Roadrunner
Everything posted by Roadrunner
  1. Ok, thanks for the clarification
  2. If I understand you correctly, there is no way for the KPLs to indicate the proper status of a connected device if that device is controlled through the Administrative Console or MobiLinc?
  3. I recently added a ISY to an existing Insteon network. I added ISY scenes involving KPLs and while the devices respond properly to the KPL button pushes, the KPL button lights do not follow changes made remotely through the ISY. For example: - A lamp is plugged into a LampLinc. - Lamp is controlled by two different KPLs. - Lamp responds properly to both KPLs, and KPLs show proper device status. - A "Lamp" scene was created in the ISY with the two KPLs as Controllers and the LampLinc as a Responder. Problem: The button lights on the KPLs do not respond when the Lamp is turned on or off through the Administrative Console or MobiLinc. The Membership for the KPLs say the KPL "Is Controller for Lamp" and "Is Responder to Lamp" Any thoughts?
