mking0310
  1. mking0310 changed their profile photo
  2. I do see that it is the battery operated devices like motion sensors that are showing in the log. I use Insteon, not z-wave and my admin console just got updated yesterday as a test to see if that fixed this issue. Help-About is 4.90 and I've never heard of a pro version. When I make a change on a normal outlet, why would it try to communicate with all the other devices, including the motion sensors ?
  3. Thank you MrBill. When I launched admin console, it immediately went into system busy and the output is shown below. Tue 04/13/2021 08:31:40 AM : [INST-TX-I1 ] 02 62 2A FE EC 0F 0D 00 Tue 04/13/2021 08:31:40 AM : [INST-ACK ] 02 62 2A.FE.EC 0F 0D 00 06 (00) Tue 04/13/2021 08:31:45 AM : [INST-TX-I1 ] 02 62 2B 05 E2 0F 0D 00 Tue 04/13/2021 08:31:45 AM : [INST-ACK ] 02 62 2B.05.E2 0F 0D 00 06 (00) Tue 04/13/2021 08:31:53 AM : [INST-TX-I1 ] 02 62 2B 05 E2 0F 0D 00 Tue 04/13/2021 08:31:53 AM : [INST-ACK ] 02 62 2B.05.E2 0F 0D 00 06 (00) Tue 04/13/2021 08:32:02 AM : [INST-TX-I1 ] 02 62 2B 05 E2 0F 0D 00 Tue 04/13/2021 08:32:02 AM : [INST-ACK ] 02 62 2B.05.E2 0F 0D 00 06 (00) Tue 04/13/2021 08:32:07 AM : [INST-TX-I1 ] 02 62 2D 67 C6 0F 0D 00 Tue 04/13/2021 08:32:07 AM : [INST-ACK ] 02 62 2D.67.C6 0F 0D 00 06 (00) Tue 04/13/2021 08:32:16 AM : [INST-TX-I1 ] 02 62 2D 67 C6 0F 0D 00 Tue 04/13/2021 08:32:16 AM : [INST-ACK ] 02 62 2D.67.C6 0F 0D 00 06 (00)
  4. mking0310 posted a topic in ISY994
    My ISY99 shows "system busy" with a progress bar that moves slowly for a very long time after I make any changes to any device or scene. If I remove a device from a scene, change the name, change the On Level, anything. Once I make a change, First the System busy progress bar moves quickly to 100% but then it starts over and takes forever to complete. Approximately 3-5 minutes. Happens in Isy99 Ver 4.7.5, and issue has persisted after upgrading to 4.9.0
  5. Alexa will either silently fail with no error message or will say "not responding" My ISY99 and Amazon Alexa have been working for 5 years and all of a sudden, voice activated commands via Alexa result in "Cabinet Lights are not responding" and Programs on the ISY do not result in ON or OFF as they correctly did before. and this happens for ALL devices/scenes. I removed the devices on alexa.amazon.com under Smart Home. Then clicked Discover again. Test by using the spoken phrase. but still get error "...not responding" I removed the device from https://my.isy.io/index.htm and re-added it back, then ran Discover on the Alexa.amazon.com... it showed that it was added back but voice commands result in same error. THEN: I've restarted the Wifi Router, ISY and PLM. Then when using voice command with Alexa/Echo, it sounds the chime that indicates the command was sent but no lights turn on.
  6. Xanthros, The additional commands I configured successfully after your help, have all provided the 200 response AND additional response information from the DVR. 1. Is there a way to right programs using the response info? 2. When using the browser to send the GET, I get back more details than what ISY gives me... How do I tell it to show it all. I'm hoping to see the response in ISY to include the "MODE" - then I could say, IF Network Resource is Mode 1, then do XYZ
  7. Xanthros, Thank you so much.. I was skeptical at first, but eager for any suggestion. You rock buddy. I owe you a starbucks next time you're in Sac-town.
  8. I've searched all day for resources on creating a network resource to sent a command to the DirecTV. I can successfully send the command using Safari - Receive Response 200 and the channel changes. Therefore I'm using the right IP address. I've successfully added other network resources therefore I am saving it correctly. Previously added my audio receiver Denon, by using TCP, by following online threads, and even tried using TCP for the Directv but failed. Error Messages in ISY are - Request Failed and Fri 2014/10/03 12:32:13 PM System -170001 [TCP-Conn] -1/-140002, Net Module Rule: 10 I'm hoping someone can explain what I'm doing wrong, or tell me why I can send the command in Safari but not ISY. The URL is http://192.168.150.31:8080/tv/tune?major=3&minor=65535
  9. I have tried my own gmail account as well as the test account isyalerts@gmail.com and I keep getting the error message "Mail Server Failure" [Connection Failed] I'm using Comcast Broadband, and there are no firewall rules or router rules in place. I'm not sure what to look for or where to go next. My recipients list had 3 different groups but I have removed them and added just one email address. *Yes, I saved*
