ABLE1
Everything posted by ABLE1
  1. ABLE1 replied to ABLE1's topic in ISY994
    oberkc, Ok, that was more of a "ME" programming thing than anything else. I just found it easier for "ME" to not use scenes to get the job done. All is good. Thanks, Les
  2. ABLE1 replied to ABLE1's topic in ISY994
    obeerkc, Thanks for your reply. However I am a bit mystified by your "reliability" comment. What I was questioning was the Ramp at 8.5% in the Log and it was explained by kclenden to be a result of a power start up status report. Which makes sense and it could have easily been. It hasn't happened since. If there is something else that I might be missing then please explain, since I am missing it somewhere in translation. As for the programming of scenes or not I am quite happen at this time with the not. Thanks, Les
  3. ABLE1 replied to ABLE1's topic in ISY994
    Hi oberkc, May be somewhat true. However, my present programing is doing what I wanted it to do except for what I assume is the Ramping of the light levels. The customer is happy with how it is working!! Therefore for me to work on this by using scenes to get the ramping to actually work is not really necessary. I just would have liked the it to ramp. At this point figuring it out has little value for me. If the customer expressed a desire for it and was willing to pay for the extra time spent that might be a different story. Economics 101 or Rewards for Time spent. Thanks, Les
  4. ABLE1 replied to ABLE1's topic in ISY994
    Maybe true. However, I tried using a scene in the beginning and for some reason had trouble with it not working as desired. When I went to just controlling the switches themselves then all was good. As I said, I will give it a try when I have nothing else to do. Thanks for the input!! Les
  5. ABLE1 replied to ABLE1's topic in ISY994
    Sooooooo what you are saying is that I need to do some different/more programming?? Maybe, I will just leave well enough alone..................... until I have nothing better to do. Thanks, Les
  6. ABLE1 replied to ABLE1's topic in ISY994
    Hello kclenden, Thank you for the detailed response to my question. Very helpful!! So the info in the Log was a report of the configuration status of the switch not an command to the switch. Got it!! In your response you triggered another question. You said: "the switch is configured to come on to 100% with a ramp rate of 8.5 seconds if you actually tap it." If in programming I have a switch go from 30% to 100% will it ramp up at a rate of 8.5 seconds?? By your statement I am guessing that to be not true. If that be true then the programming needs to be modified to have the switch ramp up to 100%. Is that correct?? Thanks again!! Les
  7. ABLE1 replied to ABLE1's topic in ISY994
    UPDATE: Over the past two weeks all seems to be working quite well. However, I did notice something that needs a little enlightenment. I noticed on the Log the following in the attachment. This is the first time I noticed that the Ramp Rate is Logged into the report. It was not triggered by the driveway sensor X10 input but did start with a "Null" being logged. First question, what is a Null and then what would cause it to happen?? It actually triggered all switches to do the same thing. Status OFF >> On 100% >> Ramp Rate 8.5 seconds At some point the lights went Off since when I looked at the switch they were off. May not be a big deal but I am curious as to what caused it to happen?? Again thanks for any input. Les
  8. ABLE1 replied to ABLE1's topic in ISY994
    Hello ALL, Ok, so I now have my program working as desired. At least it appears to be from looking at the Log File. The program is attached for those that have a similar desire. Now I am sure that there are a multitude of other variations to do the same thing. However, this seems to work for me, at this time. I also set the Ramp Rate for each switch to 8.5 seconds. I assume that it will apply to both up and down since I am not there to observe the effect. Which brings up a few questions. I decided not to add the Ramp Rate in the program itself since it is available in the switch itself. Is that correct?? I also noticed in the programming pull down that there are a number of ways to say the same thing. Such as Brighten and Fade Up or Fade Down and Dim. Why so many choices to do the same thing?? Seems odd, but I assume there is a good reason. The other odd thing that I noticed is that in the switch programming under Ramp Rate the values go from 0.1 seconds up to 8.5 seconds and then jump to 19.0 and 21.5 seconds and move up to 47 seconds. Is there some mathematical value of prime numbers going on there that creates those values?? And thanks to all for the input. All very helpful. Have a good rest of your week. Les ISY Program 02_12_19.pdf
  9. ABLE1 replied to ABLE1's topic in ISY994
    Hello, Still a bit mystified here. I have this small program entered and running. X10 Test - [ID 0003][Parent 0001] If X10 'A5/On (3)' is Received Then Set '4D.76.AA.1 Rear Door' On 100% Else - No Actions - (To add one, press 'Action') Seems rather straight forward in that If a X10 A5 is received then set 4D.76.AA.1 to On at 100% However the Log shows that it is turning on at 100% and then turns Off in the same second or 1 second later. This is the part I am missing or not understanding!! What is turning it off?? ----------------------------------------------------------------------------------------------------------------------- X10 A5 Mon 2019/02/11 01:14:00 PM X10 A5 On (3) Mon 2019/02/11 01:14:00 PM 4D.76.AA.1 Tony Rear Door Status 100% Mon 2019/02/11 01:14:01 PM 4D.76.AA.1 Tony Rear Door Status Off Mon 2019/02/11 01:14:01 PM X10 A5 Mon 2019/02/11 01:14:03 PM X10 A5 Off (11) Mon 2019/02/11 01:14:03 PM X10 A5 Mon 2019/02/11 01:15:50 PM X10 A5 On (3) Mon 2019/02/11 01:15:51 PM 4D.76.AA.1 Tony Rear Door Status 100% Mon 2019/02/11 01:15:51 PM 4D.76.AA.1 Tony Rear Door Status Off Mon 2019/02/11 01:15:52 PM X10 A5 Mon 2019/02/11 01:15:53 PM X10 A5 Off (11) Mon 2019/02/11 01:15:54 PM Thanks, Les This is an edit. I think that I found the problem. It seems that I forgot to disable the other program to have the light off during the day and as such they were being turned off just after being turned on. Maybe i will know once the driveway sensor is tripped again now that I have the other programs disabled. My bad........... I decided not to delete the above since it may help others with the challenge someday. Les
  10. ABLE1 replied to ABLE1's topic in ISY994
    Hurting2Ride Please look at the loaded image. In the Add To Program area it states Time is After Sunset However, it the Program Line it states Time is Sunset. It does look like a contradiction but it is the Admin Console that is making it look that way. Besides I don't see a "between" selection or choice. It is either Before or After. That is UNLESS I am missing some other program pull down. Thanks, Les
  11. ABLE1 replied to ABLE1's topic in ISY994
    Hello all, I do appreciate all the extra insight and thoughts on how to use scenes or not use scenes, etc. However, my problem is trying to get the X10 On(3) signal to actually trigger a 100% lights ON So far that hasn't happened that I can see. In the Log it clearly records the X10 On(3) but the lights have yet to respond. So I have now set a program to do just one thing. And because I am not there I have to wait for someone to come in the driveway and see if the light comes on. X10 Test - [ID 0003][Parent 0001] If '4D.76.AA.1 Tony Rear Door' Status is Off And X10 'A5/On (3)' is Received Then Set '4D.76.AA.1 Tony Rear Door' On 100% Else - No Actions - (To add one, press 'Action') It would seem to me that this simple program should do as it is written. However, in the mean time, my question goes to the following. Are there condition or devices that will not respond as expected with X10 signals?? Or is it just a matter of getting the program written properly?? If the program above does NOT turn on the light then what is missing?? Needless to say if it does actually turn on the light then this is all somewhat moot. At this point it is just a wait and see. I will provide more input later once it happens .......... or not. Thanks, Les
  12. ABLE1 replied to ABLE1's topic in ISY994
    Ok Guys, I have read and sifted through the input. Some I get and some I put the side. I have made changes to the programs and will have to wait a while to see what happens. I am quite sure something needs changed or modified. Again Thanks for any input. Les The programs are now as follows. My Programs - [ID 0001][Parent 0000] Folder Conditions for 'My Programs' If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Allow the programs in this folder to run. ----------------------------------------------------------------------------------- Turn On At Sunset - [ID 0005][Parent 0001] If Time is Sunset Then Set '2C.36.AB.1 Laundry Door' On 30% Set '4D.76.8D.1 Front Door' On 30% Set '4D.76.97.1 Mud Room Door' On 30% Set '4D.76.AA.1 Tony Rear Door' On 30% Set '4D.77.36.1 Tony Garage Front' On 30% Else Turn On From X10 - [ID 0002][Parent 0001] If Time is Sunset And X10 'A5/On (3)' is Received Then Set '2C.36.AB.1 Laundry Door' On 100% Set '4D.76.8D.1 Front Door' On 100% Set '4D.76.97.1 Mud Room Door' On 100% Set '4D.76.AA.1 Tony Rear Door' On 100% Set '4D.77.36.1 Tony Garage Front' On 100% Wait 10 minutes Set '2C.36.AB.1 Laundry Door' On 30% Set '4D.76.8D.1 Front Door' On 30% Set '4D.76.97.1 Mud Room Door' On 30% Set '4D.76.AA.1 Tony Rear Door' On 30% Set '4D.77.36.1 Tony Garage Front' On 30% Else Set 'Sconce Lights' Off --------------------------------------------------------------------------- After 11pm x10 - [ID 0004][Parent 0001] If From 11:00:10PM To Sunrise (next day) And X10 'A5/On (3)' is Received Then Set '2C.36.AB.1 Laundry Door' On 100% Set '4D.76.8D.1 Front Door' On 100% Set '4D.76.97.1 Mud Room Door' On 100% Set '4D.76.AA.1 Tony Rear Door' On 100% Set '4D.77.36.1 Tony Garage Front' On 100% Wait 10 minutes Set 'Sconce Lights' Off Else Set 'Sconce Lights' Off ----------------------------------------------------------------------------------- Turn Off at 11PM - [ID 0006][Parent 0001] If Time is 11:00:00PM Then Set '2C.36.AB.1 Laundry Door' Off Set '4D.76.8D.1 Front Door' Off Set '4D.76.97.1 Mud Room Door' Off Set '4D.76.AA.1 Tony Rear Door' Off Set '4D.77.36.1 Tony Garage Front' Off Else - No Actions - (To add one, press 'Action')
  13. ABLE1 replied to ABLE1's topic in ISY994
    Hi Paul, I made the changes as you described. Will need to wait till sundown to see it it makes a difference. But, I do question what that change would have to do with the program reacting favorably to a X10 On(3) input?? Can you or somebody shed some light on that point?? Thanks, Always learning............................. Les
  14. ABLE1 replied to ABLE1's topic in ISY994
    Paul, Ok, I can do it that way. I thought having the From and To was a more efficient way saying the same thing. I will give that a try. Thanks, Les
  15. ABLE1 replied to ABLE1's topic in ISY994
    Paul, Sorry you are right, I pulled the wrong part number off. My whoops. I am using a PSC01 that is responding to a contact closure from the driveway sensor board. Personally not sure what the HD/UC stands for but if it has to do with a X10 ON (3) signal then yes that is what I have in the program. The LOG shows that that being received as well as the OFF (11) OFF signal. As in: X10 A5 On (3) Sun 2019/02/10 12:06:48 PM System Log X10 A5 Sun 2019/02/10 12:06:51 PM System Log X10 A5 Off (11) Sun 2019/02/10 12:06:51 PM System Log X10 A5 Sun 2019/02/10 12:12:59 PM System Log X10 A5 On (3) Sun 2019/02/10 12:13:00 PM System Log X10 A5 Sun 2019/02/10 12:13:02 PM System Log X10 A5 Off (11) Sun 2019/02/10 12:13:03 PM System Log X10 A5 Sun 2019/02/10 12:18:25 PM System Log The issue is that the signal does not appear to change the lights that I can see. That is what I am missing. Thanks, Les
  16. ABLE1 replied to ABLE1's topic in ISY994
    Paul, Thanks for the response but, sorry, wrong assumption on your part. This is a Driveway sensor that triggers a X10 UM506 Universal Module that is being read by the PLM. The X10 A5 signal is being received, logged in history but is not being responded to as f or turning on the scene to 30% or 100% as desired. That is where the mystery is at. Thanks for any other thoughts. Les
  17. Hello all, SOooooo I thought this was going to be simple programming project, but.................... I have researched this issue as far as I can, but I am not seeing what is missing. I have installed 5 each Togglelinc's for some outside light Sconces around an customers house. Installed a ISY and PLM and linked all switches through the Admin Console. Easy!! Then I created a Scene and called in Sconces. Attached the Switches to the Scene. Then wrote a program to have the lights come on at 30% at Sunset every day and off at 11pm. Then wrote a program to respond to a X10 signal A5 that is triggered by a driveway sensor to turn on the lights to 100% for 10 minutes and then return to 30%. Then wrote a program to have the lights off at 11pm to Sunrise the next day except when the X10 A5 is triggered to then put the lights at 100% for 10 minutes and then shut off. ============================================================================= My Programs - [ID 0001][Parent 0000] Folder Conditions for 'My Programs' If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Allow the programs in this folder to run. ----------------------------------------------------------------------------------- After 11pm - [ID 0002][Parent 0001] If From 11:00:10PM To Sunrise (next day) Then Set 'Sconce Lights' Off Else - No Actions - (To add one, press 'Action') ----------------------------------------------------------------------------------- After 11pm x10 - [ID 0004][Parent 0001] If From 11:00:10PM To Sunrise (next day) And X10 'A5/On (3)' is Received Then Set 'Sconce Lights' On 100% Wait 10 minutes Set 'Sconce Lights' Off Else - No Actions - (To add one, press 'Action') ----------------------------------------------------------------------------------- Turn On At Sunset - [ID 0005][Parent 0001] If From Sunset To 11:00:00PM (same day) Then Set 'Sconce Lights' On 30% Else - No Actions - (To add one, press 'Action') ----------------------------------------------------------------------------------- Turn on From X10 - [ID 0003][Parent 0001] If From Sunset To 11:00:00PM (same day) And X10 'A5/On (3)' is Received Then Set 'Sconce Lights' On 100% Wait 10 minutes Set 'Sconce Lights' On 30% Else - No Actions - (To add one, press 'Action') =============================================================== What is not happening is the X10 A5 to 100% Simple question, what am I missing or do I need to adjust?? Thanks for any hints. Les
  18. ABLE1 replied to ABLE1's topic in ISY994
    Ok!!! Here is today's findings and what I did. Arrived on sight and the first thing was to remove two wires from the offending 3way switch. Did so and then checked the Insteon switched light and low and behold....................... it turned on. As it should!!! That is one more NOT. Then I decided to do what I had dreaded and moved the dining room table and checked the ceiling fixture junction box. Expecting to find all the splices for the 4way circuit. My plan was to tear it apart and check all the connections in order to find another NOT or not. Pulled the cover down and what did is see?????????????? One 14-2 romex connected to the lamp wiring. What the.....................................?? Well that means that the junction box must be somewhere else...................like the basement. Sure enough there it was nailed to a floor joist. Took the cover off and pulled the splices out. All looked as they should. Isolated the power feed to the box and separated the power feed to the 4way, and Insteon switch circuits and tagged. I was so happy finding the splice box that I did not even take the time to see if the problem was still happening. Happy! Happy! Happy!!!! I then had a conversation with the homeowner and asked this question. "What is more important, finding and understanding the problem or making it go away." He said, "80% making it go away and 20% curiosity of finding and understanding the problem." I then rewired the circuit to feed the 4way over to an near junction box that had a hot circuit. Reconnected all and the problem went away. So, I would like to THANK all that helped with thoughts and suggestions. At this point we will never know the cause. I can now sleep nights and get back to the rest of my life. And I am good with that!!! To be honest I would really have liked to continue troubleshooting until the source of the issue was found and corrected. But sometimes it is better just to throw in the towel and relax. Again thanks to all!!!! Les
  19. ABLE1 replied to ABLE1's topic in ISY994
    LOL Not my house but I will suggest it to the owner. He may be very receptive and might be reading this thread. I do understand what you are getting at. I just can't get my head around what you are suggesting based on what I have already observed. But then again nothing about this seems normal. Will let you know the results. Thanks, Les
  20. ABLE1 replied to ABLE1's topic in ISY994
    Oh, not that the 4way circuit is improperly wired but that more like the 4way circuit is improperly wired. Ok, I got it. But given your thought on the above. Would it not happen with every flip of the 3way switch. Sometimes it will take 15 -20 flips before it happens, and then it will take 2 - 5 flips to happen again. And when it does there is no indication at the Insteon that the power has been effected. I will let you know. So just for a moment, assuming that the Insteon does in fact work after the 3way is disconnected what would be your thoughts at that point?? Anything else I should be looking at that I have not already done?? I am just trying to look at other steps. BTW can anyone here describe what type and when does data get sent down the wire?? As I remember with x10 it was at zero crossing and for about 4 volts with I think 8 or 9 bits of data. With Ineston I am not sure. Do not remember reading that information anywhere. Can anyone provide some insight into that information?? Thanks, Les
  21. ABLE1 replied to ABLE1's topic in ISY994
    Ok, I can accept a possible bad connection but where?? The only place I have not checked is at the ceiling light fixture box. I will check. On the "incorrectly wired". How can a 4way circuit be wired "incorrectly" and still function as desire or designed?? Incorrectly wired tells me that it is not going to work properly. This one does. I have not tried to remove 2 wires from the offending switch............... but I will. Are you suggesting removing from the common terminal and another or just the contact terminals?? On the "momentary voltage interruption" it would have to be in microseconds. The analog meter was being watched by a very steady eye and it was rock solid. If there was a interruption of a microsecond or even a milisecond that could not be seen on the meter would or could the Ineston Switch even respond in any way?? I will check as suggested. However, I will wait to accumulate additional thoughts first. Thanks for the input. Les
  22. ABLE1 replied to ABLE1's topic in ISY994
    As an associated question. It there another Forum that I should be posting this question or issue that may have additional input to help resolve the problem?? Thanks again, Les
  23. ABLE1 replied to ABLE1's topic in ISY994
    Xathros and others, Ok, today I did some more testing and found some more NOT's. 1) First checked the Event Viewing on Level 3 as suggested. With a clear board I flipped the offending 3way switch to get the Insteon Light to react. When it did Nothing registered on the Viewer. I performed the test 4 times and Nothing. Just to be sure that the Event Viewer was working I turned the Ineston switch off and on and it indeed did respond and registered the action. The switch address is 28.96.D1. The result history is below. =============================================================== Wed 01/15/2014 02:17:50 PM : [iNST-SRX ] 02 50 28.96.D1 00.00.01 CB 13 00 LTOFFRR(00) Wed 01/15/2014 02:17:50 PM : [std-Group ] 28.96.D1-->Group=1, Max Hops=3, Hops Left=2 Wed 01/15/2014 02:17:50 PM : [ 28 96 D1 1] DOF 0 Wed 01/15/2014 02:17:50 PM : [ 28 96 D1 1] ST 0 Wed 01/15/2014 02:17:50 PM : [iNST-SRX ] 02 50 28.96.D1 13.00.01 CB 06 00 (00) Wed 01/15/2014 02:17:50 PM : [std-Group ] 28.96.D1-->13.00.01, Max Hops=3, Hops Left=2 Wed 01/15/2014 02:17:50 PM : [iNST-INFO ] Previous message ignored. Wed 01/15/2014 02:17:57 PM : [iNST-SRX ] 02 50 28.96.D1 00.00.01 CB 11 00 LTONRR (00) Wed 01/15/2014 02:17:57 PM : [std-Group ] 28.96.D1-->Group=1, Max Hops=3, Hops Left=2 Wed 01/15/2014 02:17:57 PM : [ 28 96 D1 1] DON 0 Wed 01/15/2014 02:17:57 PM : [ 28 96 D1 1] ST 255 Wed 01/15/2014 02:17:57 PM : [iNST-SRX ] 02 50 28.96.D1 11.00.01 CB 06 00 (00) Wed 01/15/2014 02:17:57 PM : [std-Group ] 28.96.D1-->11.00.01, Max Hops=3, Hops Left=2 Wed 01/15/2014 02:17:57 PM : [iNST-INFO ] Previous message ignored. ============================================================================== 2) I then decided to place my analog meter on the voltage input to the Insteon Switch. The voltage read 120vac steady. I then flipped the offending 3way until the Ineston reacted. The voltage held rock solid, no change of input voltage. 3) Just for comparison I place the meter on the voltage input to the ceiling light. (Red output wire from Insteon Switch.) I then flipped the offending 3way until the Ineston reacted. The voltage dropped off, light went out, light came back and voltage returned to 120vac. 4) I then decided to replace the Ineston Switch with a New Unit that I had just received. I then flipped the offending 3way until the Ineston reacted. Another NOT has been found. Not the switch. 5) Re-installed the original switch. Saw no reason to do other wise. 6) Re-checked the wiring in the 4way circuit. Each of the two 3way switches have a single 14/3 romex wire and the 4way has two 14/2 romex wires. What this means is that the hot feed wire comes into the ceiling light fixture. I have not removed the ceiling fixture to check but I do not see a good reason to do so based on my test of 2) above. 6a) I re-confirmed that is just one of the 3way causes the Ineston to respond. The other 3way and the 4way do not affect the Ineston Switch. 7) Don't ask me to explain but, the Homeowner had a EMF meter that measures Gauss units in a value up to 200 Gauss. Not sure if this is any good information at all but here is what I observed. Placing the EMF meter next to black power input wire to the Ineston Switch while the light was on gave a reading of 16.1 Gauss. I then flipped the offending 3way and saw no change until the light went off and back on. This would be expected since the load changed during the time. The value return to 16 Gauss. Again not sure if this means anything but that is what was observed. Conclusion: So far my NOT's are racking up. I am really not sure what else I can test or try to find the problem. A few things that really puzzle me is how can a Mechanical Switch on a 120vac circuit produce any signal or affect on a wire if the is no load devices installed. Someone correct me if I am wrong but if a open switch is made and there is no load, thus no electrons move. How can an electronic device that is designed to respond to some kind of data signal actually see that signal and respond?? It is obvious that something is going on. I can't believe that this is so "Never heard of this before" unique. As was said by kck when I first started this thread indicated that he observed something similar. Any suggestions would be most appreciated. Even dumb suggestion since they may spark another thought. Thanks, Les
  24. ABLE1 replied to ABLE1's topic in ISY994
    Ok, I got it!! Thanks!!!! Les
  25. ABLE1 replied to ABLE1's topic in ISY994
    Xathros, I won't get there till next week. But, please help me a little bit. I don't recall seeing an "event viewer" or a "level 3" when I was looking at the Universal-Devices Administration Console. There is a Event Log and a Error Log that i was looking at. Or are you thinking I should be looking at something else. Please advise. Les
