jeffbott
  1. When I click On, Fast On, Off, or Fast Off in the scene, the relay does not change state but the status at the top of the scene, 'Current State' changes (On or Off following the correct click) I added a KPL button as a controller and it acts the same; press the button, the 'Current State' changes but the relay does not energize/de-energize. I did confirm again, if I adjust the slider to any position other than 0 to 100 the dialog box comes up saying that level is not supported what do you want to do. If you adjust the slider to 100% the relay energizes, if you slide it to 0% it de-energizes.
  2. I have searched the forums and can't find this, so forgive me if I missed it. I have an ISY99i IR/Pro v2.6.6. I have several EZIO 2x4's working great using both inputs and outputs. However, when i try to use one of the relays (outputs) in a scene as a responder it acts strange (to me). If I click the On or Off button for the scene nothing happens. The scene does have a slider showing at the bottom and if I slide the slider to 100% it activates the relay. Sliding to 0% deactivates the relay. Is this normal or do I have something set up wrong??
  3. Thanks guys. I suspected this was the case. I will take your advice and find a hardware factory reset on the ISY and start over by adding devices with the clear all links option. Jeff
  4. Maybe i missed this, so forgive me if i have. I have a variety of Insteon devices that were installed and linked either manually or using HouseLinc (all up and running fine). Now i have just installed a new ISY99i / IR Pro and added all the devices, created scenes, programs, etc. I selected to keep existing links (maybe a mistake) as it created a bunch of numbered scenes. As i am going through the scenes, it appears that they were created using the existing device link tables. So, before i go ahead and clear all the scenes and corresponding device links i thought i would rely on your wisdom. Now to the question; should the only links in devices point to the modem and therefore all control be managed vis the ISY, OR should i leave the existing links and have a mixed environment? Hope that made sense.
