korby
  1. I removed 2 devices from my ISY. Both had been associated with Amazon Echo devices. They still appear in my ISY Portal Amazon Echo device list. Anybody know how to make them go away?
  2. Thanks for pointing that out. I had not seen it. I don't have a question, just a suggestion that bodyless notifications should work like all email systems that I've seen, that allow null mail bodies. As I'm not a frequent user of this forum, can you tell me a better way to make a suggestion?
  3. If you send a notification with an empty body, it fails to send.
  4. Right, I have patiently deleted every scene and device. Then I added an OutletLinc device (which controls a light) and a Dual Band KeypadLinc device. I can control the OutletLinc successfully through the ISY. Then I added a scene and added the KeypadLinc Scene C (controller) and OutletLinc to the scene. Scene Test is successful. However, when I turn the scene on, the OutLinc and KeypadLinc device states remain off, although the ISY shows them as on. I tried this with a different KeypadLinc with similar results. My whole automation system was working properly a week ago, with many devices and scenes and programs. That was when the PLM failed and I replaced it. Now I can't make even this simple configuration work. Sure hope somebody can tell me what's wrong.
  5. I have restored and deleted the PLM several times, unplugging, re-plugging, resetting everything I could think of. I've reached the point of exasperation and all I want to do now is start over with the ISY. Even that (deleting all of the devices from the ISY) is painfully slow. Do any of you experts have any suggestions about how I can get scenes to work again?
  6. Thanks for replying, Brian. I did that. Several times actually. Just now when I did it again, the progress bar got to about 2% and then it went away. Didn't seem to do anything. Repeated with same result. So I tried deleting the PLM. Progress bar got to about 1% and then went away. What should I try now?
  7. I'm using ISY 994i, v.4.2.30. A few days ago my PLM (2413S) seemed to stop working (scenes were not getting turned on/off programmatically) and after running several diagnostics, I was able to convince SmartHome to send me a replacement. Now that I've installed it, it looks like I have good comm and I can control devices just fine. But I can't turn on/off devices by turning on/off scenes. No scenes work anymore. ISY tells me the devices are on, but they aren't. I've tried restoring devices, and I've tried deleting all devices and re-defining them in ISY. Scene Test appears to work, but the devices are not actually turning on/off. I also tried moving my PLM and ISY to another location where I have another router. I'm baffled. Bill
