Dotto
  1. LeeG, Thanks for your reply! You gave me a good idea, but I can´t set ramp rate because this option isn´t avaliable at isy994i for switchlinc on/off. I have only one choice that is change my switchlinc for KPL or add more one InLineLinc as you suggested me. Thanks again, Fabio Dotto.
  2. I´m beginner of isy994i and I need some help because I don´t know if I want is possible. Sorry for my english... I have two switchlink on/off 2477S and I would like to turn on the light 02 only when I pressed (dual click) the switchlinc button of the module 01. When I pressed (up) the first time, the light 01 turn on and if I press (up) again the light 02 turn on too. I would like to wait the double click before decide if I need to turn on the light 01 or not. Details of my system: - light 01 - wired in switchlinc 01 (2477S) - light 02 - wired in switchlinc 02 (2477S) a) one click (up) on the switchlinc 01 - turn on the light 01 double click (up) on the switchlinc 01 - turn on the light 02 - the light 01 is preserved as your original state (doesn´t change your state) c) one click (down) on the switchlinc 01 - turn off the light 01 d) double click (down) of switchlinc 01 - turn off the light 02 - the light 01 is preserved as your original state (doesn´t change your state) My program: --- double click off --- If $count is -2 Then $count = 0 Set 'Light 2' Off Set 'Light 2' 250 (Beep Duration) Set 'Light 1' 100% (Backlight Level) Else Wait 3 seconds Set 'Light 1' 100% (Backlight Level) $count = 0 --- double click on --- If $count is 2 Then $count = 0 Set 'Light 2' On Set 'Light 2' 250 (Beep Duration) Set 'Light 1' 100% (Backlight Level) Else Wait 3 seconds Set 'Light 1' 100% (Backlight Level) $count = 0 ---Light 02 off--- If Control 'Light 1' is switched Off Then $count -= 1 Set 'Light 1' 0% (Backlight Level) Run Program 'double click off' (If) Else - No Actions - (To add one, press 'Action') ---Light 02 on --- If Control 'Light 1' is switched On Then $count += 1 Set 'Light 1' 0% (Backlight Level) Run Program 'double click on' (If) Else - No Actions - (To add one, press 'Action') Thanks, Fabio
