Canz
Everything posted by Canz
  1. Hello I am considering purchasing one of these and your ability to set or change a code on the go is one of the features I am looking for along with setting an expiration time for the code. Have you had any luck getting this program set up or another way to go about it. I would assume the iOS mobilinc app only gives you the option of Open/Close with it. Thanks. Sent from my iPhone using Tapatalk
  2. That's cool, no rush. Sorry i am just now getting back to you, Wednesday was left out by design because my wife was working from home, but i am having the problems on the other days too.
  3. Xathros, I am hoping you can help me. I have tried your suggestion with my program however i am running into a problem. It was working fine but for some reason it has stopped working correctly on its own. Normally i get it working where the stat watcher is false and then the corresponding daily program starts. from what i can tell the daily program runs until it gets to the daytime shift. 6:30 - 16:30 and then it should lower the temp for when I arrive home from work. However it seams that at 16:30 it doesn't low the temp and the StatWatcher program kicks in and keeps the temp at the previous set temp of 80deg and doesn't resolve until i run the Else path of the StatWatcher. This is the programs, first is the StatWatcher followed by daily programs. Please let me know if you notice anything that could be causing my problem. Thanks again- Matt Spring_Weekday_StatWatcher If ( On Mon, Tue, Wed, Thu, Fri From 12:00:01AM To 5:29:59AM (same day) And ( Status 'Main Thermostat' is not 78° F (Cool Setpoint) Or Status 'Main Thermostat' is not 65° F (Heat Setpoint) ) ) Or ( On Mon, Tue, Wed, Thu, Fri From 5:30:00AM To 6:29:59AM (same day) And ( Status 'Main Thermostat' is not 76° F (Cool Setpoint) Or Status 'Main Thermostat' is not 67° F (Heat Setpoint) ) ) Or ( On Mon, Tue, Wed, Thu, Fri From 6:30:00AM To 4:29:59PM (same day) And ( Status 'Main Thermostat' is not 80° F (Cool Setpoint) Or Status 'Main Thermostat' is not 55° F (Heat Setpoint) ) ) Or ( On Mon, Tue, Wed, Thu, Fri From 4:30:00PM To Sunset - 1 second (same day) And ( Status 'Main Thermostat' is not 75° F (Cool Setpoint) Or Status 'Main Thermostat' is not 64° F (Heat Setpoint) ) ) Or ( On Mon, Tue, Wed, Thu, Fri From Sunset To 11:59:59PM (same day) And ( Status 'Main Thermostat' is not 77° F (Cool Setpoint) Or Status 'Main Thermostat' is not 65° F (Heat Setpoint) ) ) Then Wait 2 hours Run Program 'Spring_Weekday_StatWatcher' (Else Path) Else Run Program 'Spring_Weekday_00-530' (If) Run Program 'Spring_Weekday_0530-630' (If) Run Program 'Spring_Weekday_0630-1630' (If) Run Program 'Spring_Weekday_1630-Sunset' (If) Run Program 'Spring_Weekday_Sunset-2359' (If) Spring_Weekday_00-530 If On Mon, Tue, Thu, Fri From 12:00:00AM To 5:29:59AM (same day) Then Set 'Main Thermostat' 78° F (Cool Setpoint) Set 'Main Thermostat' 65° F (Heat Setpoint) Else - No Actions - (To add one, press 'Action') Spring_Weekday_0530-630 If On Mon, Tue, Thu, Fri From 5:30:00AM To 6:29:59AM (same day) Then Set 'Main Thermostat' 76° F (Cool Setpoint) Set 'Main Thermostat' 67° F (Heat Setpoint) Else - No Actions - (To add one, press 'Action') Spring_Weekday_0630-1630 If On Mon, Tue, Wed, Thu, Fri From 6:30:00AM To 4:29:59PM (same day) Then Set 'Main Thermostat' 80° F (Cool Setpoint) Set 'Main Thermostat' 55° F (Heat Setpoint) Else - No Actions - (To add one, press 'Action') Spring_Weekday_1630-Sunset If On Mon, Tue, Thu, Fri From 4:30:00PM To Sunset - 1 second (same day) Then Set 'Main Thermostat' 75° F (Cool Setpoint) Set 'Main Thermostat' 64° F (Heat Setpoint) Else - No Actions - (To add one, press 'Action') Spring_Weekday_Sunset-2359 If On Mon, Tue, Wed, Thu, Fri From Sunset To 11:59:59PM (same day) Then Set 'Main Thermostat' 77° F (Cool Setpoint) Set 'Main Thermostat' 65° F (Heat Setpoint) Else - No Actions - (To add one, press 'Action')
  4. Thanks Xathros Sent from my iPhone using Tapatalk
  5. I have been using the Honeywell z-wave for about 2 weeks with no problems so far. The only issue I see so far and I could have been missing something is the ability to add it to a scene so that it can be controlled or control insteon devices. Sent from my iPhone using Tapatalk
  6. Xathros, Thank You for the Reply. I will give that a try tonight. But I had 3 questions 1) Can I put all of the timeframes under one StatWatcher Program? 2) I am not understanding the Else section of the Statwatcher Program. Should it blank to create the False condition under the Folder Conditions? And to add the trigger to cause the Programs to run after the Hold would it just be Else Run IF – Program A Run IF – Program B And so on. 3) And just to confirm for those programs to run properly I need to use IF Time is – 5:30AM to 8:00AM (or ) IF Time is – 5:30AM Thanks for all your help, Matt
  7. Hello, I am hoping someone can help me out and give me some ideas. I am using the Z-wave Honeywell thermostat (TH8320ZW) and I have turned the internal Home/Away programing off. I have created some programs to set the cool and heat temp set points such as. ******* If M-F and time is 5:30am Then Stop program – Bedtime Set – Heat Set point to 69 Set – Cool Set point to 74 Else Blank ******** I have additional programs set up that take effect at different times though out the day and then end the program that ran before it. But what I am looking to create is a program, that when someone changes the temperature at the thermostat it will suspend all of the other programs and Hold the new temperature setting for a period of time (2hours) and then picks backup where it left off. Does anyone have any ideas on how to create something like this? Or something that will monitor set point change. Thanks Matt
  8. Ok, Thanks. I will give a try in the next couple days
  9. I also have a slight different problem with my Garage Door Kit, First the Garage Door Goes up and down fine, no problems as described above. However when it closes its status reports "Closed", "Open", "Closed" and then remains with a Closed status until I reopen the door. Any Ideas on how to fine tune this or filter it out with a program so that if I have a program that says something like: If Between Sunset - Sunrise (next day) And Garage Door status is Open Then Set Flood light' On Else Set Flood Light' Off The Flood Light doesn’t turn OFF and then ON then OFF again. Thanks for your help
  10. Thank You for your reply sounds easy enough. To answer some of your questions Yes, if I where to hit button A for a second time I would want the countdown to restart. Yes, I would like the fan turn off the fan and "scene" button to turn off when the timers expire. When Main OFF is pressed everything turns off and returns and resets. And if the 30min is running and I press the 15min I would like the 30min to stop and the 15min to begin. Or likewise if the 15 or 30 are running and the 45min is pressed they would also stop and the 45min would start, however I would like the fan to continue to run though the changeover. Below is what I came up with last night, which seemed to work correctly however I didn't get to test the going from 15min to 30min as described in the above paragraph. I did set up a scene with all 4 buttons A-D as Responders and I left them in toggle ON mode. And Just to Confirm you recommend changing them to Controllers? Fireplace Fan_A 10min If Control 'Devices / Fireplace Fan / Fireplace Fan - A' is switched On Then Repeat 8 times Wait 10 minutes Run Program 'Fireplace Fan Off' (Then Path) Wait 20 minutes Set 'Devices / Fireplace Fan / Fireplace Fan' On Repeat 1 times Run Program 'Fireplace Fan Off' (Then Path) Else - No Actions - (To add one, press 'Action') Fireplace Fan_B 15min If Control 'Devices / Fireplace Fan / Fireplace Fan - B' is switched On Then Repeat 8 times Wait 15 minutes Run Program 'Fireplace Fan Off' (Then Path) Wait 30 minutes Set 'Devices / Fireplace Fan / Fireplace Fan' On Repeat 1 times Run Program 'Fireplace Fan Off' (Then Path) Else - No Actions - (To add one, press 'Action') Fireplace Fan_C 30min If Control 'Devices / Fireplace Fan / Fireplace Fan - C' is switched On Then Repeat 8 times Wait 30 minutes Run Program 'Fireplace Fan Off' (Then Path) Wait 30 minutes Set 'Devices / Fireplace Fan / Fireplace Fan' On Repeat 1 times Run Program 'Fireplace Fan Off' (Then Path) Else - No Actions - (To add one, press 'Action') Fireplace Fan_D 45min If Control 'Devices / Fireplace Fan / Fireplace Fan - D' is switched On Then Repeat 8 times Wait 45 minutes Run Program 'Fireplace Fan Off' (Then Path) Wait 30 minutes Set 'Devices / Fireplace Fan / Fireplace Fan' On Repeat 1 times Run Program 'Fireplace Fan Off' (Then Path) Else - No Actions - (To add one, press 'Action') Fireplace Fan Off If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set Scene 'Devices/ Fireplace Fan/ Fireplace Fan Scene' Off Set 'Devices / Fireplace Fan / Fireplace Fan' Fast Off Set 'Devices / Fireplace Fan / Fireplace Fan' Off Else - No Actions - (To add one, press 'Action') Hopefuly this gives you more of a idea of where i was headed in my thinking. Thanks Again for all of your help.
  11. Hello, I am trying to use a 6button Keypadlinc as a timer. I was planning on using the "On" button to turn on the device and the "Off" button to turn off the device and the scene buttons as periods of time, that I can later adjust. So let’s say each in 15min increments ex. "scene A" would be 15min, "scene B" would be 30min, "scene C" would be 45min and "scene D" would be 60min. When a different Scene is selected it would end the previous scene. I was thinking of creating programs to control each of these, but I was wondering if anyone had any direction I could head. Thanks, Matt
