paob
Everything posted by paob
  1. Hi all any idea when the firmware supporting this sensor will be available?
  2. I spoke with Insteon and was very disappointed with their response on the sensor working with ISY. The Insteon folks are aware of the issue but they offer no solution. I like the ISY product and the integration with Alexa but being dependant on Insteon PLM's as a single point of failure and now the seeming clueless-ness of the Insteon team as to how/when their newest sensor will work with ISY is not a good thing.
  3. paob posted a topic in ISY994
    Hi all I love my ISY.... Have a bunch of insteon devices on my network.... principally set to work by time of day etc..... Now I'm ready to try a new thing... I have a driveway sensor (Dakota Alert WR 3000) and I have an Insteon I/O linc 2450... I also have a Wifi webcam that looks at my driveway... It can be set to sense motion and record... Here's what I want to try I want to set up a condition that "if" motion is sensed by the Dakota Alert.... "And" it is from sunset till sunrise "then" my outside floodlights should turn on for 5 minutes I also want to set up a condition that "if" motion is sensed by the Dakota Alert... "And" it is not from sunset till sunrise "then" my outside floodlights stay off Finally, for both of the above scenarios I want my Wifi Camera to begin recording for 5 minutes once the Dakota Alert senses motion... Can this be done? Thanks in advance Paul
  4. paob replied to paob's topic in ISY994
    it is connected to port a
  5. paob replied to paob's topic in ISY994
    Hi same side of bus means that in a 220 home wiring plan there are 2- 110 v buses... sometimes a bridge is needed to send powerline signals across the bus...in my case everything is on the same bus. The PLM is directly connected to the ISY by a cat 5e cable
  6. paob replied to paob's topic in ISY994
    yes I have standard power. yes everthing is on the same side of the bus yes I have checked the pinouts Thanks
  7. paob replied to paob's topic in ISY994
    ps...I have also tried factory reset of the PLM but it does not reset.....I tried this several times
  8. paob replied to paob's topic in ISY994
    Again thanks for your guidance I have tried new Cat 5e cords...no luck Yes the PLM is lit and it is a 2413s I tried all of this last week with Tech support...I've reestablished a help request. I hope this is an isolated situation. Thank you again Paul
  9. paob replied to paob's topic in ISY994
    Thanks for the guidance I powered the PLM and connected it to the ISY Then I powered the ISY both led's on the back of the ISY lit... One was solid, the other was blinking The front of the ISY had both the Power and RX lights lit When I tried to launch the console I got the message "safe mode"The software can't find the PLM.
  10. paob posted a topic in ISY994
    I am new to the ISY product. I purchased an ISY994i and a PLM In stand alone mode (no PLM attached) the ISY can be found and it tells me that it cant locate the PLM....Good! If I connect the PLM and retry...I still get the message that the PLM can't be found (Power and RX LED are on) If I reboot the ISY and PLM (with the PLM attached) the Power LED AND the Mem LED lights go on...RX LED goes off.....When I launch the software I get a message that the ISY can't be found.. Have worked with Tech support...They suggested I get a new PLM...So I did Installed new PLM...same issues... Please help...This is very frustrating
