jonathanud
  1. All of what I assembled here came from other forum posts and the posted sonos.zip network resources. It took me a while to get it all together, but I was very pleased with the results. The ISY is one of the best appliances I have ever owned. I purchased it exclusively to drive my lighting, which it does masterfully: timers and adjustments matched to sunset, sunrise, and my routine. I love what it does, but I never expected it to bridge additional systems as it is now doing with Sonos. Had I known I could do this, I would have invested in Sonos sooner. Thanks to you forum contributors for teaching me how to leverage it, and thank you, UD Sales for giving me a discount on the Network Module in exchange for my contribution to the community. That kind of partnership is really nice to see. Objective: Living room Insteon controls for Sonos Play/Pause button Volume Up/Down button Previous track button Next track button Equipment ISY-994i with Network Module Insteon 2486D 6 Button Control Sonos ZP100 Variable sonos_lr_play - Sonos doesn't have a play/pause toggle function, so we cheat with a variable. Buttons PLAY/PAUSE - toggle on only VOLUME - toggle on/off to use fade up and fade down controls PREVIOUS - toggle on only NEXT - toggle on only PLAY/PAUSE can also be used as toggle on/off, and the indicator light while match whether music is playing. As long as you use no other Sonos controls (ios app, computer, etc.), this works, but the indicator cannot be guaranteed to match the play mode when other controls are used. I opted just to have a permantently lit toggle and let my ears determine the status. PROGRAMS Sonos LR Next If Control NEXT is switched On Then Resource 'sonos.lr.next' Sonos LR Pause button1 and button2 pause the music as part of other scenes; PLAY/PAUSE is the in-room toggle button If Control button1 is switched On Or Control button2 is switched On Or (Control PLAY/PAUSE is switched On And $sonos_lr_play = 1) Then Resource 'sonos.lr.pause' $sonos_lr_play = 0 Sonos LR Play If Control PLAY/PAUSE is switched On And $sonos_lr_play = 0 Then Resource 'sonos.lr.play' $sonos_lr_play = 1 Sonos LR Previous If Control PREVIOUS is switched On Then Resource 'sonos.lr.previous' Sonos LR VolumeDown Button is held, volDown repeats until button is released. If Control VOLUME is switched Fade Down And Control VOLUME is not switched Fade Stop Then Repeat 25 times Resource 'sonos.lr.volDown' Sonos LR VolumeUp Button is held again, volUp repeats until button is released. If Control VOLUME is switched Fade Up And Control VOLUME is not switched Fade Stop Then Repeat 25 times Resource 'sonos.lr.volUp' NETWORK RESOURCES sonos.lr.next POST /MediaRenderer/AVTransport/Control HTTP/1.1 Host: 192.168.3.134:1400 Connection: Close Content-Type: text/xml; charset="utf-8" Content-Length: 265 SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Next" 0 sonos.lr.pause POST /MediaRenderer/AVTransport/Control HTTP/1.1 Host: 192.168.3.134:1400 Connection: Close Content-Type: text/xml; charset="utf-8" Content-Length: 267 SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Pause" 0 sonos.lr.play POST /MediaRenderer/AVTransport/Control HTTP/1.1 Host: 192.168.3.134:1400 Connection: Close Content-Type: text/xml; charset="utf-8" Content-Length: 285 SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Play" 0 1 sonos.lr.previous POST /MediaRenderer/AVTransport/Control HTTP/1.1 Host: 192.168.3.134:1400 Connection: Close Content-Type: text/xml; charset="utf-8" Content-Length: 273 SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Previous" 0 sonos.lr.volumeDown I played with the adjustments a bit to find a good speed, found that I preferred the volume decrease a little quicker than increase. Volume must change sufficiently before the Insteon button enters pairing mode. POST /MediaRenderer/RenderingControl/Control HTTP/1.1 Host: 192.168.3.134:1400 Connection: Close Content-Type: text/xml; charset="utf-8" Content-Length: 356 SOAPACTION: "urn:schemas-upnp-org:service:RenderingControl:1#SetRelativeVolume" 0 Master -7 sonos.lr.volumeUp POST /MediaRenderer/RenderingControl/Control HTTP/1.1 Host: 192.168.3.134:1400 Connection: Close Content-Type: text/xml; charset="utf-8" Content-Length: 355 SOAPACTION: "urn:schemas-upnp-org:service:RenderingControl:1#SetRelativeVolume" 0 Master 6 Attachments isy994i network resources sonos.zip
