Hophead
  1. I would love to see this developed as well. I just had a Mitsu 4 zone minispilt heatpump intsalled. It uses the Honeywell Focus Pro thermostats with Redlink. I would love to be able control the thermostats through the ISY and mobilinc app.
  2. You are correct. Both of those things work. I was able to test the smoke alarm with some smoke and get a Mobilinc notification and an e-mail so everything appears to be working. Thanks!
  3. Thanks Lee! I should have known to look at the FW. I go through this with customers at work using our servo drives. I thought I have upgraded before when I got the ISY back in April. I was at 3.xx for the ISY. I loaded the FW and have v4.0.5 for the ISY and v4.0.11 for the UI. I get all 7 nodes and I have the same results as junkycosmos. When I do a test, I see traffic in the event viewer and the test node shows an ON state but never goes to OFF. None of the other nodes have a value for current state. Is this normal?
  4. OK, so I'm not having any luck getting communication from the smoke bridge to the ISY. I've got one smoke alarm and one smoke bridge. I can ge the bridge to link to the alarm. I know its linked because the LED flashes red on the bridge when I test the alarm. When I add the device to the ISY it seems to add ok and I get 3 nodes (smoke, CO, & battery), but none of them show their state. I also don't see any traffic in the event viewer when I test the alarm (although I do see traffic for the bridge when I add the device). I've tried resetting the bridge back to factory defaults and I've tried adding the bridge through "start linking" and "new insteon device" but I'm not having any luck. Anyone have any other ideas? Thanks.
