cmaterick
  1. Very strange.... I went back and tried one of my "old" Network Resources that was erroring on the IP2IR, and it is actually working on the Flex. So, I bought the Flex to enable REST and failed in the exact same way as TCP on the IP2IR, but it seems TCP on the Flex is working. Thanks for the idea of trying it.
  2. I appreciate the quick responses. Last weekend, I spent many hours attempting to get the GC iTach IP2IR working via the TCP interface. I gave up and ordered the Flex to use the REST API since I knew that my Bond Bridge rest calls worked great and only took me a couple minutes to get working. When I was fighting with the IP2IR, I was seeing the exact same thing. No matter what settings I used and what I included in the message body, I would get the following error in my error log which is the same error it's giving me trying to use the REST API. Sat 2022/01/22 05:05:22 PM System -170001 [TCP-Conn] -1/-140002, Net Module Rule: 3 I feel like I've made progress with the Flex since I can use Postman and get it to work 100% of the time. I just don't understand what I've done wrong in the setup in the ISY Network Resource such that it doesn't work as well.
  3. I could really use some help getting my Global Cache Flex to send IR commands. I have it working just fine from Postman, but it seems like no matter how I set up my network resource, it just errors out telling me with a -1/-14002 message in the error log. I believe this is indicating that the end tag is malformed. I also have multiple other network resources that send PUT requests to a Bond Bridge, and they work just fine. I can create new ones of those at will with success every time. I have attached screenshots from the Postman Console, one of my Bond Bridge network resources (PUT to 10.0.0.221) that works fine, and my GC Flex test network resource (POST to 10.0.0.225) that errors. Note that the GC Flex just returns an empty 200 OK message to Postman, and it does send the IR signal. I've also tried sending just the minimal set of headers for the GC Flex request like in Postman. This version is when I tried recreating all the headers that are working for the Bond Bridge network resource. Honestly, I've tried dozens of different options. I know other people not only have this working but say it's simple. So, I must be missing something dumb. Any help is appreciated.
  4. Every couple of days, I find that my 99i/IR Pro has lost its ability to connect to the outside world. Everything works just fine inside my house, but it cannot connect to an NTP server, SMTP server, WeatherBug, etc. Rebooting doesn't seem to solve the problem, but changing from a static IP to a dynamic IP (or dynamic to static) seems to resolve the issue temporarily. I've had the unit for years with no issues. I've upgraded to 2.7.15, and that hasn't solved the problem. If it helps, I'm using a Linksys E2000 router running firmware 1.0.01. Any thoughts are appreciated. Thanks.
