cherokeesix
  1. Hi, A SwitchLink Relay in the garage, which is the load, turns on front yard lights. A different SwitchLink Relay in the house, which is load, turns on backyard lights. I want to make the SLRelay in the garage also turn on the backyard lights, but only if pressed-on twice. When turning off, it would be neat to be one press off turns off the front, two presses off turns of the back. These are SwitchLink Relays (non-dimming) and I'm not sure of what to look for in the programming. Is it ON, FAST ON ...? I have experimented by making a Front Yard On folder and a Front Yard Off folder. Programs inside these folders would take appropriate action based upon the status of Front Yard. For example: If Folder Front Yard On = True and Switch is Pressed On then set scene back yard ON. Am I going about this the best way? Thanks
  2. Thanks for the help. Would I be able to see the traffic in the event viewer if it was X10 causing the strange behavior?
  3. I have a KPL button D linked with a Switchlink relay. Both are set as controllers. That part works fine. The weird part is when I press the KPL D button ON, some lights controlled with ICON switches (4 way lighting arrangement), also turn on. I removed the scenes with the ICONS and the KPL D button and restored the switches, then remade the scenes. Still get the strange behavior. The ICONS do not indicate being ON, and the ISY99 does not show them or the scene they are in as being ON. I worked around it by writing a small program that says "when button D is turned on then turn the ICON switches off". That fixed the problem, but it is not the solution. Do I have bad ICON or KPL switches? Thanks
