iglon
Everything posted by iglon
  1. it has been more than a few years since I upgraded ISY to its current version is 5.0.16C. I help-> about show that it is ISY 994i (1120) is there a newer firmware that I could use? if so, where do I download it? thanks for any help.
  2. thanks for providing in-depth explanation, I have lot better understanding how can you troubleshot the problems . is ISY considered the controller and device that receive command are considered to be responders? What is PLM considered to be - both? how come one of my 2456s3 appliance switches has only controller link record, no responder link record?
  3. yes, that is PLM. so, how would it display if there was the error? please take a look at my devices (tools --> diagnostics --> show PLM links table) and tell me if you see any errors (some devices have multiple IDs) . Is that normal? I know that thermostat shows 3 links but I am not sure if the rest of devices need to show that? what are those numbers before and after hardware addresses (in yellow highlight)?
  4. Ok, I have done that can you please elaborate how to decipher this: http://s27.postimg.org/iwadf3snn/ufo_light.png (sorry, do not know how to embed the image on this forum)
  5. ok, this is easy enough to do on all devices that I have but one. how can I factory reset the device if I do not have easy physical access to it? say, this device is in attic and I really do not want to bring the ladder and crawl up there so that I can hit the reset button for 5 seconds. (I presume that is the only way to factory reset the device) is there a way that I can tell if this hard to reach device has any links to old devices?
  6. finally! I got it to work. I received a new type of on/off module (2635-222 dual band) and added it it without a problem, Then I decided to move my older (troubled) modules to same area, same physical outlet, which happens to be on upper floor and quite away from PLM that is in my garage, next to ISY. so, after fiddling with linking process a few times I was able to add those modules to my setup and they seem to work just fine, no issues, no errors. tonight I will try to move those 2 older modules to my garage, next to PLM and to my living room see if they still work. This got me now puzzled :-/ thanks everyone for trying to help me and giving me pointers. BTW, one of the older modules had information about insteon hub that it was previously connected to (I have all of the MAC addresses of my insteon devices documented so I know it was an insteon hub) apparently, this caused the conflict with my dual band dimmer that was at one time connected to same hub. It took me awhile to fix this (restored the ISY config and cleaned up devices) but all seem to be good now. I probably need to make sure that all of my insteon devices are "clean" of information that pertains to old smartlinc controller and insteon hub that they were communicating with at one time. So, what is the best way to go about it, just to make sure that all of my insteon devices have no information on other controllers but ISY?
  7. I tried moving both of the modules to same outlet where powerlinc is plugged into but I am getting the same error. is is possible that ISY cannot understand appliancelinc's version of firmware? Those 2 appliancelinc modules used to work with insteon controller so I am guessing that maybe firmware version could be the issue.
  8. same appliance link, autodiscover mode: Tue 02/18/2014 06:40:27 PM : [11 57 99 ] Added to list of devices to link to ISY Tue 02/18/2014 06:40:27 PM : [iNST-TX-I1 ] 02 62 11 57 99 0F 0D 00 Tue 02/18/2014 06:40:27 PM : [iNST-ACK ] 02 62 11.57.99 0F 0D 00 06 (00) Tue 02/18/2014 06:40:36 PM : [iNST-TX-I1 ] 02 62 11 57 99 0F 0D 00 Tue 02/18/2014 06:40:36 PM : [iNST-ACK ] 02 62 11.57.99 0F 0D 00 06 (00) Tue 02/18/2014 06:40:42 PM : [iNST-SRX ] 02 50 1E.0C.0D 2A.1F.B3 01 6F 35 (35) Tue 02/18/2014 06:40:42 PM : [std-Direct ] 1E.0C.0D-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Tue 02/18/2014 06:40:42 PM : [ 1E C D 1] CLIHUM 53 Tue 02/18/2014 06:40:45 PM : [iNST-TX-I1 ] 02 62 11 57 99 0F 0D 00 Tue 02/18/2014 06:40:45 PM : [iNST-ACK ] 02 62 11.57.99 0F 0D 00 06 (00) Tue 02/18/2014 06:40:49 PM : [11 57 99 0 ] Failed to add device, reason 3 Tue 02/18/2014 06:40:49 PM : [All ] Writing 0 bytes to devices
  9. and this is another appliancelinc module: Tue 02/18/2014 06:35:57 PM : [ Time] 18:36:03 3(0) Tue 02/18/2014 06:36:24 PM : [11 57 99 ] Added to list of devices to link to ISY Tue 02/18/2014 06:36:24 PM : [iNST-TX-I1 ] 02 62 11 57 99 0F 0D 00 Tue 02/18/2014 06:36:24 PM : [iNST-ACK ] 02 62 11.57.99 0F 0D 00 06 (00) Tue 02/18/2014 06:36:33 PM : [iNST-TX-I1 ] 02 62 11 57 99 0F 0D 00 Tue 02/18/2014 06:36:33 PM : [iNST-ACK ] 02 62 11.57.99 0F 0D 00 06 (00) Tue 02/18/2014 06:36:42 PM : [iNST-TX-I1 ] 02 62 11 57 99 0F 0D 00 Tue 02/18/2014 06:36:42 PM : [iNST-ACK ] 02 62 11.57.99 0F 0D 00 06 (00) Tue 02/18/2014 06:36:46 PM : [11 57 99 0 ] Failed to add device, reason 3 Tue 02/18/2014 06:36:46 PM : [All ] Writing 0 bytes to devices
  10. here it is: Tue 02/18/2014 06:27:47 PM : [FileOpen ] Open failed for [/CONF/ELEC.CFG] ® Tue 02/18/2014 06:28:25 PM : Start Insteon Device Linking Mode Tue 02/18/2014 06:28:25 PM : [LNK-BGN ] 02 64 01 00 06 Tue 02/18/2014 06:28:29 PM : Stop Insteon Device Linking Mode, Final processing to follow Tue 02/18/2014 06:28:29 PM : ---- Start: Generate Scenes from links ---- Tue 02/18/2014 06:28:29 PM : [LNK-END ] 02 65 06 : : Unexpected, ignored (65) Tue 02/18/2014 06:28:29 PM : ---- End: Generate Scenes from links ---- Tue 02/18/2014 06:28:29 PM : [All ] Writing 0 bytes to devices Tue 02/18/2014 06:28:29 PM : [All ] Writing 0 bytes to devices Tue 02/18/2014 06:29:43 PM : [20 b9 9d ] Added to list of devices to link to ISY Tue 02/18/2014 06:29:43 PM : [iNST-TX-I1 ] 02 62 20 B9 9D 0F 0D 00 Tue 02/18/2014 06:29:43 PM : [iNST-ACK ] 02 62 20.B9.9D 0F 0D 00 06 (00) Tue 02/18/2014 06:29:52 PM : [iNST-TX-I1 ] 02 62 20 B9 9D 0F 0D 00 Tue 02/18/2014 06:29:52 PM : [iNST-ACK ] 02 62 20.B9.9D 0F 0D 00 06 (00) Tue 02/18/2014 06:30:01 PM : [iNST-TX-I1 ] 02 62 20 B9 9D 0F 0D 00 Tue 02/18/2014 06:30:01 PM : [iNST-ACK ] 02 62 20.B9.9D 0F 0D 00 06 (00) Tue 02/18/2014 06:30:05 PM : [20 B9 9D 0 ] Failed to add device, reason 3 Tue 02/18/2014 06:30:05 PM : ---- Start: Generate Scenes from links ---- Tue 02/18/2014 06:30:05 PM : ---- End: Generate Scenes from links ---- Tue 02/18/2014 06:30:05 PM : [All ] Writing 0 bytes to devices
  11. I see -- the level must be set before I try to add the device -- that explains it. I will try to do this as soon as I get home. Thanks!
  12. yes, this was additional information, I already posted level3 log here it is again: ---------------------------------------------------- Mon 02/17/2014 07:12:42 PM : [20 b9 9d ] Added to list of devices to link to ISY Mon 02/17/2014 07:13:03 PM : [20 B9 9D 0 ] Failed to add device, reason 3 Mon 02/17/2014 07:13:03 PM : ---- Start: Generate Scenes from links ---- Mon 02/17/2014 07:13:04 PM : ---- End: Generate Scenes from links ---- Mon 02/17/2014 07:13:04 PM : [All ] Writing 0 bytes to devices --------------------- that was level3 log that I have accessed from TOOLS --> DIAGNOSTICS --> EVENT VIEWER --> selected Device/level 3 communication events and saved it to my desktop to a file named ISY-Events-Log.v4.1.2__Mon 2014.02.17 07.18.07 PM.txt. After I posted this I was asked by Michael to run/post level3 results and since I did not know what other level 3 log to post I have tried posting the error log hoping that it would have information that he requested. I am kind of confused as what level3 we are referring to now. Is there other level3 log that I need to access?
  13. hi Michael how do I change to level3? I thought that level3 was just the type of event log that I can select. from ISY window I selected tools --> diagnostic --> event viewer --> level 3 --> saved to a file and I posted the contents of that file to this thread. maybe there is something else I need to do?! here is the error log if that helps: Time User Code Message Thu 2013/12/12 05:50:49 PM System -5 Start Thu 2013/12/12 05:50:50 PM System -110022 /CONF/INSTENG.OPT Thu 2013/12/12 05:50:50 PM System -110012 /CONF/INSTENG.OPT Thu 2013/12/12 05:50:51 PM System -170001 [Network] Established Mon 2013/12/30 07:30:37 AM System -5 Start Mon 2013/12/30 07:30:57 AM System -110022 /CONF/INSTENG.OPT Mon 2013/12/30 07:30:57 AM System -110012 /CONF/INSTENG.OPT Mon 2013/12/30 07:30:57 AM System -100 No network connection Mon 2013/12/30 07:32:22 AM System -100 [DHCP] state=NOT STARTED Mon 2013/12/30 07:32:30 AM System -170001 [Network] Established Thu 2014/01/02 06:03:30 PM System -5 Start Thu 2014/01/02 06:03:31 PM System -110022 /CONF/INSTENG.OPT Thu 2014/01/02 06:03:31 PM System -110012 /CONF/INSTENG.OPT Thu 2014/01/02 06:03:31 PM System -170001 [Network] Established Thu 2014/01/02 06:10:15 PM System -5 Start Thu 2014/01/02 06:10:21 PM System -110022 /CONF/INSTENG.OPT Thu 2014/01/02 06:10:21 PM System -110012 /CONF/INSTENG.OPT Thu 2014/01/02 06:10:21 PM System -170001 [Network] Established Thu 2014/01/02 07:01:53 PM System -10011 n/a Thu 2014/01/02 07:37:10 PM System -5012 28 Thu 2014/01/02 08:50:54 PM System -5012 31 Thu 2014/01/02 10:03:06 PM System -5012 37 Thu 2014/01/02 11:52:47 PM System -5012 29 Thu 2014/01/02 11:54:56 PM System -5006 uuid:37 Thu 2014/01/02 11:54:57 PM System -5006 uuid:37 Fri 2014/01/03 08:05:32 AM System -5012 42 Fri 2014/01/03 08:17:37 AM System -5012 43 Fri 2014/01/03 06:28:08 PM System -5012 47 Fri 2014/01/03 07:31:09 PM System -5012 50 Fri 2014/01/03 07:38:31 PM System -170001 [HTTP] 192.168.200.126:58124->80 Fri 2014/01/03 07:38:35 PM System -170001 [HTTP] 192.168.200.126:58125->80 Fri 2014/01/03 07:38:38 PM System -170001 [HTTP] 192.168.200.126:58128->80 Fri 2014/01/03 07:38:39 PM System -170001 [HTTP] 192.168.200.126:58129->80 Fri 2014/01/03 07:38:39 PM System -170001 [HTTP] 192.168.200.126:58130->80 Fri 2014/01/03 07:38:43 PM System -170001 [HTTP] 192.168.200.126:58131->80 Fri 2014/01/03 07:38:48 PM System -170001 [HTTP] 192.168.200.126:58134->80 Fri 2014/01/03 07:38:48 PM System -170001 [HTTP] 192.168.200.126:58135->80 Fri 2014/01/03 07:38:48 PM System -170001 [HTTP] 192.168.200.126:58136->80 Fri 2014/01/03 07:38:52 PM System -170001 [HTTP] 192.168.200.126:58137->80 Fri 2014/01/03 07:38:56 PM System -170001 [HTTP] 192.168.200.126:58140->80 Fri 2014/01/03 07:38:57 PM System -170001 [HTTP] 192.168.200.126:58141->80 Fri 2014/01/03 07:38:57 PM System -170001 [HTTP] 192.168.200.126:58142->80 Fri 2014/01/03 07:39:01 PM System -170001 [HTTP] 192.168.200.126:58143->80 Fri 2014/01/03 07:39:03 PM System -170001 [HTTP] 192.168.200.126:58146->80 Fri 2014/01/03 07:39:04 PM System -170001 [HTTP] 192.168.200.126:58147->80 Fri 2014/01/03 07:39:04 PM System -170001 [HTTP] 192.168.200.126:58148->80 Fri 2014/01/03 07:39:08 PM System -170001 [HTTP] 192.168.200.126:58149->80 Fri 2014/01/03 07:39:11 PM System -170001 [HTTP] 192.168.200.126:58152->80 Fri 2014/01/03 07:39:11 PM System -170001 [HTTP] 192.168.200.126:58153->80 Fri 2014/01/03 07:39:12 PM System -170001 [HTTP] 192.168.200.126:58154->80 Fri 2014/01/03 07:39:16 PM System -170001 [HTTP] 192.168.200.126:58155->80 Fri 2014/01/03 07:39:24 PM System -170001 [HTTP] 192.168.200.126:58158->80 Fri 2014/01/03 07:39:24 PM System -170001 [HTTP] 192.168.200.126:58159->80 Fri 2014/01/03 07:39:24 PM System -170001 [HTTP] 192.168.200.126:58160->80 Fri 2014/01/03 07:39:28 PM System -170001 [HTTP] 192.168.200.126:58161->80 Fri 2014/01/03 07:39:35 PM System -170001 [HTTP] 192.168.200.126:58164->80 Fri 2014/01/03 07:39:36 PM System -170001 [HTTP]: GET-->/WEB/CLOSE.HTM Fri 2014/01/03 07:39:36 PM System -170001 [HTTP] Socket error Fri 2014/01/03 07:39:36 PM System -170001 [HTTP] Closing socket w/failure Fri 2014/01/03 07:39:36 PM System -170001 [HTTP] 192.168.200.126:58165->80 Fri 2014/01/03 07:39:36 PM System -170001 [HTTP] 192.168.200.126:58168->80 Fri 2014/01/03 07:39:36 PM System -170001 [HTTP]: GET-->/WEB/CLOSE.HTM Fri 2014/01/03 07:39:36 PM System -170001 [HTTP] Socket error Fri 2014/01/03 07:39:36 PM System -170001 [HTTP] Closing socket w/failure Fri 2014/01/03 07:39:36 PM System -170001 [HTTP] 192.168.200.126:58169->80 Fri 2014/01/03 07:39:47 PM System -170001 [HTTP] 192.168.200.126:58170->80 Fri 2014/01/03 07:39:47 PM System -170001 [HTTP]: GET-->/admin Fri 2014/01/03 07:39:47 PM System -170001 [HTTP]: GET-->/web/udlogo.jpg Fri 2014/01/03 07:39:48 PM System -170001 [HTTP] Socket error Fri 2014/01/03 07:39:48 PM System -170001 [HTTP] Closing socket w/failure Fri 2014/01/03 07:39:48 PM System -170001 [HTTP] 192.168.200.126:58192->80 Fri 2014/01/03 07:39:48 PM System -170001 [HTTP]: GET-->/web/insteon.jar Fri 2014/01/03 07:39:49 PM System -170001 [HTTP] Closing socket normally Fri 2014/01/03 07:39:50 PM System -170001 [HTTP] 192.168.200.126:58219->80 Fri 2014/01/03 07:39:50 PM System -170001 [HTTP]: GET-->/admin Fri 2014/01/03 07:39:50 PM System -170001 [HTTP]: GET-->/web/udlogo.jpg Fri 2014/01/03 07:39:50 PM System -170001 [HTTP] Socket error Fri 2014/01/03 07:39:50 PM System -170001 [HTTP] Closing socket w/failure Fri 2014/01/03 07:39:51 PM System -170001 [HTTP] 192.168.200.126:58220->80 Fri 2014/01/03 07:39:51 PM System -170001 [HTTP]: GET-->/desc Fri 2014/01/03 07:39:51 PM System -170001 [HTTP] 192.168.200.126:58223->80 Fri 2014/01/03 07:39:51 PM System -170001 [HTTP] 192.168.200.126:58224->80 Fri 2014/01/03 07:39:51 PM System -170001 [HTTP]: GET-->/desc Fri 2014/01/03 07:39:51 PM System -170001 [HTTP] 192.168.200.126:58227->80 Fri 2014/01/03 07:40:00 PM System -170001 [HTTP] 192.168.200.126:58229->80 Fri 2014/01/03 07:40:01 PM System -170001 [HTTP] 192.168.200.126:58232->80 Fri 2014/01/03 07:40:01 PM System -170001 [HTTP] 192.168.200.126:58233->80 Fri 2014/01/03 07:40:31 PM System -170001 [HTTP] 192.168.200.126:58234->80 Fri 2014/01/03 07:40:31 PM System -170001 [HTTP]: GET-->/WEB/CLOSE.HTM Fri 2014/01/03 07:40:31 PM System -170001 [HTTP] Socket error Fri 2014/01/03 07:40:31 PM System -170001 [HTTP] Closing socket w/failure Fri 2014/01/03 07:41:17 PM System -170001 [HTTP] 192.168.200.126:58236->80 Fri 2014/01/03 07:41:17 PM System -170001 [HTTP]: GET-->/admin Fri 2014/01/03 07:41:17 PM System -170001 [HTTP]: GET-->/web/udlogo.jpg Fri 2014/01/03 07:41:17 PM System -170001 [HTTP] Socket error Fri 2014/01/03 07:41:17 PM System -170001 [HTTP] Closing socket w/failure Fri 2014/01/03 07:41:17 PM System -170001 [HTTP] 192.168.200.126:58237->80 Fri 2014/01/03 07:41:18 PM System -170001 [HTTP]: GET-->/web/insteon.jar Fri 2014/01/03 07:41:18 PM System -170001 [HTTP] Closing socket normally Fri 2014/01/03 07:41:19 PM System -170001 [HTTP] 192.168.200.126:58239->80 Fri 2014/01/03 07:41:19 PM System -170001 [HTTP]: GET-->/desc Fri 2014/01/03 07:41:19 PM System -170001 [HTTP] 192.168.200.126:58242->80 Fri 2014/01/03 07:41:28 PM System -170001 [HTTP] 192.168.200.126:58243->80 Fri 2014/01/03 07:41:28 PM System -170001 [HTTP] 192.168.200.126:58246->80 Fri 2014/01/03 07:41:28 PM System -170001 [HTTP] 192.168.200.126:58247->80 Fri 2014/01/03 07:41:29 PM System -170001 [HTTP] 192.168.200.126:58248->80 Fri 2014/01/03 07:41:29 PM System -170001 [HTTP]: GET-->/WEB/LATLONG.XML Fri 2014/01/03 07:41:29 PM System -170001 [HTTP] 192.168.200.126:58249->80 Fri 2014/01/03 07:41:29 PM System -170001 [HTTP] 192.168.200.126:58250->80 Fri 2014/01/03 07:44:25 PM System -170001 [uDSockets] RSub:27 error:6 Fri 2014/01/03 07:44:30 PM System -170001 [uDSockets] RSub:27 error:6 Fri 2014/01/03 07:44:35 PM System -5012 51 Fri 2014/01/03 07:45:20 PM System -170001 [uDSockets] RSub:27 error:6 Fri 2014/01/03 07:45:25 PM System -5012 52 Fri 2014/01/03 07:50:10 PM System -170001 [uDSockets] RSub:30 error:6 Fri 2014/01/03 07:50:15 PM System -170001 [uDSockets] RSub:30 error:6 Fri 2014/01/03 07:50:20 PM System -170001 [uDSockets] RSub:30 error:6 Fri 2014/01/03 07:50:25 PM System -5012 54 Fri 2014/01/03 07:52:05 PM System -5012 55 Sat 2014/01/04 02:34:29 PM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/04 02:34:34 PM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/04 02:34:39 PM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/04 02:34:44 PM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/04 02:34:49 PM System -5012 65 Sat 2014/01/04 03:25:00 PM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/04 03:25:05 PM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/04 03:25:10 PM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/04 03:25:15 PM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/04 03:25:20 PM System -5012 66 Sat 2014/01/04 05:00:01 PM System -5006 uuid:66 Sat 2014/01/04 05:00:03 PM System -5006 uuid:66 Sat 2014/01/04 09:15:04 PM System -5012 69 Sat 2014/01/04 09:15:04 PM System -5006 uuid:69 Sat 2014/01/04 09:15:05 PM System -5006 uuid:69 Sat 2014/01/04 10:06:21 PM System -5012 73 Sun 2014/01/05 09:05:26 AM System -170001 [uDSockets] RSub:33 error:6 Sun 2014/01/05 09:05:31 AM System -5012 79 Sun 2014/01/05 10:50:15 AM System -5006 uuid:79 Sun 2014/01/05 10:50:16 AM System -5006 uuid:79 Sun 2014/01/05 12:01:45 PM System -5012 81 Sun 2014/01/05 12:10:11 PM System -5012 82 Sun 2014/01/05 04:34:00 PM System -5012 83 Mon 2014/01/06 07:54:56 AM System -170001 [uDSockets] RSub:31 error:6 Mon 2014/01/06 07:55:01 AM System -170001 [uDSockets] RSub:31 error:6 Mon 2014/01/06 07:55:06 AM System -170001 [uDSockets] RSub:31 error:6 Mon 2014/01/06 07:55:11 AM System -5012 88 Mon 2014/01/06 08:04:03 AM System -5006 uuid:88 Mon 2014/01/06 08:04:04 AM System -5006 uuid:88 Mon 2014/01/06 11:56:34 PM System -5012 91 Tue 2014/01/07 07:42:24 PM System -170001 [uDSockets] RSub:32 error:6 Tue 2014/01/07 07:42:28 PM System -5012 92 Tue 2014/01/07 07:42:29 PM System -5006 uuid:92 Tue 2014/01/07 07:42:30 PM System -5006 uuid:92 Wed 2014/01/08 07:27:18 PM System -170001 [uDSockets] RSub:32 error:6 Wed 2014/01/08 07:27:23 PM System -170001 [uDSockets] RSub:32 error:6 Wed 2014/01/08 07:27:28 PM System -5012 98 Wed 2014/01/08 09:09:19 PM System -60001 pool.ntp.org Wed 2014/01/08 09:09:29 PM System -60001 pool.ntp.org Wed 2014/01/08 09:09:39 PM System -60001 pool.ntp.org Wed 2014/01/08 09:09:49 PM System -60001 pool.ntp.org Wed 2014/01/08 09:09:59 PM System -60001 pool.ntp.org Wed 2014/01/08 09:10:09 PM System -60001 pool.ntp.org Wed 2014/01/08 09:10:09 PM System -60006 Stopping retries/next cycle Wed 2014/01/08 09:32:30 PM System -5006 uuid:98 Wed 2014/01/08 09:32:31 PM System -5006 uuid:98 Thu 2014/01/09 03:23:54 AM System -170001 [uDSockets] RSub:32 error:6 Thu 2014/01/09 03:23:59 AM System -170001 [uDSockets] RSub:32 error:6 Thu 2014/01/09 03:24:04 AM System -170001 [uDSockets] RSub:32 error:6 Thu 2014/01/09 03:24:09 AM System -5012 101 Thu 2014/01/09 07:58:24 AM System -5006 uuid:101 Thu 2014/01/09 07:58:25 AM System -5006 uuid:101 Thu 2014/01/09 08:31:50 AM System -170001 [uDSockets] RSub:30 error:6 Thu 2014/01/09 08:31:55 AM System -170001 [uDSockets] RSub:30 error:6 Thu 2014/01/09 08:32:00 AM System -170001 [uDSockets] RSub:30 error:6 Thu 2014/01/09 08:32:05 AM System -5012 103 Thu 2014/01/09 10:12:15 PM System -100 No network connection Thu 2014/01/09 10:12:20 PM System -170001 [Network] Established Fri 2014/01/10 09:11:30 PM System -60001 pool.ntp.org Fri 2014/01/10 09:11:40 PM System -60001 pool.ntp.org Fri 2014/01/10 09:11:50 PM System -60001 pool.ntp.org Fri 2014/01/10 09:12:00 PM System -60001 pool.ntp.org Fri 2014/01/10 09:12:10 PM System -60001 pool.ntp.org Fri 2014/01/10 09:12:20 PM System -60001 pool.ntp.org Fri 2014/01/10 09:12:20 PM System -60006 Stopping retries/next cycle Fri 2014/01/10 10:12:01 PM System -170001 [uDSockets] RSub:27 error:6 Fri 2014/01/10 10:12:06 PM System -170001 [uDSockets] RSub:27 error:6 Fri 2014/01/10 10:12:11 PM System -5012 106 Sat 2014/01/11 08:14:33 AM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/11 08:14:38 AM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/11 08:14:43 AM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/11 08:14:48 AM System -170001 [uDSockets] RSub:27 error:6 Sat 2014/01/11 08:14:51 AM System -5012 107 Sat 2014/01/11 08:23:23 AM System -5006 uuid:107 Sat 2014/01/11 08:23:24 AM System -5006 uuid:107 Sat 2014/01/11 12:10:30 PM System -5012 109 Sat 2014/01/11 09:13:10 PM System -60001 pool.ntp.org Sat 2014/01/11 09:13:20 PM System -60001 pool.ntp.org Sat 2014/01/11 09:13:30 PM System -60001 pool.ntp.org Sat 2014/01/11 09:13:40 PM System -60001 pool.ntp.org Sat 2014/01/11 09:13:50 PM System -170001 [Network] Failed DNS 11 Sat 2014/01/11 09:13:50 PM System -60001 pool.ntp.org Sat 2014/01/11 09:14:00 PM System -170001 [Network] Failed DNS 12 Sat 2014/01/11 09:14:00 PM System -60001 pool.ntp.org Sat 2014/01/11 09:14:00 PM System -60006 Stopping retries/next cycle Sun 2014/01/12 12:22:14 AM System -100 No network connection Sun 2014/01/12 12:22:45 AM System -5 Start Sun 2014/01/12 12:22:46 AM System -170001 [Network] Established Sun 2014/01/12 12:23:03 AM System -60001 pool.ntp.org Sun 2014/01/12 12:23:08 AM System -100 No network connection Sun 2014/01/12 12:27:32 AM System -5 Start Sun 2014/01/12 12:27:34 AM System -170001 [Network] Established Sun 2014/01/12 12:27:50 AM System -60001 pool.ntp.org Sun 2014/01/12 12:34:32 AM System -5012 27 Sun 2014/01/12 12:36:34 AM System -5012 29 Sun 2014/01/12 12:38:14 AM System -5012 26 Sun 2014/01/12 12:43:49 AM System -170001 [uDSockets] RSub:31 error:6 Sun 2014/01/12 12:43:53 AM System -5012 31 Sun 2014/01/12 12:44:24 AM System -5012 32 Sun 2014/01/12 12:46:26 AM System -5012 33 Sun 2014/01/12 10:56:00 AM System -5012 36 Tue 2014/01/14 08:04:33 AM System -5012 46 Mon 2014/01/20 12:32:53 AM System -60006 n/a Wed 2014/01/22 07:30:30 PM System -5012 54 Wed 2014/01/22 07:36:44 PM System -170001 [uDSockets] RSub:32 error:6 Wed 2014/01/22 07:36:49 PM System -5012 56 Thu 2014/01/23 12:26:55 AM System -5012 58 Thu 2014/01/23 08:10:07 AM System -5012 59 Thu 2014/01/23 08:15:32 AM System -170001 [uDSockets] RSub:27 error:6 Thu 2014/01/23 08:15:37 AM System -170001 [uDSockets] RSub:27 error:6 Thu 2014/01/23 08:15:42 AM System -170001 [uDSockets] RSub:27 error:6 Thu 2014/01/23 08:15:47 AM System -5012 60 Thu 2014/01/23 08:33:12 AM System -5006 uuid:60 Thu 2014/01/23 08:33:13 AM System -5006 uuid:60 Thu 2014/01/23 10:17:09 AM System -170001 [uDSockets] RSub:33 error:6 Thu 2014/01/23 10:17:14 AM System -170001 [uDSockets] RSub:33 error:6 Thu 2014/01/23 10:17:15 AM System -5012 63 Thu 2014/01/23 10:17:15 AM System -5012 64 Thu 2014/01/23 10:24:22 AM System -170001 [uDSockets] RSub:33 error:6 Thu 2014/01/23 10:24:27 AM System -170001 [uDSockets] RSub:33 error:6 Thu 2014/01/23 10:24:32 AM System -5012 66 Thu 2014/01/23 10:24:32 AM System -5012 67 Thu 2014/01/23 10:25:22 AM System -5012 68 Thu 2014/01/23 10:33:17 AM System -170001 [uDSockets] RSub:30 error:6 Thu 2014/01/23 10:33:22 AM System -170001 [uDSockets] RSub:30 error:6 Thu 2014/01/23 10:33:27 AM System -170001 [uDSockets] RSub:30 error:6 Thu 2014/01/23 10:33:28 AM System -5012 69 Thu 2014/01/23 10:33:28 AM System -5012 70 Thu 2014/01/23 11:07:56 AM System -5 Start Thu 2014/01/23 11:07:57 AM System -170001 [Network] Established Thu 2014/01/23 11:10:16 AM System -5 Start Thu 2014/01/23 11:10:17 AM System -170001 [Network] Established Thu 2014/01/23 11:25:16 AM System -5006 uuid:71 Thu 2014/01/23 11:25:36 AM System -5012 26 Thu 2014/01/23 11:27:31 AM System -5 Start Thu 2014/01/23 11:27:32 AM System -170001 [Network] Established Thu 2014/01/23 11:35:13 AM System -5012 26 Thu 2014/01/23 02:40:22 PM System -10011 n/a Thu 2014/01/23 04:02:59 PM System -5 Start Thu 2014/01/23 04:03:00 PM System -170001 [Network] Established Thu 2014/01/23 04:06:28 PM System -5012 26 Thu 2014/01/23 04:08:37 PM System -5012 28 Thu 2014/01/23 04:08:42 PM System -170001 [uDSockets] RSub:29 error:6 Thu 2014/01/23 04:08:47 PM System -170001 [uDSockets] RSub:29 error:6 Thu 2014/01/23 04:08:52 PM System -170001 [uDSockets] RSub:29 error:6 Thu 2014/01/23 04:08:57 PM System -170001 [uDSockets] RSub:29 error:6 Sun 2014/01/26 06:38:04 PM System -5 Start Sun 2014/01/26 06:38:05 PM System -170001 [Network] Established Sun 2014/01/26 06:38:22 PM System -60001 pool.ntp.org Sun 2014/01/26 11:22:06 PM System -5012 26 Fri 2014/01/31 08:10:31 PM System -170001 [uDSockets] RSub:33 error:6 Fri 2014/01/31 08:10:36 PM System -5012 34 Fri 2014/01/31 10:00:07 PM System -170001 [uDSockets] RSub:33 error:6 Fri 2014/01/31 10:00:10 PM System -5012 35 Mon 2014/02/03 07:31:16 PM System -5 Start Mon 2014/02/03 07:31:17 PM System -170001 [Network] Established Mon 2014/02/03 07:31:34 PM System -60001 pool.ntp.org Tue 2014/02/04 07:32:01 PM System -60001 pool.ntp.org Tue 2014/02/04 07:32:08 PM System -60001 pool.ntp.org Tue 2014/02/04 07:32:18 PM System -60001 pool.ntp.org Tue 2014/02/04 07:32:24 PM System -60001 pool.ntp.org Tue 2014/02/04 07:32:34 PM System -60001 pool.ntp.org Tue 2014/02/04 07:32:34 PM System -60006 Stopping retries/next cycle Wed 2014/02/05 07:33:24 PM System -60001 pool.ntp.org Wed 2014/02/05 07:33:31 PM System -60001 pool.ntp.org Wed 2014/02/05 07:33:41 PM System -60001 pool.ntp.org Wed 2014/02/05 07:33:47 PM System -60001 pool.ntp.org Wed 2014/02/05 07:33:57 PM System -170001 [Network] Failed DNS 11 Wed 2014/02/05 07:33:57 PM System -60001 pool.ntp.org Wed 2014/02/05 07:34:03 PM System -170001 [Network] Failed DNS 12 Wed 2014/02/05 07:34:03 PM System -60001 pool.ntp.org Wed 2014/02/05 07:34:03 PM System -60006 Stopping retries/next cycle Thu 2014/02/06 07:36:43 AM System -170001 [uDSockets] RSub:29 error:6 Thu 2014/02/06 07:36:48 AM System -170001 [uDSockets] RSub:29 error:6 Thu 2014/02/06 07:33:08 PM System -5 Start Thu 2014/02/06 07:33:09 PM System -170001 [Network] Established Thu 2014/02/06 07:33:26 PM System -60001 pool.ntp.org Thu 2014/02/06 10:18:57 PM System -5012 26 Fri 2014/02/07 09:47:35 PM System -5 Start Fri 2014/02/07 09:47:36 PM System -170001 [Network] Established Fri 2014/02/07 09:47:53 PM System -60001 pool.ntp.org Sat 2014/02/08 09:26:54 AM System -170001 [uDSockets] RSub:32 error:6 Sat 2014/02/08 09:26:59 AM System -5012 26 Sat 2014/02/08 09:27:17 AM System -5006 uuid:26 Sat 2014/02/08 09:27:18 AM System -5006 uuid:26 Sat 2014/02/08 09:19:46 PM System -100 No network connection Sat 2014/02/08 09:19:51 PM System -170001 [Network] Established Sat 2014/02/08 09:48:22 PM System -60001 pool.ntp.org Sat 2014/02/08 09:48:29 PM System -60001 pool.ntp.org Sat 2014/02/08 09:48:39 PM System -60001 pool.ntp.org Sun 2014/02/09 02:57:56 PM System -5 Start Sun 2014/02/09 02:57:57 PM System -170001 [Network] Established Sun 2014/02/09 02:58:09 PM System -100 No network connection Sun 2014/02/09 02:59:04 PM System -60001 pool.ntp.org Sun 2014/02/09 02:59:46 PM System -5 Start Sun 2014/02/09 02:59:47 PM System -170001 [Network] Established Sun 2014/02/09 02:59:54 PM System -100 No network connection Sun 2014/02/09 03:00:04 PM System -60001 pool.ntp.org Sun 2014/02/09 03:07:54 PM System -5 Start Sun 2014/02/09 03:07:55 PM System -170001 [Network] Established Sun 2014/02/09 03:08:12 PM System -60001 pool.ntp.org Mon 2014/02/10 10:28:07 PM System -5012 28 Tue 2014/02/11 03:09:02 PM System -60006 n/a Thu 2014/02/13 03:10:31 PM System -60001 pool.ntp.org Thu 2014/02/13 03:10:41 PM System -60001 pool.ntp.org Thu 2014/02/13 03:10:51 PM System -60001 pool.ntp.org Thu 2014/02/13 03:11:01 PM System -60001 pool.ntp.org Thu 2014/02/13 03:11:01 PM System -60006 Stopping retries/next cycle Fri 2014/02/14 03:11:49 PM System -60001 pool.ntp.org Fri 2014/02/14 03:11:59 PM System -60001 pool.ntp.org Fri 2014/02/14 03:12:09 PM System -60001 pool.ntp.org Fri 2014/02/14 03:12:19 PM System -60001 pool.ntp.org Fri 2014/02/14 03:12:29 PM System -60001 pool.ntp.org Fri 2014/02/14 03:12:39 PM System -60001 pool.ntp.org Fri 2014/02/14 03:12:39 PM System -60006 Stopping retries/next cycle Fri 2014/02/14 08:11:11 PM System -170001 [Auth] 192.168.200.132:49416->80, Num=3 Fri 2014/02/14 08:27:21 PM System -170001 [Auth] 192.168.200.133:49205->80, Num=4 Sat 2014/02/15 04:40:23 AM System -170001 [Auth] 65.255.195.132:40641->443, Num=5 Sat 2014/02/15 10:16:58 AM System -170001 [Auth] 192.168.200.8:49264->80, Num=6 Sat 2014/02/15 10:16:58 AM System -10108 Check log Sat 2014/02/15 10:30:45 AM System -5 Start Sat 2014/02/15 10:30:46 AM System -170001 [Network] Established Sat 2014/02/15 10:30:51 AM System -60001 pool.ntp.org Sat 2014/02/15 10:30:56 AM System -60001 pool.ntp.org Sat 2014/02/15 10:31:08 AM System -60001 pool.ntp.org Sat 2014/02/15 10:31:18 AM System -60001 pool.ntp.org Sat 2014/02/15 10:31:28 AM System -60001 pool.ntp.org Sat 2014/02/15 10:31:38 AM System -60001 pool.ntp.org Sat 2014/02/15 10:31:38 AM System -60006 Stopping retries/next cycle Sat 2014/02/15 10:37:19 AM System -5 Start Sat 2014/02/15 10:37:20 AM System -170001 [Network] Established Sat 2014/02/15 07:55:20 PM System -170001 [uDSockets] RSub:29 error:6 Sat 2014/02/15 07:55:25 PM System -170001 [uDSockets] RSub:29 error:6 Sat 2014/02/15 07:55:30 PM System -170001 [uDSockets] RSub:29 error:6 Sat 2014/02/15 07:55:35 PM System -170001 [uDSockets] RSub:29 error:6 Sat 2014/02/15 07:55:40 PM System -5012 26 Mon 2014/02/17 11:03:00 AM System -170001 [HTTP] 192.168.200.8:53875->80 Mon 2014/02/17 11:03:00 AM System -170001 [HTTP]: POST[1]-->/services Mon 2014/02/17 11:03:00 AM System -170001 Mon 2014/02/17 01:03:02 PM System -170001 [HTTP] 192.168.200.8:54025->80 Mon 2014/02/17 01:03:02 PM System -170001 [HTTP]: POST[1]-->/services Mon 2014/02/17 01:03:02 PM System -170001 Mon 2014/02/17 02:31:02 PM System -170001 [HTTP] 192.168.200.8:54446->80 Mon 2014/02/17 02:31:02 PM System -170001 [HTTP]: POST[1]-->/services Mon 2014/02/17 02:31:02 PM System -170001 Mon 2014/02/17 07:18:11 PM System -170001 [HTTP] 192.168.200.8:57972->80 Mon 2014/02/17 07:18:11 PM System -170001 [HTTP]: POST[1]-->/services Mon 2014/02/17 07:18:11 PM System -170001
  14. hi Michael, here is event log level 3: Mon 02/17/2014 07:12:42 PM : [20 b9 9d ] Added to list of devices to link to ISY Mon 02/17/2014 07:13:03 PM : [20 B9 9D 0 ] Failed to add device, reason 3 Mon 02/17/2014 07:13:03 PM : ---- Start: Generate Scenes from links ---- Mon 02/17/2014 07:13:04 PM : ---- End: Generate Scenes from links ---- Mon 02/17/2014 07:13:04 PM : [All ] Writing 0 bytes to devices ====
  15. sorry, my bad. I have 2 older 2456S3 modules, and I was trying not to spend the money on new dual band 2635-222 modules. I will probably buy at least one new module anyways, but I would like to put to good use those older 2456S3 appliance modules.
  16. I will do that as soon as I am at home. thanks!
  17. I upgraded the firmware successfully and then I tried adding applianelinc modules. one module has firmware version 4.1, other has version 4.9 I tried adding devices by "start linking" option, that did not work so I tried adding them manually. when i try adding it manually it fails with ''cannot determine insteon engine'' so, the firmware update did not fix the issue. anything else I can try before i spend money on new type of 2635-222 modules?
  18. firmware version is 4.0.5 so, should I upgrade the firmware? any risks with the upgrade?
  19. Mi ISY994 works like a charm, it is quick, very reliable (compared to smartlinc controller) and my insteon thermostat response is almost immediate. But, there is a problem when I try to add 2 older single band devices (Smarthome 2635-222 ApplianceLinc ) as they are not recognized, nor can I them manually. So, I was thinking, there has to be a way to make ISY recognize those devices. Can someone give me the pointers how to do this? I rather try different things then spend $ 100 if I can get those appliance modules to work.
