v101
Everything posted by v101
  1. Hello, I purchased and now trying to install the ISY Portal. I get to the step where it says Would you like to proceed, then when I press YES, i get the following error: Could not open config file to read: /CONF/INSTENG.OPT could not open file /CONF/INSTENG.OPT I have tried power cycling the device, to no avail. I am running version 4.8, i have installed other modules in the past, so not sure why this is happening. I have my configuration settings set to 8.8.8.8 for the DNS server, Any ideas to get this module installed?
  2. v101 replied to tdotr6's topic in ISY994
    wondering if any updates have been made to this? is full support for this on the way? or has anyone discovered any work arounds? to the morning industry locks w/ the ISY 99?
  3. GOT IT ! I suspected that was how to do this! thanks again!
  4. Hello - I have been working to get a program created where when my ELK Alarm goes OFF, I would like lights to flash on/off @ same time. Currently I build the program and tested it but the way its programmed, the lights go on/off in order, vs ALL @ the same time. Hopefully someone has done this before and figured out a way to get this working; if so please let me know; thanks;
  5. OK, will try this and report back how that works out. thanks for the assistance.
  6. correct, so that is how I am turning the switches on/off, is via the SCENE button. I enable the scene, and it reports only 50% (if I have 2 switches) just wondering if there is a way to have them both turn on for the LED's and also the Scene to reflect 100% vs just 50%
  7. Hello ISY users. I am somewhat a newbie with the ISY 99. I was able to get everthing into it, and so far working great. however I have a few small issues, I am trying to resolve. I believe most of them are related to the Insteon switches I have, but figured I would start by asking here in this forum. So I am using the APP MobiLinc Pro, and I have several lighting scenes that are reporting only 50% due to the fact that only 1 of the 2 switches in the scene are powered up 100%. Its reporting is odd, considering the light is fully on, that the switches control. When I push the button manually, It appears both switches are linked properly, as the LED's both ramp up/down. however when pushing the lights on via the APP, or via a program, they only engage 1 of the lights, and thus why it reports @ 50%. If anyone can comment on the proper method of getting BOTH to report as active. let me know.
  8. Hello ISY users, I have been doing basic automated lighting for years, actually started way back using X10 and had the entire house geeked out w/ the lights, and other devices being controlled. Anyway the Insteon Control Linc worked as a basic controller, but when I wanted to do more advanced things, it just wasn't possible. I recently purchased an ELK M1 GOld security panel due to the automation features of it, and bought also the ISY-994i and after getting it powered on and on my network, it took me about 10 minutes and I had various scenes working, about 30 minutes of work, and I got every Insteon device into the scenes, including the 6 button keypads, and fan-lincs, and they all work just fine! I am very happy with my purchase, and next step is to integrate this into the ELK,
