tunamangye
Everything posted by tunamangye
  1. Thanks for the help and the quick reply. Here are the programs: Entrada Sala Motion If Control 'Sensores Motion / Motion Entrada Depa-Sensor' is switched On And From Sunset To Sunrise (next day) Then Run Program 'EntradaSala3min' (Then Path) Else - No Actions - (To add one, press 'Action') EntradaSala3min If Control 'Sala / Entrada sala' is not switched On Or Control 'Sala / Entrada sala' is not switched Fast On Or Control 'Sala / Entrada sala' is not switched Fade Up Then Set 'Sala / Entrada sala' On Wait 3 minutes Set 'Sala / Entrada sala' Off Else - No Actions - (To add one, press 'Action') EntradaSalaMotion Enable Disable If Control 'Sala / Entrada sala' is switched On Or Control 'Sala / Entrada sala' is switched Fast On Or Control 'Sala / Entrada sala' is switched Fade Up And Control 'Sala / Entrada sala' is not switched Off Or Control 'Sala / Entrada sala' is not switched Fast Off Then Disable Program 'Entrada Sala Motion ' Else Enable Program 'Entrada Sala Motion ' Here are the jumper settings: jumper 1: both pins jumper 2: one pin only jumper 3: both pins jumper 4: both pins jumper 5: both pins Settings for the options dialog: timeout 1 Led Brightness 100 Darkness Sensitivity 80 Sensing mode (Checked) On only mode (unchecked) Night mode (unchecked) Event Viewer log: Tue 05/20/2014 11:24:47 AM : [iNST-SRX ] 02 50 28.3A.B7 00.00.01 CB 11 01 LTONRR (01) Tue 05/20/2014 11:24:47 AM : [std-Group ] 28.3A.B7-->Group=1, Max Hops=3, Hops Left=2 Tue 05/20/2014 11:24:47 AM : [ 28 3A B7 1] DON 1 Tue 05/20/2014 11:24:48 AM : [iNST-SRX ] 02 50 28.3A.B7 00.00.01 CB 11 01 LTONRR (01) Tue 05/20/2014 11:24:48 AM : [std-Group ] 28.3A.B7-->Group=1, Max Hops=3, Hops Left=2 Tue 05/20/2014 11:24:48 AM : [iNST-DUP ] Previous message ignored. Tue 05/20/2014 11:24:49 AM : [iNST-SRX ] 02 50 28.3A.B7 22.FE.60 41 11 01 LTONRR (01) Tue 05/20/2014 11:24:49 AM : [std-Cleanup ] 28.3A.B7-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Tue 05/20/2014 11:24:49 AM : [iNST-DUP ] Previous message ignored. Tue 05/20/2014 11:24:49 AM : [iNST-SRX ] 02 50 28.3A.B7 11.01.01 CB 06 00 (00) Tue 05/20/2014 11:24:49 AM : [std-Group ] 28.3A.B7-->11.01.01, Max Hops=3, Hops Left=2 Tue 05/20/2014 11:24:49 AM : [iNST-INFO ] Previous message ignored. Tue 05/20/2014 11:24:50 AM : [iNST-SRX ] 02 50 28.3A.B7 11.01.01 CB 06 00 (00) Tue 05/20/2014 11:24:50 AM : [std-Group ] 28.3A.B7-->11.01.01, Max Hops=3, Hops Left=2 Tue 05/20/2014 11:24:50 AM : [iNST-INFO ] Previous message ignored. Hope this helps to figure out the problem. Julio
  2. Hi Xathros, The program is not working for me. I have several issues. Sometimes it turns on, other times it doesn't. I do check ISY and the programs look disable even when the lights are not on. Another problem is the countdown.. it looks like it won't restart the 1 min countdown when the sensor senses movement, so the light turn off no matter what. What am I doing wrong? Help
  3. Hi Xathros, Thank you so much for the help. Oberkc, Yes. I would like to reset the countdown, how do I do that? I thought the program did that already.
  4. My intention was to avoid running the program when the light is already on. If the light is on, there is no need to turn on the light or to turn it off in 3 minutes. The problem is that when I have people over and somebody walks by the sensor.. 3 minutes later the light turns off. Very annoying. I'm trying to find a solution.. I thought the 'status' option was it.
  5. I´m using the same program to turn on the lights when entering the apartment from the main door. It works great when entering the apartment at night. But the problem is, that when I have people over and they walk by the entrance area, when the light is already on, they activate the sensor and it activates the time countdown and it turns off after the 3 minute set interval. Here is the program: If Control 'Sensores Motion / Motion Entrada Depa-Sensor' is switched On And From Sunset To Sunrise (next day) Then Set 'Sala / Entrada sala' On Wait 1 minute Set 'Sala / Entrada sala' Fade Down Else Wait 1 minute Set 'Sala / Entrada sala' Fade Down Here is what I thought was the solution (but it did not work): If Control 'Sensores Motion / Motion Entrada Depa-Sensor' is switched On And Status 'Sala / Entrada sala' is Off And From Sunset To Sunrise (next day) Then Set 'Sala / Entrada sala' On Wait 1 minute Set 'Sala / Entrada sala' Fade Down Else Wait 1 minute Set 'Sala / Entrada sala' Fade Down What am I doing wrong??? Please Help
