************ isy-6.0.3_3 Name : isy Version : 6.0.3_3 Installed on : Sat Dec 13 08:30:25 2025 EST Origin : misc/isy Architecture : FreeBSD:14:amd64 Prefix : /usr/local Categories : misc Licenses : Maintainer : michel@universal-devices.com WWW : UNKNOWN Comment : ISY Port to X (IoX) Sh
  3. I just finishing upgrading and am also receiving the socket timeout error. The upgrade seemed to complete correctly, but after the reboot, I had trouble restarting PG3, but eventually got it to start. In addition, when I use the UDM interface on my iphone, when I try to synchronize to the EISY, it starts, gets to the programs step, starts the next phase and stops. It never gets to the end where it displays the number of unused items, where it asks if you want to backup and then delete them. So I am not sure if that functionality has changed or if its not working.
  4. I think my issue resolved itself...I found that I had stored 2 different instances of my.isy.io in my password manager - each with a different password. I was able to log in to the Admin console using one of them... My question now is ' Should I still be using Admin Console or is there something else that I should be using?" thanks
  5. After what I think was a successful update to 6.0 (I am able to see the status and control devices via the mobile app on my phone.) But I was only able to log into the admin console using my portal ID and password one time (but it didn't show me any of my devices or programs). So I rebooted the EISY, am still able to see and control devices on my phone, but still can't log in to the admin console - I get the same error as AKAPADIA and polo2883 above.
  6. baabm replied to baabm's topic in LiFX
    I finally figured out how to add my LIFX Z-strips nd bulbs to the plugin, but now am having trouble controlling them with a program. As a simple example, the LIFX API says that brightness is a (decimal) number from 0.0 to 0.9, and color (hue) is an integer between 0 and 360. but the program allows entries of 0-32767 for brightness and 0-32767 for color. Michel says that the interface is designed to only show acceptable values, but I don't understand how 0-32767 maps too either 0.0-0.9 or 0 to 360. Any help would be appreciated. thanks
  7. I cannot find any information on how to use the LIFX plugin. I am currently controlling my LIFX lights using the old networking resources, but would like to use the plugin. I only have a few LIFX lights but can't see how to add them to the plug in. Any help would be appreciated. Thanks
  8. I’m using about a half dozen notifications through the notification node server and they seem to work fine with my iphone. At this point, I’m not sure if there is any value in trying to implement telegram (or even pushover).
  9. Thanks for the response, but if you read further in the post, I managed to remove the telegram service- but I’m not sure how I did it. thanks
  10. I have installed the LIFX node server from the PG3x plugin store. I have it in slot 3. I have tried to follow the instructions in https://lifx-nodeserver.readthedocs.io/en/latest/usage.html#how-to-use but this seems to be focused on downloading from GITHUB and not loading it from the plugin store. I have also read through anything I could find in the forum and I couldn't find anything in the wiki. to Anyway, when I go into POLYGLOT, and look at the LIFX node, it says that it is DISCONNECTED. I can't seem to find any way get it connected. Any help would be appreciated.
  11. Thanks for the explanation re: the multi function button. I never actually use that to cycle the power, I essentially disconnect it from power and reconnect it. This “seemed” to have less impact on the system as using the admin console to reboot. After the power cycle, the EISY simply restarted. But after the reboot, I got a message saying the system has been updated- which seems like more activity to me.
  12. More info: I had cycled power before my initial writeup. I didn't realize that a reboot (from the admin console) is a different animal, so I did that today. It still hangs up in network resources. I don't know when this issue started but I had switched over to EISY a few months ago and set up UDMobile at that time and had done several synchronizations while setting up UDM. I have made a few recent changes to my network resources in order to utilize the notification node server, but I think I saved everything I changed. I'll try to save them all again.
  13. I have an ISY portal account, but cannot find where to open a ticket.
  14. I have been trying to run the synchronization of my UD mobile to the EISY and it starts off OK, syncing a bunch of stuff including programs and "optional", but when it gets to "Getting Network Resource files from ISY", it hangs up and never completes. I tried letting it run overnight last night and it never completed. I'd like to make sure that UDM and the EISY are synchronized before I go on a trip. Thanks, Bob M
  15. After I wrote the note above, I decided to look around at the PG3 page. there I found that I had 3 nodes, so I clicked on it to discover 1 of them was the Telegram node and there was an x icon next to it. I clicked on the x and it started to delete the telegram node. I restarted Admin console and it was gone...
