aweber1nj
  1. Yeah, this is a very good point. Unfortunately, I have a mish-mosh of different plugs so I'll have to go find the factory reset info for each model. But yes, good idea. Thanks.
  2. Trying to exclude/remove some Z-Wave switches from my ISY in preparation to move them, but when I choose Remove a Device, that window just says Listening for Devices and eventually just dismisses itself, not returning anything or doing anything. I did see some SSL errors recently, but not sure what those are all about. ISY v5.3.1 ZWave 6.82.01 / 21100 Any help/tips would be greatly appreciated. Found this in the log, don't know if it helps? ZW 004 Multilevel Switch Error 0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Wed 2024/01/31 04:51:36 PM System Log ZW 004 Multilevel Switch Wed 2024/01/31 04:51:36 PM System -2 D R Side board Lights Status 100% Wed 2024/01/31 04:55:06 PM System Log L R Lights 3 Status 50% Wed 2024/01/31 05:20:06 PM System Log ZW Outdoor1 On-Off Error 0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Wed 2024/01/31 07:52:50 PM System Log Get NodeDef ZWave 0 Wed 2024/01/31 08:36:34 PM System Log ZW 005 On-Off Power Switch Status On Wed 2024/01/31 08:36:57 PM System Log Start Exclude ZWave Wed 2024/01/31 08:37:15 PM System Log Start Exclude ZWave Wed 2024/01/31 08:39:43 PM System Log Cancel Include/Excl ZWave Wed 2024/01/31 08:40:38 PM System Log Start Exclude ZWave Wed 2024/01/31 08:41:16 PM System Log ZW Outdoor1 On-Off Status Off Wed 2024/01/31 08:44:08 PM System Log ZW Outdoor1 On-Off Status On Wed 2024/01/31 08:44:11 PM System Log ZW Outdoor1 On-Off Status Off Wed 2024/01/31 08:44:17 PM System Log ZW Outdoor1 On-Off Error 0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Wed 2024/01/31 08:44:28 PM System Log ZW Outdoor1 On-Off Wed 2024/01/31 08:44:28 PM System -2 [ZWCMD cmd.51] ZWave Wed 2024/01/31 08:44:50 PM System Log [ZWCMD cmd.51] ZWave Wed 2024/01/31 08:44:51 PM System Log [ZWCMD cmd.51] ZWave Wed 2024/01/31 08:44:51 PM System Log [ZWCMD cmd.51] ZWave Wed 2024/01/31 08:45:19 PM System Log [ZWCMD cmd.51] ZWave Wed 2024/01/31 08:45:19 PM System Log [ZWCMD cmd.51] ZWave Wed 2024/01/31 08:45:20 PM System Log Start Exclude ZWave Wed 2024/01/31 08:45:30 PM System Log Get Dongle Version ZWave Wed 2024/01/31 08:50:44 PM System Log Get NodeDef ZWave 0 Wed 2024/01/31 08:55:57 PM System Log ZW Indoor1-On-Off Error 0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Wed 2024/01/31 08:57:18 PM System Log ZW Indoor1-On-Off Wed 2024/01/31 08:57:18 PM System -2
  3. I installed a "commercial" SSL Cert on my isy a few years ago. I think this was for an alternate portal...or maybe I was trying to "roll my own" extranet access to my isy (very likely with wiki or forum topics). I just got a notification that my SSL Cert needs to be renewed... My question is: If I'm paying for the (official) ISY Portal, and I currently only use that - and its Amazon Echo integration - do I need an SSL certificate installed on my isy device anymore? Can I just let that expire? Or is it necessary for comms with the Portal? Thanks for any info. -AJ
  4. As much as I like the banter (and I do), just to get back to the OP... Still having trouble with this. I actually always had just "tree" as a secondary name for the outlet-module, but it doesn't help. The really strange thing is that Alexa doesn't seem to ever have a problem with the "on" command. It is only turning it "off" that she thinks the device does not support the command. In addition, sometimes she replies that she can't execute that command, but then it turns off anyway. So I'm wondering if there is some timing or other resource issue where commands aren't being sent to the portal or ACK'ed back to Alexa in a timely manner? Still...why only the "off" command? I did notice my devices get messed-up over the past few days as one poster had mentioned (some were in Spanish, some were devices I never had, etc.)...I did a forget-all and re-discover and it appeared to get my devices back. Any further ideas or updates from the devs? Thanks again, AJ
  5. Yeah, I don't know Alexa's implementation, but I did work with the MSFT speech sdk at one point and it (logically enough) would try and "understand" all words, then throw-out all the ones that it figured were irrelevant according to its "vocabulary". So technically, you should be able to say something like, "Alexa, please turn the Christmas tree in here all the way on right now", and it would only care about noun and verb for this case: "Christmas Tree" and "On". Certainly, other "skills" or actions require additional vocabulary -- even ISY's; like if it recognized the word "percent" it might try and find the number to associate with the command as well as changing it's pattern to look for the words "up" or "down" as adverbs. I appreciate the advice and experience. I'll try to re-arrange my requests to Alexa (though I'm sure Amazon's goal is to make the order of the sentence anything at all)...us early adopters have to deal with idiosyncrasies sometimes!
  6. Thanks, Andy. Doesn't seem directly related, other than they're fixing some bugs in the integration. Appreciate the heads-up.
  7. Are the bugs related to the "newer" version of the alexa skill? Maybe I was really lucky, but I don't remember having a single problem with the older one. Not sure which "other recent thread", but if you can point me in the right direction, I'll be happy to read through it. Thanks for your reply!
  8. I upgraded my Amazon Echo to the new ISY "skill" (v2) last week. I had been using the original integration via the ISY Portal successfully. Everything seemed to be working smoothly...and for the most part, everything still is, except... I added an insteon module to control the Christmas Tree. Also added it to the portal. First two days everything worked great: "Alexa, turn Christmas tree on/off" was flawless. Yesterday afternoon I turned it on (using Alexa), no problem. But when I was headed to bed, I couldn't turn it off! Alexa kept responding with, "That command doesn't work for this device." The command being "off". This morning I tested it and it turned on fine. But when I went to turn it off, she complained again...but then successfully turned it off? Has anyone experienced something like this controlling ISY-devices via their Echo? Any tips/tricks? Thanks in advance, AJ
  9. OK, cool. So 8001 was originally missing - it's not a "standard" port so I have it blocked by default. Once I allowed all outbound traffic last night, things started working fine. (I did double-check the HTTPS Client settings, and they were OK.) I can go back and change the firewall rule to only allow 443/tcp and 8001/tcp for the ISY's MAC address instead of "everything". Thank you for the response. -AJ
  10. I really don't want to get off topic here. The vast majority of networked appliances leverage https (sometimes http) to connect to servers in the cloud. I have plenty of them. Those that don't use standard ports typically publish their requirements somewhere. Google something like "Sonos ports", or "ecobee network ports". You'll see them explicitly define what they require for normal operation. They typically wouldn't be prone to viruses either. Anyway, thank you for the feedback!
  11. Outbound ports shouldn't be too insecure to publish. You can't connect to them, they're outbound. The reason I don't allow "all ports" outbound is to reduce exposure for anything malicious that finds its way into my network. (And because I'm a freak. ) I just feel that if you have a connected device, you should ask for (or specify requirements for) communications; consider it a privilege, not a right. It's not a huge deal. Just thought if a dev read this, they could correct me or publish the info for "the next guy".
  12. That's what I was wondering. If the ISY uses http/https (or a multitude of other ports I already have open), it would be OK. If it's using something specific, I think it should be published somewhere so crazy guys with hardened home firewalls know what the device requires to operate.
  13. Yessir, I registered it. Could be total coincidence, but when I set an exception in my firewall to allow the ISY unfettered access outbound, things started to get back on track. I saw it ask for permission in the ISY Console, the icon went yellow in the portal, and after accepting it, it went green and now I'm off and running. So IDK if it's coincidence or if the devs are using a non-standard port to communicate outbound to the portal servers.
  14. Are there any specific ports that my isy994i needs to connect out to the ISY Portal? I just purchased the portal to try it out with my Amazon Echo. The ISY is added to the portal, but continues to say "Never connected". The ISY Portals page shows "Offline Never Registered". Hopefully it's just a little slow tonight, because there isn't any info I can find that says there are any special ports that it requires outbound (my firewall DOES filter outbound traffic). Any ideas? Thanks, AJ
  15. @oberkc: Thank you for the clarification. That's the details I was looking for. Still trying to fully solve the original issue, but thank you very much for that info!
