smorgasbord
  1. Yeah, I could do a weather station, and might be fun to have the stats, but if it doesn't detect light drizzle, or even moderate drizzle it's not helping me.
  2. smorgasbord started following Rain Sensor?
  3. smorgasbord posted a topic in Insteon
    I've got both Insteon and YoLink devices in my EISY-based setup. I just installed new Velux solar-powered skylights. These claim to have a rain sensor integrated into the solar panel, but after investigating, it turns out that it's really just a sound/knock sensor. That is, when rain drops hit it, there's a noise/vibration and it interprets that as rain and closes the skylights. However, last night/this morning/right now it's drizzling. Definitely more than a mist, but the rain drops are small/light enough that they're not triggering the Velux sensor. Since I do have the ability to close the skylights via my EISY, I'm thinking an external rain sensor might be a good option, but I can't find one made by Insteon or YoLink. Both have water sensors, but they need puddles underneath. There's a YoLink version that has two contacts on the top and so that might work, but I'm reaching out in case anyone knows of anything specific.
  4. smorgasbord replied to roho's topic in YoLink
    Well, that sucks.
  5. smorgasbord replied to roho's topic in YoLink
    Just wanted to point out that Belkin's recent termination of WeMo support AND cloud service shows us exactly why completely local control and local setup is needed. I set up a lighting automation system last century, yes in the 1990s. Although the company (LiteTouch) is no longer around, I'm still able to not only keep the system running, but to add new devices and capabilities to it since it's all programmed and run locally. Cloud is great for monitoring/controlling away from home, but the in-house stuff always need to work as long as the hardware lasts.
  6. smorgasbord replied to roho's topic in YoLink
    Aren't there things one needs to do to set up to run locally, beyond just using the local-capable hub? I recall seeing something about automations, but can't find it now. Also, if one is running two hubs (for distance), then what happens when the internet goes out? thanks!
  7. I am using UD Mobile on my iPhone and it is up to date. Don't see anything in Notifications that isn't from my debugging set ups. The UD Web Interface seems OK, too. Polyglot is fine now, too. It seemed that maybe something was going on after the update/reboot that consumed the CPU and so I got that message. Eventually the something ended and all seems just fine now, thanks.
  8. Just to expound a bit more. Velux now ships all skylights with remote-operated shades. So, when you get a skylight that also opens, you end up with two bulky square remotes - one for the skylight open/close and one for the shade up/down. Now, you can buy a touchscreen remote from Velux that can be programmed to choose and control multiple items, BUT (and this is a big problem) the top-level menu is to choose Skylight Control or Shade Control. So, if you're in a room and want to close the skylight AND lower the shade on that same skylight you've got a lot of clicking to do: 1) Select Skylights 2) Select the Group or Skylight 3) Close 4) Return to Main 5) Select Shades 6) Select the Group or Skylight (hopefully you created the same groups and/or renumbered the shades the same way) 7) Lower I'd rather have a single Insteon I3 keypad with 4 buttons - top 2 for open/close, bottom 2 for raise/lower. That requires the internet interface to the KLF and some programming, which has been done for Home Assistant but not for EISY. I've got 14 skylights, 8 of which open, so this is kind of a big deal for me.
  9. OK, so did the backup, and upgraded Java as well. Rebooted and things looked fine, so I did the update, got a prompt to reboot and did so. Logged in and looked around a bit, then rebooted manually as you suggested. Seemed fine, but when I went into Polyglot, I had some trouble logging in, eventually did but then got logged out right away with this message: Retried it a few times, and eventually got in. So far things seem to be working normally again now, but that was a little bit weird.
  10. OK, here's the KLF documentation. KLF API technical specification for klf 200 api-ver3-18.pdf
  11. Thanks, this is what I'm running now: ************ IoX ************ isy-5.9.1_7 Name: isy Version: 5.9.1_7 Installed on: Thu Feb 27 14:25:50, 2025 PST Origin: misc/isy Architecture: FreeBSD 14:amd64 later on it says: FreeBSD_version: 1401000 So, I don't think I'm too out of date.
  12. That's correct. For me, I don't have Home Assistant set up - I use EISY (with my old LiteTouch system for lighting) exclusively. So, this would mean learning yet another system (Home Assistant), figuring out what hardware to buy, load and set things up, and then integrate the KLF200. Certainly do-able, but I'm not looking forward to setting up a third home automation system in my home.
  13. I have a bunch of Insteon and YoLink devices connected through Eisy and the YoLink plug-in. I'm now adding a 5 skylights to be controlled. I just figured out the contact closure end of things, but the Velux integration hub does NOT report the state of the skylight. Since the skylight can be controlled not just through Eisy, but also directly through Velux's remotes or the Velux App, I can't just track the commands Eisy sends. YoLink has a door & window sensor: https://shop.yosmart.com/collections/door-sensors/products/ys7704 for $17. Insteon has one for $40 https://www.insteon.com/products/open-close-sensor The problem I have with both of them is that the skylights have screens that don't move. So I'd have to put one piece (say the magnet) on the moving skylight window frame, and other piece just inside the fixed frame on the other side of the screen. I'm worried that even when closed the distance between the two pieces will be too large and the sensor will always report open. Any thoughts on either sensor's ability to span, say, ½" of distance with a metal frame in between and still report closed? YoLink's contact sensor that uses a small magnet and the sensor is also small, connected with a short wire to a battery pack. I've used that on my front gate, but it requires the magnet and sensor be able to be very close to register closed, so i don't think that'll work and while the thing is outdoor rated, don't really want to mount it outside the skylight due to battery replacement concerns. Insteon also has a single piece plunger-operated door sensor, but I can't drill a hole deep enough in the skylight for that to work. Maybe the best idea is the YoLink Garage Door sensor, which I think can tell when the tilt changes. Given my skylights are on an angled roof it may be that when they're open they're horizontal enough to report as "closed", but I could invert the logic in Eisy. Anyone try anything like this?
  14. Follow-up to my own post - I got the KLF200 to work. On the web configuration, there's a page where you can assign product(s) to input wires: You can't see it here, but on the 5/6 input pair I've got two window openers controlled (would have to click the wheel to see and change that). But, there's also a "Channel" selector. By default, it's using Channel 3, which is "normal operation," but it looks like I could select 4,5,6,or 7 to get different operation behaviors. That might be a way to have more than 5 controls, but it wouldn't be useful for most things as if you can open a skylight you'd also want to be able to close it. Anyway, I can now use relays in Eisy (Insteon or whatever) to open/close my skylights.
  15. I'm an EISY user (previously 994i) using a mix of Insteon and YoLink modules. I haven't done anything with the system in over a year, since everything is working. I just had to replace a bunch of Velux skylights, and so now have new items to control. In the interim, it appears from my reading: https://www.universal-devices.com/2025-liftoff/ That there's a new non-Java Admin UI as well as HomeKit support. I've looked but can't find the how-to/getting started pages for those features. Can someone point me at documentation for both? Oh, and I guess updating my software as well. thanks!
  16. The KLF200 can handle only 5 devices/scenes/groups that require up/down or open/close control. There are only 10 input contact closure wires after all. The default is that when you pair a skylight, one wire opens and the next wire closes it. So with 10 wires that gets you to 5. Now, instead of controlling a single device, there is the concept of groups. You can program a single Velux remote (KLI) to control multiple skylights or multiple shades. One set of KLF200 wires can control that whole group as well, but not the items in that group independently.
