currieg
  1. Thanks I have a 994i and the latest version of the firmware... I used to be able to connect... sudden;y stopped working... I have also tried re-booting everything!
  2. I am trying to connect to the Admin console via Chrome but get this Java Error message.... Java is installed What do I need to do to correct? Thanks! => see details below: Java Plug-in 10.55.2.14 Using JRE version 1.7.0_55-b14 Java HotSpot Client VM User home directory = C:\Users\Currie ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message l: dump classloader list m: print memory usage o: trigger logging q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack x: clear classloader cache 0-5: set trace level to ---------------------------------------------------- java.lang.NullPointerException at sun.awt.SunToolkit.getSystemEventQueueImplPP(Unknown Source) at sun.awt.SunToolkit.getSystemEventQueueImplPP(Unknown Source) at sun.awt.SunToolkit.getSystemEventQueueImpl(Unknown Source) at java.awt.Toolkit.getEventQueue(Unknown Source) at java.awt.EventQueue.invokeLater(Unknown Source) at sun.awt.windows.WToolkit.windowsSettingChange(Unknown Source) at sun.awt.windows.WToolkit.eventLoop(Native Method) at sun.awt.windows.WToolkit.run(Unknown Source) CacheEntry[http]: updateAvailable=false,lastModified=Mon Dec 31 19:18:03 EST 1979,length=3424585 Resource http://crl.globalsign.net/root.crl has future expires: Sat May 10 16:57:35 EDT 2014 update check skipped.
  3. Yes the green LED on the PLM is on... Thanks
  4. The two Left Blue LEDs are on (Pwr & Rx)... I have re-booted (power off => on) a number of times. Also I have checked PLM connection cable? Thanks!
  5. When I do first boot up the ISY a get an message stating: "Your system is in Safe Mode"... But I can access the configuration page, etc. => Then when I go to the Program page I get the Error message: "Could not open File" [/CONF/INSTENG.OPT]. It looks like I may be missing a configuration file? Where would I find it? Also if I try to save a program (such as Query All) to my new ISY-994i I get this Error message: Invalid/incorrect program Key [HTTP]] I seem to be able to connect to the ISY-994i fine and adjust the Configuration, but when I try to save the Query All program I get the error message... I have not been able to figure out what is wrong / missing? Please help... Thanks!
