bigscience
Everything posted by bigscience
  1. So I think I finally figured out the hardware side of things. I ended up cutting a phone wire and putting the red and green wires into the ground and sensor inputs on a I/O Linc. Normally, when there is no alarm, the connection in made on these wires but when an alarm is triggered, a relay comes on and flips them on and off. This is all it takes to trigger a signal to the ISY. I wrote a simple program to send a text saying the alarm was triggered. If Control 'IO Sensor' is switched Off Then Send Notification to 'BradCell' content 'Alarm' Wait 15 seconds Send Notification to 'BradCell' content 'Alarm' Else - No Actions - (To add one, press 'Action') It works and sends me 2 texts so hopefully I don't miss the first one. I'm not sure if there is a more elegant way to wait for a bit to make sure it wasn't an accidental set off or to keep sending them if the alarm is still on. Overall I'm happy that I can keep my current alarm for now and can cancel my land line. Thanks ISY!
  2. The other thing I was thinking about doing was since I woun't be using the phone lines in it (it has a line in and line out), was to connect the two of them with a IO Link between them. My thought is that when it tries to dial, it would connect between the line in and put it's dialing out. This would signal the IO link that something happened? It's also a little easier hack since it would just be a phone line splice. Thanks for the LED idea, I hadn't thought of that. I'll post back if I get anything figured out.
  3. I have a Skylink Wireless alarm system with a dialer to give me a call when the alarm goes off. Everything works fine but I'd like to get rid of the land line and just use ISY to send me a text when the alarm goes off in stead. Has anyone ever done any integration with one of these systems? http://www.amazon.com/Skylink-SC-1000-C ... B0002YPFBS I looked inside the dialer and there are a set of contacts that look they are for hardwiring the dialer to an IO Link to trigger the dialer but I'm looking to go the other way. http://www.smarthome.com/73210/I-O-Linc ... Kit/p.aspx Any thoughts?
  4. So I updated Java with the same outcome. Then I added my add ISY address as an exclusion to Avast and now it works. Hopefully this can help someone else out down the road. I'm still not sure why this just became an issue.
  5. When I turn on/off lights from the admin console, there is no status. Current State is blank and the On level is 0%, the Ramp Rate is 9.0 Min. I Disabled the Avast Web Shield and then reloaded the Console and it then worked as expected. What I'm not getting is how this could happen? I'm wondering if it has to do with a Java update that I haven't done yet (Avast blocks parts of it in ISY). I'd rather not update that and then also have to update the ISY to a Beta. I'll see if there is a way to 'trust' the ISY in Avast. Any other thoughts? Thanks for the point in the right direction too.
  6. I went into the Admin console yesterday and wanted to change a few lights settings but nothing was being written. Then I noticed the button that toggles on/off the writing of changes is not there anymore. I tried to right click on the switch and use 'Write Updates to Device' option but this didn't write either. I tried to restart the ISY 994i and I get the same thing. Any thoughts? I'm running v.4.0.5 on an 994i Pro with 1758MB Free and the PLM shows as connected. I can turn lights on/off from the console too. Thanks for the help.
  7. Rats. I guess I need to find a spot to put the smoke bridge where SWMBO can't unplug it and forget to plug it back in. Thanks for the info.
  8. So is there anyway to tell if it's still plugged in? How does the 'is responding' work?
  9. I do have a 994 Pro version 4.0.5. For the smoke bridge, I'm showing nodes smoke, CO, Clear, Low Bat, Malfunction, Test and Unknown Message. I'm not sure what Clear and Unknown Message are for. Is one supposed to be the heartbeat like on a leak sensor? Thanks for the help.
  10. I just got and hooked up a smoke bridge and a few detectors. I've got all the alerts working via text but am wondering if there is a way to let me know if it get's unplugged (kind of like the heartbeat on the leak sensors). Would a "is responding" once a day work? What exactly does "is responding" do when in a program? Would it ping the smoke bridge and then report back the results?
  11. That's what I thought I could do but after I did a factory reset, the ISY couldn't communicate with it. I thought it broke the link between the ISY and the KPL with the factory reset. I couldn't get it to work without removing and adding the KPL back in. I guess I should have tried a little harder. Thanks for the help, I'm still leaning here. I like what I'm seeing so far though.
  12. For Status, in a program I can choose >Off or Is Not Off. I get that 10% is not 'ON' but is >Off. I just don't get why there is an "is not off" when ">off" looks to do the same thing. Am I missing something? Is there a case where you'd use one over the other? Thanks for the help.
  13. Sorry if this is a dumb question but what's the difference between status >Off vs Is Not Off?
  14. I never was able to solve this with just the ISY (restore or anything) so I ended up removing the KPL, doing a factory reset at the unit and then relinking to the ISY. Everything seems to be working great now. I wish there was a way to do the factory reset and then restore from the ISY so I didn't have to recreate all the scenes. If there is and I couldn't figure it out, please let me know in case this ever comes up again.
  15. Did a test scene and got this: Sat 12/14/2013 06:33:32 PM : [GRP-RX ] 02 61 30 13 00 06 Sat 12/14/2013 06:33:32 PM : [iNST-SRX ] 02 50 1D.F4.D3 25.16.EB 61 13 30 LTOFFRR(30) Sat 12/14/2013 06:33:32 PM : [std-Cleanup Ack] 1D.F4.D3-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sat 12/14/2013 06:33:32 PM : [iNST-SRX ] 02 50 0D.32.1C 25.16.EB 61 13 30 LTOFFRR(30) Sat 12/14/2013 06:33:32 PM : [std-Cleanup Ack] 0D.32.1C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sat 12/14/2013 06:33:32 PM : [iNST-SRX ] 02 50 22.76.6F 25.16.EB 61 13 30 LTOFFRR(30) Sat 12/14/2013 06:33:32 PM : [std-Cleanup Ack] 22.76.6F-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sat 12/14/2013 06:33:33 PM : [iNST-SRX ] 02 50 14.CA.C8 25.16.EB 61 13 30 LTOFFRR(30) Sat 12/14/2013 06:33:33 PM : [std-Cleanup Ack] 14.CA.C8-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sat 12/14/2013 06:33:33 PM : [iNST-SRX ] 02 50 1D.D0.82 25.16.EB 61 13 30 LTOFFRR(30) Sat 12/14/2013 06:33:33 PM : [std-Cleanup Ack] 1D.D0.82-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sat 12/14/2013 06:33:33 PM : [CLEAN-UP-RPT] 02 58 06 Sat 12/14/2013 06:33:33 PM : [iNST-SRX ] 02 50 13.9F.CE 25.16.EB 61 13 30 LTOFFRR(30) Sat 12/14/2013 06:33:33 PM : [std-Cleanup Ack] 13.9F.CE-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 ----- Home Test Results ----- [succeeded] Kitchen Cans Controller (22 76 6F 1) [succeeded] Stairs (1D D0 82 1) [succeeded] Kitchen Cans (D 32 1C 1) [succeeded] Living Room Cans (13 9F CE 1) [succeeded] Landing (Kitchen) (1D F4 D3 3) [succeeded] Landing (Living Room) (1D F4 D3 2) [succeeded] Landing (Stairs) (1D F4 D3 1) [succeeded] Landing (Home) (1D F4 D3 7) [succeeded] Living Room (Stairs) (14 CA C8 1) ----- Home Test Results ----- Sat 12/14/2013 06:33:40 PM : [iNST-TX-I1 ] 02 62 00 00 30 CF 13 00 Sat 12/14/2013 06:33:40 PM : [iNST-ACK ] 02 62 00.00.30 CF 13 00 06 LTOFFRR(00) Sat 12/14/2013 06:33:40 PM : [ 1D F4 D3 3] ST 0 Sat 12/14/2013 06:33:40 PM : [ D 32 1C 1] ST 0 Sat 12/14/2013 06:33:40 PM : [iNST-TX-I1 ] 02 62 00 00 18 CF 11 00 Sat 12/14/2013 06:33:40 PM : [ 22 76 6F 1] ST 0 Sat 12/14/2013 06:33:40 PM : [iNST-ACK ] 02 62 00.00.18 CF 11 00 06 LTONRR (00) Sat 12/14/2013 06:33:41 PM : [iNST-TX-I1 ] 02 62 00 00 36 CF 13 00 Sat 12/14/2013 06:33:41 PM : [iNST-TX-I1 ] 02 62 00 00 18 CF 11 00 Sat 12/14/2013 06:33:41 PM : [ 1D F4 D3 3] ST 255 Sat 12/14/2013 06:33:41 PM : [iNST-ACK ] 02 62 00.00.36 CF 13 00 06 LTOFFRR(00) Sat 12/14/2013 06:33:41 PM : [iNST-TX-I1 ] 02 62 00 00 21 CF 11 00 Sat 12/14/2013 06:33:41 PM : [iNST-ACK ] 02 62 00.00.18 CF 11 00 06 LTONRR (00) Sat 12/14/2013 06:33:42 PM : [iNST-ACK ] 02 62 00.00.21 CF 11 00 06 LTONRR (00) Sat 12/14/2013 06:33:42 PM : [ D 32 1C 1] ST 255 Sat 12/14/2013 06:33:42 PM : [iNST-TX-I1 ] 02 62 00 00 18 CF 11 00 Sat 12/14/2013 06:33:42 PM : [ 22 76 6F 1] ST 255 Sat 12/14/2013 06:33:42 PM : [iNST-ACK ] 02 62 00.00.18 CF 11 00 06 LTONRR (00) Sat 12/14/2013 06:33:43 PM : [iNST-TX-I1 ] 02 62 00 00 36 CF 13 00 Sat 12/14/2013 06:33:43 PM : [iNST-TX-I1 ] 02 62 00 00 18 CF 11 00 Sat 12/14/2013 06:33:43 PM : [iNST-ACK ] 02 62 00.00.36 CF 13 00 06 LTOFFRR(00) Sat 12/14/2013 06:33:43 PM : [iNST-ACK ] 02 62 00.00.18 CF 11 00 06 LTONRR (00)
  16. In the ISY, they show the true status. I just disabled all my programs as well (in case they were somehow doing something) but it still doesn't work. I already tried to remake the scene but maybe I'll try it one device at a time to see how it works. The only other thing I was thinking was that this is for a button 7 on and 8 button KPL. It shows as an 8 button in ISY but I wasn't sure if a 6/8 button thing is going on here? If I Restore the device with ISY, is that the same as a factory reset at the device? Should I try that next? Thanks for the help.
  17. what relationship does the "few lights" and the "3 different lights" have with one another? Are they all the same lights, some of the same lights, or none of the same lights? What buttons on the KPL controls these lights? What devices actually provide power to the lights? Entry KPL controls 3 separate Switchlincs that control the Kitchen, Stairs and Living room lights. The buttons on the Entry KPL work fine. Just to illustrate that there is no signal sucker or any interference. I am not sure what this means. Sorry. Under the Scene, this is an option to rewrite the link for the scene. So...you want one of your KPL buttons to be a "home" button and when pressed, 3 different lights turn on and any other KPL buttons which individually control those same lights also come on. Do I have that correct? To do this, create a scene that includes the home button (as controller) the other KPL buttons, and any devices that actually provide power to the lights. Set the ON levels and ramp rates as you desire for the scene, and any controller in the scene. Is this what you did? That's correct and that's what I have as illustrated by the fact that when I turn on the scene from the ISY everything works fine. When I use the Home button on the KPL that is set as the controller, only the lights on the Entry KLP respond. The on levels are the same as (and taken from) ISY scene. I just link table checked all the responders and the controller and they are the same as the ISY. I restored the devices as well. Still no luck.
  18. bigscience posted a topic in ISY994
    I'm sure I'm missing something here but I'm at my wits end. I have a KPL that controls a few lights and am trying to add a "Home" button that will turn 3 different lights on. Before ISY, this was working fine but somehow during my setup and playing around with other things it no longer does. I don't think it's a communication issue as the 3 other buttons can still control their respective lights. I've tried to "restore link to Home", scene and button, as well as restoring the devices to make sure the link tables are matching. How is it that I can turn the scene on from the ISY, the links match but the button won't turn on the scene? When I do a scene test it even says it works. I've tried to set the button as toggle, non-toggle on/off and nothing seems to be working. I'm at a loss here. Any advice or even suggestions on where to look or how to post logs would be great. I'm sure it's an operator issue.
  19. Thanks a ton! This is way simpler than the 4+ programs I was trying to use.
  20. So I can't use a scene but I have to use a scene for a secondary button? So is what I describe possible and worth perusing or out of reach? Thanks for the info and direction.
  21. I'm sure this has to have be address but I can't seem to find the answer and I feel really stupid about it. I just got my ISY 994i and am really annoyed about having to constantly enter a password to control lights. Is there a way, either on the ISY or iPhone, to have it remember the credentials? If I need to turn off the bedroom lights when I get into bed it seems lame to have to log in to press one button vs just getting up and turning them or (or buying a hard remote). Is there a way to put the ID/PW in the URL maybe? Sorry if this is a really novice question, I'm new. Thanks in advance for the help!
  22. Just got my ISY 994i last week and am loving it so far. MUCH better that the Smarthome stuff I wasted my money on. I have a question that I'm sure I can do but am at a loss for so far. I have a few situations where I want a KPL button to show when a light is on for any number of other lights but then to turn one on, then all off if pressed again. Example: By my entry I have a "Kitchen" button that I want to use to turn on the cans if off or to turn off all the kitchen lights it pressed again. I also want it to come on if either the cans or cabinet lights are tuned on. BUT, if I turn both on an then turn one off, I need the button to stay on for the KPL. Cans pressed on - KPL button turns on Counter pressed on - KPL button turns on Counter or Cans off but other on - KPL still on KPL Kitchen button turned on - Kitchen Cans turn on KPL Kitchen button off - Cans and counter go off I can't figure out how to do this with a scene(s). Does this require a program? Sorry if this has been addressed before but I can't seem to find it. I have the same desire for my downstairs lighting. Toggle one light on or all off but not any press other stuff off.
