flazar
Everything posted by flazar
  1. Hi, I have a mini-remote (2342-2), and am trying to get it to control a dimmer (2477S), and a socket (2472D). The dimmer currently powers a light, and has the socket configured as a responder as well. The desired end result is two lights turn on) as a scene, which works fine if pushing the dimmer switch. I would like to have the mini-remote turn on this scene with one button as well. At first I made the remote a controller for the dimmer. This had the effect of turning on only on light that directly attached to the 2477S, but not also the socket. I then set up a program that said "If status living room dimmer" is on, set living room socket to on. I removed the scene which had the dimmer be a controller for the socket. I then tested that the program works by simply pushing the wall switch (2477S), confirming that the program executed, and seeing both lights turn on. When I tried turning on the dimmer (2477S) via the mini-remote, it still only turns on the dimmer itself, but not the socket. Basically it looks like the program completely ignores the status of the dimmer when it's activated via a remote. I'm pretty confused at this point - how can I make the program work correctly so that turning pushing the button on the remote result has the desired result? I tried all possible conditions in the program to see if making more generic would help (If switch turned on or switch turned fast on or switch status status = on, and still no dice. Filip Filip
