SomeWhatLost
  1. looking through the forums, I think I have concluded that this is a router config issue, but I am still confused about it... basically it stopped working about the same time I switched from AT&T DSL to WoW Cable (2x the speed and $10 less a month... seemed like a god idea at the time) the only config in the router that I changed at that time was I switched from PPoE to DHCP I tried both the pool.ntp (I forget the exact address it was, but it is the 'stock' one that worked with AT&T) and time.nist.gov neither can find the server... I am running firmware version 2.8.16 if that matters, although I am mostly convinced it has to be a router issue, or WoW is defective in some way?... so I doubt the isy FW version matters... also I haven't kept up with firmware, is that still a 'good' one? or is there better ones out now?
  2. 64bit java did not work... (ie nothing has changed... not any worse, but not any better either) anymore ideas?
  3. maybe the 64bit java will help ( I will try when I get home), but even so, why did it work Friday just fine? but Saturday was no go? I didn't start doing anything with java until Sunday... wonder if there was a virus update Friday night/Saturday morning? or a window update?
  4. eh, minutes, seconds, whats the difference? but, 28-57 years before replacement isn't that bad... and really I was just curious....
  5. this may seem like a stupid question, and that probably is because it is but still, how long will an insteon relay last if you cycle it on/off every thirty seconds? that would be 86400 cycles per day assuming my math is right, and you don't turn the fan on and just let it run... is an insteon relay like a normal relay that has a rated life around a around a million cycles or so? if so doesn't that mean you will go through relays every 12 days or so? even assuming it is rated for like 100 million cycle, that's every 3 years you need to replace the relay? are they easy to get too? or do insteon relays have an infinite amount of cycle in them? just curious really?
  6. correct just a quick run down of where we are at so far: it worked just fine Friday, did not work Saturday... doesn't work with either direct IP or from http://www.universal-devices.com/99i windows firewall on/off has no effect... IE and FF fail to work exactly the same... it is only the Administrative Console that does not work... cleared browser cache (FF only) & java cache, still no workie... reinstalled Java (from UDI website) no help... it is not the ISY itself as it works fine from a different PC (my server) running v2.6.7 my desktop (where it does not work) is running win x64 XP Pro...
  7. nope, both are just running the windows firewall... I tried turning it off, and still no go...
  8. the behavior is the same when I use IE7 as it is with FF 3.0.1, I would think that rules out FF as the culprit? Java is the same as you have posted, I tried re-installing it from your web site and it claimed it was the same... I set up my isy with a static IP, just so I always know where it is at... anyway, I just connect straight to it... 192.168.1.60 (my dhcp is between .100 to .200) I did try connecting through /99i and that had the same results. also, the only thing that doesn't work is the administrative option, the devices/scenes/programs options all work fine...
  9. my isy finally showed up! but now I have a problem, yesterday everything was fine, today I can not get into the Administrative Console anymore, it just locks up my browser (firefox) and just doesn't work... I am guessing its some Java issue, as I can get to the ISY just fine from a different PC... but I have cleared my cache, and still no luck
  10. it wont see anything, and i can't even see it... it wont even reboot... of course, that could be because those evil smarthome people haven't shipped it yet of course, I guess why they haven't shipped it is because I also ordered a couple of those motion detector things (they looked cool, I couldn't help myself...), and they like to consolidate the shipping... I should of read the fine print so, while I am waiting impatiently, is there anything i can do to make the wait less painful??? anything i should know to get ready?
