Steve Vollstedt
  1. Thank you for this useful information
  2. I have to replace 2 Insteon motion sensors. I 'inherited' a Universal Devices EISY system from the previous owner of my home. I'm thinking that I should go to the IoX Launcher administrative console and delete all of the lines related to the old Insteon motion sensors which are no longer operable and then add the new motion sensors by following whatever instructions are provided by Insteon for the new motion sensors. Is that the way to properly change the motion sensors so that I can manage the motion sensors from the administrative console of the IoX Launcher? Or do I somehow add the new motion sensors (after deleting the old motion sensors) by doing so using the administrative console of the IoX Launcher?r I am a novice with all of this so any help would be greatly appreciated.
  3. I want a light in my chicken coop to dim very slowly, say over a 15-minute period, down to off based on some program variables that I have set up. My understanding is that if I choose "Fade Down" the light will fade down to off over about a 5-second period. How can I cause the light to fade down over say a 15-minute period to allow the chickens to find their roosts and settle down before the light goes off?
  4. Thank you for letting me know that Kaspersky may have a mechanism to add the ISY IP address to Kaspersky so it may not cause a problem. I will research that and attempt to add the ISY IP address.
  5. PROBLEM SOLVED - THANK YOU! I rebooted my modem, router & ISY controller. I then rebooted my computer, then dialed the Kaspersky firewall, and then successfully set up the device using Link Management - Link INSTEON Device functionality. It is not clear to me if the fix was rebooting the ISY controller, disabling the firewall, rebooting the other equipment, or maybe something else. Nonetheless, the issue has been corrected and I appreciate your help.
  6. I performed the steps suggested by LeeG with the following results: I determined that the device address was not included in the list of devices defined within ISY. I did the Diagnostics Event Viewer at Level 3 after going through the process of attempting to set up New INSTEON Device. There did not appear to be any log entries of the attempt to set up the new device. The event trace log is attached. Another thing that happened is I got an error message that said "Discovering Nodes; Retry!". I pressed "OK" and that message went away.
  7. I just tried the suggestion made by TheSidewinder but it did not work for me. The OutletLinc device still does not show up in ISY's list of devices???
  8. I installed an INSTEON OutletLinc On/Off Outlet, Model 2473S, and tested that it turned the load on and off as it should when I pressed the Set button on the OutletLinc device. Then I tried to set up the OutletLinc device in my ISY system by doing the following: Select “Link Management†Then, select “New INSTEON Device†Then, fill out the window as shown below: Then, select “OK†The “New INSTEON Device†window goes away but I don’t get any messages that linking is happening. I just get my normal list of devices with status, etc. and the new device “Landscape Lights†is not listed. I have linked the OutletLinc device to a Mini Remote and tested that the OutletLinc device responds appropriately to the Mini Remote by turning the OutletLinc responder on and off using the Mini Remote as the controller. They work together like they should. Why is this new OutletLinc device not showing up in ISY after I go through the process of setting up the device in my ISY system following the Link Management process?
  9. Thank you. It is working now.
  10. Okay -- I get it that the folder should not be deleted and I like the idea of placing a "~" as a prefix to the name for filtering purposes. BUT, is "DR" an abbreviation for something and, if so, what does "DR" stand for?
  11. When attempting to test my email in Configuration, then Emails/Notification and then selecting Test, I get the error message shown in the attached file. What am I likely doing wrong and how do I go about correcting the problem? ISY - Email Error.tiff
  12. When I open the Main tab within ISY there is a folder named "Auto DR". What does that mean? Can I safely delete it?
  13. I purchased Mobilinc Pro for use on my iPhone. The first step to get it set up is to purchase and install the Mobilinc Connect Module through the ISY Admin Console. When I attempt to do that by selecting Help, then Purchase Modules the drop down menu under Help just goes away and ISY does not take me to a site where I can purchase the Mobilinc Connect Module. What can I do to successfully purchase and install the Mobilinc Connect Module so my ISY system will recognize it and allow me to use the Mobilinc Pro app on my iPhone?
  14. When I attempt to set up internet access by selecting File, Enable Internet Access I receive an error message saying 'Failed Enabling Internet Access'. How do I resolve this issue and get internet access? ISYi/IR PRO Firmware: Insteon_UD994 v.4.0.5
