mikebanes
  1. I am using the ISY99i to help control/display lighting status in the house. For example, if I turn on my kitchen lights, I want my 3 Keypad Linc (2486) C switch to indicate status (on/off). I want to also control the kitchen lights from these locations (button C). I was able to set this up manually, linking the devices. Using a Program, I can get the ISY99i to turn the kitchen lights on/off with button C say using Keypad Link #2, but I cannot figure out how to get the other 2 Keypad Link button C's to indicate current status (on/off as appropriate). So, I am attempting to set up the program such that when I turn button C on/off, the backlight is to change on the corresponding C buttons. However, once the program line is entered, and tested, the backlights do not respond as programmed. For example: IF - Status Master Bedroom Switch 8 / 17.A3.4D.C' is On THEN - Set 'Living Room Switch 8 / 16.E5.90.C' On 15 / Off 7 Backlight Level) As I press the Master Bedroom C button ON, the Master Bedroom button C illuminates, yet the Living Room button C does not. Perhaps I am using this incorrectly?
