tcaywilson
  1. Thanks! I've been trying to get time to work on this again, but haven't had the chance. I'll try your solution to see if that works for me as well as doing some debugging as previously recommended to see if I have any communication issues.
  2. Hi Xathros, Thanks for the reply. No I'm not using Trigger Reverse. I remember trying that previously when I was trying to get the garage controls to work and that it caused problems. I had gotten one of the buttons on our KPL's to show when the garage door was open. That was working for awhile, but then started showing the garage open when it wasn't intermittently. It started happening enough that I wrote a little program to check the garage door and reset the light if it was actually closed. I don't think anything had changed with our system as I hadn't had time to work on it. I'm trying to find time to get back to working on getting the ISY doing something useful, but it's frustrating when it doesn't work the way it's supposed to... Besides buying new hardware, any other suggestions? Thanks, Tammy
  3. Hi Jim, Thanks for getting back to me. I was wondering if the Resource was related to Push. Haven't set that up yet, but will if we get some things work well enough to make it worthwhile. I'm having an issue. Don't know if you can help me troubleshoot it or not. My Garage Sensor doesn't seem to consistently show the proper state. Sometimes it is off when the door is closed and other times it is on when it's closed and then the same with when it's open. Any idea what might be wrong with my setup? The relay is momentary B. What else should I check? Really hoping I can get this working. Thanks,
  4. Thanks very much for posting your code! I've wanted to get something like this working when we got the system, but never had time to get it working correctly. I have it partially working now. The button press or MobilLinc will open and close the door and the button flashes. The button on/off doesn't seem to be correct yet, but that may be how our hardware is set up. I have a few questions (probably more once I resolve these and do more testing). On the Failed state's you have a Resource in the code. I don't see that as an option. It's also too general a word so searching hasn't showed anything that seems to apply yet. Can you tell me what a Resource is and how I can set it up? On the code you later posted to fix the power failure option, I'm a little confused--does this replace one of the existing programs or is it a new program? Do I change the variables initial value to -1 under the Variables tab as well? Thanks for any help you can provide and for posting the code! Tammy
