mxflash
  1. Is there a tutorial somewhere on LED brightness? For me, 0 is brighter than 1, but 2 is also brighter than one. So that's not intuitive. Much thanks. P.S. The restore devices and restore the PLM was awesome. Now I can do all sorts of trick stuff. Thanks.
  2. After the restore, it still has the same list (which I assume represents the ten devices), but now succeeds. So that seems good. Thanks for the tip. Sun 08/25/2013 01:20:36 PM : [GRP-RX ] 02 61 1E 13 00 06 Sun 08/25/2013 01:20:37 PM : [iNST-SRX ] 02 50 22.F9.35 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:20:37 PM : [iNST-SRX ] 02 50 22.51.A9 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:20:37 PM : [iNST-SRX ] 02 50 22.5D.88 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:20:37 PM : [iNST-SRX ] 02 50 23.FA.3F 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:20:38 PM : [iNST-SRX ] 02 50 23.ED.E9 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:20:38 PM : [iNST-SRX ] 02 50 22.58.1C 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:20:38 PM : [iNST-SRX ] 02 50 22.64.6B 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:20:38 PM : [iNST-SRX ] 02 50 22.60.74 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:20:38 PM : [iNST-SRX ] 02 50 23.F0.66 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:20:39 PM : [iNST-SRX ] 02 50 21.69.7E 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:20:39 PM : [CLEAN-UP-RPT] 02 58 06 Sun 08/25/2013 01:20:39 PM : [iNST-SRX ] 02 50 22.95.84 23.98.F7 61 13 1E LTOFFRR(1E) Sun 08/25/2013 01:20:39 PM : [std-Cleanup Ack] 22.95.84-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 ----- Set Kit 8 E On Test Results ----- [succeeded] Kitchen 8-Button E (22 95 84 5) ----- Set Kit 8 E On Test Results ----- Sun 08/25/2013 01:20:44 PM : [iNST-TX-I1 ] 02 62 00 00 1E CF 13 00 Sun 08/25/2013 01:20:44 PM : [iNST-ACK ] 02 62 00.00.1E CF 13 00 06 LTOFFRR(00)
  3. I deleted the keypad from the ISY. I deleted all the scenes and programs that it was in. Then I reset it and recreated all the scenes and programs. I will try a restore device and see if that helps. Thanks.
  4. Okay, please forgive me if I'm not posting this right. Here's what I get. The "failed" seems problematic. Sun 08/25/2013 01:00:48 PM : [GRP-RX ] 02 61 1E 13 00 06 Sun 08/25/2013 01:00:48 PM : [iNST-SRX ] 02 50 22.F9.35 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:48 PM : [iNST-SRX ] 02 50 22.F9.35 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:48 PM : [iNST-SRX ] 02 50 22.F9.35 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:48 PM : [iNST-SRX ] 02 50 22.51.A9 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:48 PM : [iNST-SRX ] 02 50 22.51.A9 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:48 PM : [iNST-SRX ] 02 50 22.51.A9 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:49 PM : [iNST-SRX ] 02 50 22.5D.88 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:49 PM : [iNST-SRX ] 02 50 23.FA.3F 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:49 PM : [iNST-SRX ] 02 50 23.ED.E9 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:49 PM : [iNST-SRX ] 02 50 22.58.1C 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:50 PM : [iNST-SRX ] 02 50 22.64.6B 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:50 PM : [iNST-SRX ] 02 50 22.60.74 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:50 PM : [iNST-SRX ] 02 50 23.F0.66 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:50 PM : [iNST-SRX ] 02 50 21.69.7E 23.98.F7 E1 13 FF LTOFFRR(FF) Sun 08/25/2013 01:00:51 PM : [CLEAN-UP-RPT] 02 58 06 Sun 08/25/2013 01:00:51 PM : [iNST-SRX ] 02 50 22.95.84 23.98.F7 E1 13 FF LTOFFRR(FF) ----- Set Kit 8 E On Test Results ----- [Failed] Kitchen 8-Button E (22 95 84 5) ----- Set Kit 8 E On Test Results ----- Sun 08/25/2013 01:00:56 PM : [iNST-ACK ] 02 62 00.00.1E CF 13 00 06 LTOFFRR(00)
  5. So even when I manually (i.e. from the ISY) turn on or off the scene that just consists of the KPL button as a responder, the KPL button's status does not change. Is that normal? It has persisted through a factory reset, so I assume it is. Though if the scene won't change the status of the button, I'm not sure I follow how the program works. Unless a program acting to activate a scene is different from highlighting the scene in ISY and clicking "on" or "off". It must be, I suppose. I will try the delay and see how that works.
  6. Okay, only the A button on that 8-button KPL seems to respond appropriately to commands from the ISY. The rest it is not seeing properly (i.e. I can't directly control them from the ISY). I've tried a factory reset, but that didn't work.
  7. If ( Control Kitchen 8-Button E is switched On or Control Kitchen 8-Button E is switched Off ) And Status 'Family Room / Family Room Fan-Motor' is Low Then Set Scene 'Set KPLs / Set Kit 8 E On' Off Set 'Family Room / Family Room Fan-Motor' Off Else no action. Set Kit 8 E On just has one responder, the E button on the KPL. Program works fine. It thinks it's turning the Set Kit 8 E On scene to off, and it thinks the button turns off. But the button stays on. For some reason on that KPL, the scenes do not activate and inactivate the button LEDs.
  8. It seems for some reason that my IPY cannot turn the KPL buttons on or off on that KPL. Not sure what's wrong, already factory reset the KPL...
  9. I thought that would work but alas. Should the KPL button be set to toggle, on or off, do you think? Thanks much.
  10. Hi all, New ISY/Insteon user here and I'm a bit stumped. Any assistance would be appreciated. I have an 8 button KPL and a FanLinc, programmed through an ISY. I have a button on the KPL (E) set to toggle through the fan modes. If the fan is off and I hit E it goes to high, if the fan is on high it goes to medium, medium to low, low to off. All is working well, but I'd like the KPL button to be lit when the fan is on, and off when the fan is off. Is there any way to do this? Any suggestions would be appreciated. Thanks in advance.
