pinkfish
  1. Hi there, I did turn off the three way mode, tried all the settings inside the isy itself too. What I want it to do is be on when the sense line is high, and off when the sense line is low. I don't see how to set this up at all? When I use the sense line and touch it to the active line to see if I can trigger it, it turns on the first time I touch active and then off when I touch it again. I don't see how this works with a motion sensor at all without this ability? Thanks, David.
  2. Is there a way to make it turn on when there is power to the device then? Right now it won't seem to work as replacement for a motion sensor if it doesn't turn on when there is power to the sense line. Is there a way to set this up correctly? Thanks David.
  3. I have a micro on/off setup and I cannot seem to get it to not latch. I set it in single momentary mode and it only beeps once when I push the set button. However when I touch the sense wire to the load line it toggles when I apply power. So on first time off second time... It should be on when connected to the load and off when disconnected. Any idea what I am doing wrong? Thanks David.
  4. Did some more rebooting and seems to be working again now
  5. The isy itself still seems to be working, it is updating the lights I just can no longer connect to it via the network. However the lights are turned on correctly on the front, it thinks it is connected to the network... I tried restarting it a couple of times.
  6. I cannot get the isy to show up all when I use the universal devices admin console. It is not appearing or connecting to the device any more. Tried turning it off a few times too, it flashes the lights and seems to connect to the network. It doesn't display an error light, but it also no longer connects to anything from my computer. How do I figure out what is wrong and how do I get it to respond to me again? Thanks, David.
  7. Ok, weird. I turned on the console and now it loads fine Well, solved!
  8. I did have trouble with the dns, but I have that working correctly now. I can connect to the isy just fine, it is also operating fine from what I can tell. The java program for viewing it shows all the devices fine, but the programs tab is completely empty. I assume there is an exception or something when I click on the tab, since it doesn't open and when I click it again it opens up completely blank. The error logs doesn't seem to be showing this... Attached a screenshot of how the app looks. Is there a way to find the java exceptions? I also tried to export the data from the isy to back it up, but I think this made an empty zip file. It goes through all the things saying it is backing stuff up, but the zip file is empty. ISY-Backup.v4.0.5__Tue 2013.10.15 12.04.51.zip
  9. Morning, For some reason the programs menu won't open at all in my isy 994i any more. It gave some weird errors about program indexes not being useful or something when I tried to save a new program before I restarted, then it just won't load anything in the programs section at all any more. Is there something I do so you can get information to debug this? I attached the error log, but it doesn't seem to be logging an error Is there anything I can do? I was starting to get things nicely setup Thanks, David. ISY Error Log.v4.0.5__Tue 2013.10.15 01.12.29.txt
