memphis2k
  1. memphis2k replied to memphis2k's topic in ISY994
    Updating to v5.2.0 made no difference. Still doesn't register.
  2. memphis2k replied to memphis2k's topic in ISY994
    Java Web Start 11.261.2.12 Using JRE version 1.8.0_261-b12 Java HotSpot(TM) Client VM JRE expiration date: 11/17/20 12:00 AM console.user.home = C:\Users\Aaron ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack 0-5: set trace level to <n> ---------------------------------------------------- https://isy.universal-devices.com/994i/5.0.16C/dashboard.jar https://isy.universal-devices.com/994i/5.0.16C/insteon.jar https://isy.universal-devices.com/994i/5.0.16C/jxtt.jar https://isy.universal-devices.com/994i/5.0.16C/bc.jar https://isy.universal-devices.com/994i/5.0.16C/ce.jar https://isy.universal-devices.com/994i/5.0.16C/chart.jar I just turned on Java Console via Windows Control Panel options Can I delete all of the Certs in ISY994i, reboot? I just don't feel like it saves it when I tried deleting the main cert in the past.
  3. memphis2k replied to memphis2k's topic in ISY994
    Submitted a ticket with GoGetSSL and they said its 2048. I just tried it Clicked Server Cert. "Yes" Entered PW Typed my email in the Email field (it was empty) Clicked Receive Cert and pasted the contents of isy.domain.crt Click OK Clicked No to Importing the Immediate certs And then nothing happens... I just compared the CSR that I sent GoGetSSL and its still the same.
  4. memphis2k posted a topic in ISY994
    Hello all, ISY994i v5.0.16a and my cert is up for renewal. Realized that I don't need a cert with portal, but still, I would like this figured out. I took notes from when I installed the cert and now I can't get Dashboard to ask me to restart the ISY (its confirmation, according to the WIKI). -Clicked No to start a fresh request for the CSR. -Sent the CSR to my SSL company and got the renewal Cert back. Clicked on Receive Cert. in Dashboard -Pasted the renewal Cert. -I said yes and added the other certs too (These should be the same as before)? -Then nothing, no prompt, etc. I have restarted the ISY a couple of times, Edge/Firefox still show the HTTPS web url as expiring in a couple of months. Also tried deleting the original cert, and still the same results. Also, each time I try something, i say "yes" to re-use the CSR. Can anyone assist me at all? The 4 files I have are: isy.DOMAINNAME.com.crt (the renewal cert) AAA_Cert_Services.crt (not sure what this is for) Usertrust_RSA_Cert_Auth.crt isy.DOMAINNAME.com.ca (Cert Authority)
  5. Thanks and I did email support, Easy solution. Just sign into portal with the new email and then it will send the verification email. One extra step that I guess I never thought to try initially. Hopefully it helps someone in the future.
  6. Hello, Found a thread that talked about changing an email in ISY Portal. Created a new user and enter the ISY MAC, Account Admin, new email address and password. I have waited nearly 45 minutes and have not received a single email from ISY. Any ideas so I can get this new email working please? I have switched over 300 accounts so far to my new email so I know my stuff is working fine. Thanks,
  7. So in the Alexa app, in the devices page, Garage Door Close (program) & (door is physically closed) - Sensor is NO Says Power On - and I click on it. Nothing happens. When I click on Power Off, the door opens. Garage Door Open (program) & (door is physically closed) - Sensor is NO Says Power On - and I click on it. Nothing happens. When I click on Power Off, the door opens Which makes senses to what the WIKI says. Good call, I will create an intermediate program to call the Garage Door Open/Close program. Thanks again
  8. Ok. I will review your posts and I thought to try testing the programs before the routine. IOLink is setup perfectly in ISY, with programs and such. Thanks again.
  9. Ok. I mostly have this working but now there must be a issue with Alexa. I removed the IOLink Contact & Relay from Portal & Alexa. Then created two programs like the above. *See image Then I created two Routines: (Name) Garage Door Open - (When you say), "Alexa, Open The Garage Door" - Garage Door Open (Program) Power On (Name) Garage Door Close- (When you say), "Alexa, Close The Garage Door" - Garage Door Close (Program) Power On What's happening now is that when I say "Alexa open the garage door AND the door is already open, she will open it - INCORRECT. And when its closed, Alexa, Open the Garage Door. She will. To recap, something is not right because the state of the garage door is not recognizing the Status from the ISY program. If the Garage door is open, and I say... Alexa, Open The Garage Door. NOTHING SHOULD HAPPEN, right?? The Garage door is physically open. Going into each device on Alexa. Each say Power Is On Thanks,
  10. Perfect. Programs and routines. Wasn't to sure if I should do something like mobilinc does, shows the status via the input but when you click on the icon, it changes the relay state aka opens/closes the garage. I use the "Tell Me" skill with network commands and that works wells, but just a verbal feedback. Then I saw one of the Admins posted that he added Open & Close commands for Alexa. Worked slick, but Alexa would never know the true state without an input involved.
  11. Hello, I have an ISY994i v5.16 with Portal and Alexa. Opening the garage door in Homebridge/Siri works perfect, as well as MobiLinc. Just looking for the proper way to setup my Garage Door that's connected with an I/O Link. When the garage door is open, the contact is touching, N/O state. I just have the Garage Door I/OLinc Relay setup in Alexa. Is that right? Then I setup the Open and close command. I can say, Alexa Open the garage door when the door is physically open. Just looking for someone's .02 on how to properly add a garage door to Alexa.
  12. It appears to be working now. Thanks everyone
  13. Portal says my ISY is not connected as well. In Admin Console, it says Portal is connected.
  14. Hello, Running ISY994i v5.0.16 and just got a Insteon Icon SwitchLink 2876S and there is no address on it, XX.YY.ZZ unlike all of my other Insteon devices. Can I figure the address out by chance? When I click "New INSTEON Device" I have to present an address / name then it find it.... any ideas? Thanks,
  15. This is a great lock and works well is ISY. I just upgraded to 5.0.15A so I'm making sure everything works. My favorite thing with this lock is I get a Pushover notification telling me who entered my house via correct user code. Thought I would post those options someone was asking about.
