algod
  1. algod replied to algod's topic in ISY994
    Thanks Teken. With my heart in my throat I downloaded the 4.4.6 console and was able to run the 4.5.4 update, then downloaded the 4.5.4 consol. Gotta love this forum. Thanks again. Al
  2. algod posted a topic in ISY994
    ooops I went to upgrade to 4.5.4 and deleted my java cache, Now can't into the console. Where do I go from here. thanks, Al
  3. Found it! TLS 1.0 is the default. Mobilinc is working again in IOS 9.
  4. Does 4.2.30 set TLS 1.0 automatically, or do I have to select it. I went to network setting in configuration, but cannot find a place to change my security setting? Al
  5. Thanks Paul. It worked like a charm. Al
  6. Thanks for the quick reply. I'll give that a shot. Al
  7. I use Mobilinc with my Iphone and need to go to to 4.2.30 so I can upgrade my network security. Knowing just enough to be dangerous, and wanting to have a good install, I decided to clear my Java cache. You guessed it. I blew away my ISY desktop icon. Where do I go from here? Any help would be appreciated. Al
  8. algod replied to algod's topic in ISY994
    Hi Brian, I'm not going to use x10 signaling. I'll install an Insteon micro on/off switch on the line. I'll control power with a program in the ISY. My wife works nights, so I'll power up the lights sensor an hour before she is due home. That way I don't light up the neighborhood every time a car drives by the house. Al
  9. algod replied to algod's topic in ISY994
    Thanks for the advice. Al
  10. algod posted a topic in ISY994
    What flood lights are folks having success with? The more I reed about my old PR511, the less comfortable I feel about installing it and linking to my ISY. Too many false reads from the motion sensor. From what I've read, I'll keep away from dual bright. Is halogen acceptable? Thanks, Al
  11. algod replied to algod's topic in ISY994
    They sense that it is dead and are sending a replacement. thanks for the replies. Al
  12. algod replied to algod's topic in ISY994
    It's a 60wt incandescent bulb. I've plugged a dual band on/off module beside the switch, which I've air gapped again. I've attempted a restore from the ISY. The switchlinc still displays a red exclamation mark beside it, and I still don't have any leds on the left side of the switch. Al
  13. Came home today, and my wife said she couldn't turn off the light (incandescent). Sure enough the switchlinc's led was to the top and the load light was full on. Pressing the on/off paddle did nothing. My ISYs icon displayed 1011 no commo. I air gapped the switch. The ISY now displays a red exclamation mark beside the switch. The switch now functions as a mechanical switch, in that it turns on and off, however the leds on the side of the switch do not display at all. They do not run up and down the switch to indicate light level. If I press the linking button I do get a green and one white led to display, but the ISY still cannot find the switch. This is my second 2474 that has lasted about a month. Is it dead, or can I get it linked to my ISY? Thanks, Al
  14. algod replied to algod's topic in ISY994
    Thanks Adam. That was quick and easy. I couldn't tell you how long I was trying to find a fix in the wiki this morning. Al
  15. algod posted a topic in ISY994
    The last time I logged into my console I received a dialog box that said my shortcut was ........... Behind this I saw my login screen, so I acknowledged the dialog box, logged in and did what I needed to do. Today my desk top shortcut is missing. How can I recover my console? Can't seem to find anything in the wiki. Win 7 ISY994 Thanks, Al
