  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
ulrick65
  1. I figured it out, parameter setting. I am trying to figure out how to get Alexa+ to control the light directly (not through a scene). It works, but if I ask to turn on the light (based on the room I am in, it knows which light device) it always turns it on to the last level. I got it so that when I turn it on from the paddle switch, it comes on to 50% like I want. But Alexa always turns it on at the last level...frustrating. I know I can use a scene to do it, but it should work to turn on the light to the default on level that I set for the device I would think.
  2. Does anyone know how to set the onlevel percentage for a Zwave device? For example, when I press the local button I want it to come on to 50%. I tried to change it in the device settings in Eisy...set the onlevel to 50% and it works there, if I click the on button it comes on to 50%. But I clicked on Write Changes and that doesn't seem to do anything. When I press the local button to on, it seems to come on to whatever the last level was. Not what I want.
  3. Working fine for me. Doing some setup right now and all is working as it should.
  4. I am moving to Z-Wave devices more and more and I just discovered the QRCODE scan in the Mobile App. I did it and it added the device, but I don't see the Device in the Admin console. Where does it go? I tried to add it again it says it already exists, but I can't find it. Any help appeciated. Thanks.
  5. Try to login to the portal and you get HTTP Error 429... Too Many Requests. Either hammering is going on, or the site is rate limited for some other reason on the server side. Maybe a contract expired at the end of the year and didn't renew properly or something... ๐Ÿ˜ฒ
  6. Yup, the portal is down. Hopefully someone will see it soon and get it fixed up. No Alexa. ๐Ÿ˜ญ ๐Ÿ˜‰
  7. Anyone know of a good digital pressure sensor that will integrate into EISY for my water system? Ideally, it would be something that monitors pressure in some app or fashion over time (cloud is fine with me). What I want to do is monitor water pressure fairly accurately and be able to look at it overtime...but also integrate with EISY so I can do something with the pressure in a program for example. Thanks.
  8. Thanks for the info...I will give it a try and see if I can get APCUPSD to work on it.
  9. Yes, I have had a few outages since getting the EISY and it has come back up as well. I think the risk is low...but since I have it plugged into a UPS, and I already have several programs running on my various servers and RPI devices that take care of UPS control during an outage I figured I might as well add the EISY if it is possible. Thanks.
  10. Anyone know how to get the EISY to shutdown gracefully before the UPS runs out? I am thinking that it should be possible to do with NUT or ApcUpsd like other Linux boxes? Seems like not a good idea to just cut the power to the thing...any thoughts? Thanks.
  11. I use extension cables: The EISY sits in my server rack. The PLM is plugged in at my power panel (a separate receptacle and I have a phase bridge installed) and is connected to the EISY via a 35-foot USB 3.0 cable. The zMatter Dongle is mounted in my basement ceiling at the end of a 16-foot USB 2.0 cable. Everything works perfectly. Thanks.
  12. Thanks very much for this....pain in the backside, but works like a champ! This proves the app still recognizes the scenes, but for some reason, they are no longer accessible from the main devices list. I hope this is not a precursor of things to come and they are removing the ability to deal with scenes. I assume someone at UDM has looked into it...whoever developed the Alexa Skill perhaps. If they are phasing out support for scenes, I assume developers would be aware of it? @Chris Jahn - Chris, any insight on this, or perhaps can you pass it along to someone who might be able to look into it to make sure it is just an APP issue and not something more? Thanks.
  13. You got that right Larry...
  14. To me, the Alexa App is unbelievably clunky and always has been. Amazon should be ashamed of the UI on this app. Not only that, just when you think it might be OK they constantly moving stuff around and half the stuff never shows up. Overly complicated, etc. The service, echo, skills, integration, etc. all work great... top-notch...but the app itself just plain stinks Everything in my house is working, but when I go into the app as stated above, the Scenes are no longer there. Go into Devices and about 3 of them show up when you view all devices...but yet I have 64 of them with spoken words and all work perfectly. I was trying to clean up an old scene that I deleted...that's how I found out none of them are in there. Another example, I went looking for the "Installed Skills" that I have installed for Alexa and I can not for the life of me find a list. There is an Icon for "Skills and Games" that lists them all that I can install...I can search for one and if it is installed edit it, but I can't see where they moved the "Installed Skills" menu item to. I am currently struggling with getting both my wife and I's profiles synced up to ISY. Works fine for me...but not for her all the time on certain devices. So today I figured I would relink to ISY and see if I could fix it. Did a "Discover my devices" under her account and now I get the same message as above for everything: โ€œThere are multiple devices with the name xxxxx, please give your devices unique names and start discovery again.โ€ So nothing works on her profile now. And I can't see where to delete them from...as was said, the portal is working right...it is Alexa (and the app) that stinks. Used to be you could use the Web Page and delete things in about 1 minute there...but now they force you to the app. If I find anything out will post back here...please do the same. Thanks.
  15. Just curious is the Z-Matter Dongle for the EISY is a USB 2 or 3 device? I am putting it on an extension cable and the one I have is USB-2. I can't image it needs anything more than that. I don't have any Z-Wave devices yet to test it, so asking here. It is white inside the port, not blue...so assume USB2 but just to be sure. Thanks.
  2. Tap Permissions โ†’ Notifications.
