jneves
  1. I had the same issue with new dual band KPL. I updated the ISY firmware then deleted and re linked the KPLs, now all buttons appeared. Hope it works for you.
  2. I am new to the board and to the ISY. I had this particular KPL manually programmed to run a Fanlinc on low, med, and high speeds. When I installed the ISY I removed all old links and started my setup from scratch. I used a scene setup using 3 scenes, 1 for each speed. When I turn the scene on and off on the ISY each speed works fine and turns off the previous speed setting. When I use the KPL to activate the scene it always turns the fan speed to high. ISY shows high as well although the scene is set to execute a med or low speed command. Any ideas way this is happening? I have a similar issue with a KPL scene that turns on all my kitchen and family room lights. I am using the main button to turn on all lights, the light directly connected to the main is set to turn on at 0% or fully dimmed. When I execute the scene on the ISY it works fine. When I execute it on the KPL is turns the light on 100%????
