KHouse
  1. Thank you both so much. I was racking my brain trying to think through the logic and figure out what I was missing. Didn't realize it returns to "normal" before the time is up and that is the root cause of the problem. Thank you again for the explanation and examples!
  2. Attached is a screenshot for what I would assume to be a very basic program that is not working for me. Appreciate any help anyone can give on what I am doing wrong here. If garage door sensor or motion sensor is activated, turn garage lights ON. Wait X number of minutes, then turn garage lights OFF. The door sensor and motion sensor are ELK, tied to the alarm, while the light switch is INSTEON. The lights do turn on when triggered...but they do not turn off. I must be missing something basic or not understanding how this work. Appreciate any help!
  3. Yes! I learned this from the first facility. The manufacturers sure do like to update their lights and so a fixture bought a year from now is unlikely to be the exact same they sold a year ago. And as much as the industry LED's last a million hours, the drivers sure don't.
  4. We based the lighting off of my other facility. This garage is a little bit wider, but we duplicated the same amount of lights per bay essentially. I wrote 12, but it's actually 18 fixtures. The electrician recommended less fixtures (with more output), but I wanted that quantity of fixtures to ensure we had good coverage everywhere so that there were no shadows. I also like the 4,000k color while the electrician and everyone recommended 5,000k. I just prefer the more natural look vs. the "sterile" look of pure white LEDs.
  5. Thanks for all of the detail info/explanation! I'll work on a solution here with the electrician now that I'm a little more educated on it.
  6. Sorry, forgot to mention, this is for a commercial facility and the lighting is 277v.
  7. I believe I'm using the dimmer 2334-232. I have another one handy and the box shows 600W. So that has got to be the problem. The lights are "Astrelights LED Linear Strip Lights". SKU ALI-00-41VT-003. Shows many different wattages on the box, so not sure if it's adjustable on the fixture itself or they just sell them in those fixed wattages. I do know the color temp is adjustable on them so maybe the wattage (brightness is too). It's a large garage (3 bay + extra 20' wide by 54' deep. So there are 12 of these fixtures.
  8. My apologies...watts not volts. (The lights are 227v though btw). It seems as though the 6-button switched is "maxed out". Thanks! Thanks for the help folks, much appreciated.
  9. I've got a new build where I'm trying to install an Insteon 6-button keypad to control the garage lights. The garage is rather large so there are (12) four foot LED light fixtures in the ceiling, and the light switch gets pretty hot when the lights are on. The electrician said the lights are drawing exactly 600 volts, and so recommends a 1,000 volt light switch, however, wanting to use Insteon to control this I'm wondering if there is an alternative or if someone has a recommended work-around / solution? Appreciate any help.
  10. Submitting the ticket + remote-in from Michel solved the problem! For other's future reference, I'm not sure what the issue was as all of the work they did to solve the problem went over my head, but the problem is now solved. Thanks again for all of the help @Javi and @DennisC.
  11. Ticket submitted. Thanks!
  12. Sorry for the basic questions. Where would I open the ticket at, and where would I find the node server log? Thanks again!
  13. I just tried rebooting the controller, still no fix. I've upgraded the UD Mobile App to current version, restarted the plugin in PG3x, rebooted the eISY, restarted the Elk M1, synchornized in the app, tried to restart the plugin from the app (that does nothing), tried to start the plugin in PG3x under configurations, checked the box to allow the plugin access to the eISY, tried to press start in the app...nothing has worked. I still have the same issue where it shows the plugin is disconnected. When I try to start the plugin, I get the error message that it's already running (see attached). When I try to press restart on the plugin in UD Mobile, I get the below error message.
  14. Yes, thank you. I did check that box, which resolved the orange error, however, I when I try to set the alarm in UD Mobile, I still get error "Node Status UOM". In PG3x, it shows that the plugin is disconnected. I try to press start, and it says it's already running. I try to press restart, and that doesn't change anything / do anything.
  15. Unfortunately I'm getting an error when tryint to restart the plugin there. The configurations tab says it's disconnected, however, when I press start, it says it's already running. When I press re-start, I get the error with the red/orange pictured below. EDIT: I found the little checkbox for allow ISY access, so that part is resolved. However, I still get the same error about it being disconnected and when I try to start or restart it doesn't do anything. It says it's already running.
