Waketech
  1. Is this the same fix for the ISY launcher app on my PC ?. On a side note when I enter the IP in browser I can log into the device/dashboard but cannot get into the admin console either I just get a screen that shows "ISY Please keep this window open Java 2+ required" ? I also just got into the dashboard and the error that comes up and I think it's the same that quickly flashes in the admin console is "IO error proxy device" Also tried turning the AntiVirus on/off with no difference
  2. All, When I use the ISY launcher to get into the admin console I can successfully enter my credentials, everything comes up normal and then almost immediately a box is displayed in the center of the screen (to fast to read what it actually says) and then the screen closes. Any idea ?, using version 4.8
  3. So I finally got around to deleting the device, however this time when I signed on the icons show a green arrow/triangle as per below... What do these mean ?
  4. So I see that you can remove the device from the folder but is that actually deleting it ?
  5. Tried the factory reset and then restore device and nothing
  6. Ok so I tried the device links and got the error "failed reading device link (name) [-200000/-5]" And on the level 3 I got this Tue 06/26/2018 09:52:24 PM : [All ] Writing 0 bytes to devices
  7. I looked at the device quickly when leaving and noticed the green LED was no longer on, does this mean it's NFG ?
  8. All, I have an IOLinc that is not responding (as per message when I open the console and red acclimation mark), however I can still control it. Any ideas ?. I also tried to right click and restore the device but this did not work either.
  9. Waketech replied to mbro's topic in UD Portal
    Ok got it up and running
  10. Waketech replied to mbro's topic in UD Portal
    So on the WIKI it says that Please Note that your request will cause the Network Module to be Uninstalled and not accessible after the expiration of the ISY Portal Subscription I assume this means that the ISY Portal takes over all these functions and if something happens to the Portal then I can go back to using the network module as a stand-alone ?, secondly if I purchase the module do I need to email support to get it turned off ? Thanks
  11. The I/O linc on the opener is currently used to tell me if the door is opened or closed and so I can shut it remotely if left open. I lost my opener so am looking for a replacement and additional functionality (example: disable alarm as well as open door).
  12. I have a dual band switch linc about 10' from the IOLINC
  13. This one 2342-232
  14. All, Does anyone use one of these as their primary opener ?, if so are there any delays from when you get on your driveway to when the ISY recognizes that the remotlinc is in range and thus have the ability to open your door. TIA
  15. Waketech replied to Waketech's topic in ISY994
    Thank you for the help in working on this. I have determined that the unit will return to operation based upon the last switch position. My intent will be to turn on when needed and run for x amount of time to avoid cycling of the device. My worry is that too much power on/power off my damage the device or am I over worrying ?
