f.demello
  1. Perfect MrBill. Thank you
  2. I'm sorry - I stated this wrong. My problem is when I switched to Verizon from AT&T. Would the same logic apply? [10digit]@mms.verizon.net. Currently using [10digit]@vtext.com per the program drop down for Verizon text
  3. Thanks MrBill - will try that this weekend
  4. Hello - I use the Leak Sensor program listed in these pages and used to get full texts from events when with Verizon. I switched to AT&T and now my texts are truncated so I don't see the entire message. I changed the text parameters to AT&T Has anyone else seen this?
  5. Is there a simple way to check each device one at a time? I have some Remote Linc's as well. How do I know for sure each device is working? Thank you
  6. Seems like some of the sensors are working now. I'll work on the one's not communicating. Link cont being 0 doesn't make sense though
  7. Maybe I'm not doing it right but I am still getting a load count of 0 with the new PLM. Is it normal to go Tools/Diagnostics/Show Device Links and the system ask to select a device. I thought this reported all devices linked to the PLM? Seems difficult to get every batter device into programming mode at the same time. How do I test each device individually? Thank you
  8. Thank you. Will do
  9. PLM blue light on. Rx flashing blue Note: I recently unplugged the PLM/ISY and plugged back in from something I saw on the internet. Still getting a 0 count.
  10. Definitely > 2.5 years
  11. Sorry for the delay. Put all the battery devices in programming mode. Ran through Restore Modem. Count is still 0. Is the ISY dead in the water?
  12. I don't have that many devices. When I run the PLM Link Table it is coming up with 0. Very frustrating
  13. I worked perfectly for 2 years where it is currently. My leak sensor programs do have the heartbeat program but I don't in my 2 open/close sensors (although I just changed both batteries)
  14. Ran the If/Then statements and I received the text. I had just changed the batteries in the sensor. Do these sensors die? Not that old (1-2 years). I also suspect all my leak sensors are not working as well (have 7). Will have to test
